May 17th, 2012, 12:14 AM | #1 |
Join Date: Jul 2011 Motorcycle(s): 2019 Ninja 400, 2009 KLX250-SF, 2014 Zero S Posts: 269
weak rear brake -- a feature, not a flaw
My 1981 cx500 has a great feature, it has a rear drum that is impossible to lock up. Maybe if you jump on the pedal, but pushing down hard will not lock it up (but it definitely does help the bike slow down quicker). Shouldn't all bikes be like this? Having practiced and having had to actual do panic stops to avoid hitting cars on the 250, I have totally bought into Alex's idea that it seems to basically take 100% of your attention when stopping quickly to just modulate the front brake for maximum braking power. Locking up the rear does help you stop, but one thought I have is I could 'upgrade' the 250 to a weaker rear brake. Any thoughts or ideas on how this would be done? Make the pad surface area smaller? Drum brake upgrade?
Yes, I know I can practice, practice, practice. But my experience is that panic braking occurs when you are in a panic. And my practice sessions seem to show that it takes incredible focus to modulate the rear for maximum braking. |
May 17th, 2012, 12:30 AM | #2 |
Join Date: Aug 2010 Motorcycle(s): Ninja 250r 2009 Posts: 396
May 17th, 2012, 12:35 AM | #3 |
I would still go with practicing panic braking. Could also throw in engine braking by down shifting. Switching to organic rear brake pads may help or adjusting the rear brake to need more pedal to apply same braking force.
May 17th, 2012, 01:08 AM | #4 |
if you are set on the bike well and aren't jumping whoops, you can accurately move the pedals. but its a bitch to move them hard. so the less input you have to give, the more precise you can be with it.
why you would use a rear brake is another story
May 17th, 2012, 02:13 AM | #5 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
Sort of related, but I use GG grade pads on the rear instead of HH to help reduce lock up. While it would still lock up if I tried, it's extremely unlikely myself or anyone else on my bike would lock it without deliberately trying.
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
May 17th, 2012, 06:08 AM | #6 |
Old-tech ABS, just make the brakes too weak to be able to lock the wheels at speed.
May 17th, 2012, 07:06 AM | #7 |
Join Date: Apr 2011 Motorcycle(s): 2010 Ninja 250R Posts: 294
May 17th, 2012, 07:42 AM | #8 |
The lock up of the rear tire during really strong braking of the bike will happen, regardless the rear brake power.
At 1g deceleration, all the weight moves forward, leaving the rear tire literally in the air, or at least reducing the friction force between asphalt and tire to near zero. "The obvious mathematics of the situation are that the front wheel can do 100 percent of the braking and the back at that point just locks up no matter who you are. Learn to totally rely on the front brake for quick, clean stopping; then, if you still have a use for the rear, go ahead and use it. But realize that the rear brake is the source of a huge number of crashes both on and off the track." - Keith Code
May 17th, 2012, 08:14 AM | #9 | |
So it sounds like some people say not to use the rear brake at all... how common is this thought? Clearly, it will help you stop, and as long as your going in a straight line, locking up doesn't usually cause a problem. Is this an old debate? Well, I think my upgrade is a real possibility. So the pregen 2007 comes with HH pads stock in the rear? What about cutting grooves into the pad with like a dremel or circular saw to reduce the surface area? |
May 17th, 2012, 08:31 AM | #10 |
Some racers even disconnect or remove the rear brake.
The rear brake will help you in normal braking, but not much for emergency stop after the wheel stops turning. The skidding friction is much lower than the rolling friction. Check these brake articles: http://www.msgroup.org/Articles.aspx?Cat=2
May 17th, 2012, 08:38 AM | #11 |
as motofool stated above, if you're braking, your momentum pushes you onto the front wheel.
Braking force is directly proportional to the weight exerted by the wheel (f=mu*m*g, m*g being weight). If you're almost doing a stoppie because you're stopping so hard, there's basically no weight on the rear tire, and any ammount of force on the rear brake will lock it up. IMO, the rear brake is there more to reduce the wear on the front brake and more ballanced breaking during average riding. In a panic, don't bother with the rear brake because you're so likely to lock it up and have it slide out from under you. cliff notes: weak rear brakes prevent you from accidentally locking when you're not in an emergency, but in an emergency, anything can lock the rear wheel. |
May 17th, 2012, 09:36 AM | #12 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
Alan: I solved your problem by deciding to use only the front brake in emergency stops. I use the rear for other situations (like gently braking on a loose/non-grippy surface. Holding the bike in place on an incline when at a stop. Coming gently to a stop.)
There seem to be plenty of people here who brake front only and plenty who brake with both brakes. I just made this poll to get an idea of the numbers. |
May 17th, 2012, 12:37 PM | #13 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Rear brake + 2 up = awesome. I can almost stand on it and it will stop me easy without locking, but even in 2 up emergency stops I've locked the rear for that millisecond. I keep in practice using both brakes for emergency stops, but I've never been in a situation where I have to stop as quick as possible to avoid damage, injury or worse. I also use the rear + engine braking in normal riding to require less effort with the front brake and again just to stay in practice.
May 17th, 2012, 09:12 PM | #15 | |
[roadracingworld.com] - â??Friday Product Feature: Updated Galfer Superbike Brake Lin | Ninjette Newsbot | Motorcycling News | 0 | January 30th, 2015 11:10 AM |
Does anyone see a design flaw in this product? | corksil | General Motorcycling Discussion | 21 | January 16th, 2015 10:24 PM |
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. | N-m | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 17th, 2014 04:13 AM |
[roadracingworld.com] - Friday Product Feature: Performance Cycleworx Pro Brake Lever | Ninjette Newsbot | Motorcycling News | 0 | February 22nd, 2013 04:10 PM |
Weak-ish Brake | saxnbass | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 26th, 2012 07:11 PM |
