Old January 12th, 2016, 09:08 AM   #1
Nu2Street
Motorcycle(s): 2006 Ninja 250R
Added lights in the Pods of my '06 Ninja
I followed info I found on this site and added lights to the pods on my 06 Ninja 250. No 1157 bulbs, I used 2357? In the center for a brighter brake light, and 2397 ? I'm not at home to look at the packages in the pods for a dimmer running light to not overheat the pods.
One change I am going to make with the wiring is to add bullet connectors to the tail light circuit so if I want the pods to only illuminate with the brake lights they can. I already put bullet connectors on the brake light circuit. Going to try and post my first pic. But not sure if it is too large in size- bites.
Nu2Street is offline   Reply With Quote
Old January 12th, 2016, 09:15 AM   #2
netdobeiras
Motorcycle(s): 2004 kawasaki ninja 250
be careful with which kind of connectors you put on. Bullets are not that great. molex connectors or the ones from corsa-technics are the best. I have tried so many different connectors on my electrical mods that the only ones that work proficiently are molex or corsa-technics. the crimp on ones eventually get ripped apart from use. Maybe your electrical skills are better than mine but i don't use crimps anymore cause i have had it with them. Other than that nice job it looks fine.
netdobeiras is offline   Reply With Quote
Old January 12th, 2016, 09:21 AM   #3
Nu2Street
Thanks. Are the connectors you use solder-on instead of crimp?
Old January 12th, 2016, 09:31 AM   #4
netdobeiras
i do both. i put the wire in, crimp the side tabs then solder on the wire.
Old January 25th, 2016, 05:51 PM   #5
Paddyd
Motorcycle(s): 2003 ninja ex 250
2003 ninja
Sure did you find the steps for this mod?
Paddyd is offline   Reply With Quote
Old January 25th, 2016, 07:40 PM   #6
Nu2Street
It was on ninja250.org. "I want to wire extra brake lights into those empty rear sockets".
Old January 28th, 2016, 07:30 AM   #7
Nu2Street
Did that help?
Old February 14th, 2016, 06:26 PM   #8
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
http://faq.ninja250.org/wiki/I_want_...y_rear_sockets
WANTED for 88-07 Ninja 250:
Corbin Gunfighter & Lady seat
iplante is offline   Reply With Quote
Old February 14th, 2016, 07:03 PM   #9
Ghostt
Ghostt's Avatar
Hope this helps you out, keep in mind that this chart is for incandescent bulbs NOT LEDs
The thing to keep in mind that a change in brightness isn't the most effective brake light, changing the shape is more effective, if you just wire the pods for brake only, not only will it be brighter, but also changes the shape and size of the brake light.
An added bonus would be installing a brake light modulator.
I have done the modulator, along with adding two small CREE LEDs in the bottom of the license plate, along with an CREE LED, and added a reflective red ninja graphic due to the DIY fender chop.
The photos below were taken in direct sunlight to show the brightness of the CREE LEDs.
I converted my pods to turn signals, so adding the two CREE LEDs under the license plate for additional safety and visibility. According to others that have been behind my bike they all say they are extremely bright.
violente et ignorantia
ZX-2R BLOG
Extra Brake Lights in pods = all other lights dimming CalvinAmI 1986 - 2007 Ninja 250R Tech Talk 23 October 16th, 2012 10:21 AM
Added lights to the rear pods - now having issue iplante 1986 - 2007 Ninja 250R Farkles 5 July 24th, 2012 12:47 PM
Added driving lights gogiburn 1986 - 2007 Ninja 250R Farkles 8 July 25th, 2010 05:48 PM
[topix.net] - $1050 added value on CRF-X, $500 added value on Mini, Scooter & Entry Ninjette Newsbot Motorcycling News 0 March 31st, 2010 04:20 AM
Chopped fender & Installed lights in pods Snake 1986 - 2007 Ninja 250R Farkles 22 January 19th, 2010 12:48 AM
