July 9th, 2016, 11:17 AM | #1 |
Join Date: Jul 2014 Motorcycle(s): 2014 Ninja 300 track bike, 2007 Suzuki GSXR 750 track bike, 2002 Yamaha R6, 1995 CBR600RR f3 track bike Posts: 304
Bypassing ABS?
I want to bypass the ABS unit on my 2014 track bike. I have a new Galfer braided line.
The reason for doing so is that I can't bleed the front brake to firm enough. It always remains spongy. One of the coaches at TPM told me that it has to be done by the dealer. Apparently they connect a sensor or computer to the bike to engage the ABS for bleeding. Nope. I want to do it and I want a stiff lever for those rare occasions on track where I actually use the brakes. My question is will the bike run/operate as before if I disconnect the ABS unit and go with direct lines? Thanks
Track, track, track |
July 9th, 2016, 12:45 PM | #2 |
Have your serviced the calipers? Flush and fill new fluid? How are bleeding the brake system?
I use and recommend picking up a hand vacuum pump, like this one, makes bleeding brakes easy and quick, takes me about 2 minutes at the most. HFS (R) 2 in 1 Brake Bleeder & Vacuum Pump Test Tuner Tool Kit New https://www.amazon.com/dp/B00NP60URE..._3mvGxbY9ZCYSX Comes in handy for a lot of things requiring vacuum, like testing petcock, bleeding brakes, sensors, etc.....
July 9th, 2016, 12:58 PM | #3 |
That looks like a nice system but it's a pretty simple process for the Ninja.
Squeeze, squeeze, squeeze and hold. Open, close nipple. Repeat. It's the ABS unit that's the issue.
July 9th, 2016, 12:58 PM | #4 | |
Vintage Screwball
MOTM - Mar '16
Check your VIN number here: https://www.kawasaki.com/OwnerSupport/SafetyRecall
Goin' fast on slow bikes! |
July 9th, 2016, 12:59 PM | #5 |
I'll check on Tuesday.
July 9th, 2016, 01:03 PM | #6 |
Vintage Screwball
MOTM - Mar '16
One other thing, have you tried tying the brake lever back to the bar with a zip tie over night?
July 9th, 2016, 01:05 PM | #7 |
Clearly you've never used one, it's even easier, open bleeder, pump, pump pump, and done, obviously top off the fluid and your done, no more need for endless pumping, or worried about trapped air, etc...
July 9th, 2016, 01:08 PM | #8 |
MOTM - Mar '13, Jun '14
Now I know why these bikes are fastest in the corners!
July 9th, 2016, 01:17 PM | #9 |
Vintage Screwball
MOTM - Mar '16
I don't know why it wouldn't work to just bypass them. The ABS unit is just a passive one so it shouldn't interfere with engine management features that I know of. I's hoping your issues are tied to the recall. If it is under recall, even bypassing it won't help.
July 9th, 2016, 02:56 PM | #10 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
I wish my Mityvac was that simple... takes me longer to get a good seal on any bleeder valve than it takes me to just bleed the brakes the old-fashioned way...
DISCLAIMER: I generally have no idea what I'm talking about. |
July 25th, 2016, 12:29 PM | #11 |
The ABS has to go. I had very little brake left after 4 or 5 laps of Shenny.
Anyone have a spare stock rear brake line? Mike
July 25th, 2016, 01:04 PM | #12 |
Vintage Screwball
MOTM - Mar '16
I would recommend unplugging the ABS unit and going for a ride to see what it does to the ECU.
On it's big brother the ZX6, it pretty much turns on every idiot light there is on the dash simply by removing the lines.... I can't find anything on removing the unit. This would be a way to test and see what would happen before you went through all the work to bypass it. This place has some helpful hints as well: http://www.kawasa***************/for...s-removal.html
July 27th, 2016, 01:26 PM | #13 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
July 27th, 2016, 02:42 PM | #14 |
It's an exercise of patience that most do not have to force air out of a brake system.
July 27th, 2016, 04:22 PM | #15 |
Join Date: Dec 2014 Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100 Posts: 185
November 9th, 2016, 08:24 AM | #16 |
sorry to bring this back, but did any one find a solution for the wear issue also i was wondering if just running a single line to the caliper in front and rear will do the job?
November 9th, 2016, 08:35 AM | #17 |
I'm not sure what you're referring to but I put a braided line on the front and a stock non-abs hose in the rear. I did remove the entire ABS system and hard lines with no ill effect on either the brakes or electronics. The brake lever is solid now.
November 9th, 2016, 09:11 AM | #18 |
thats exactly the answer I'm looking for thanks Mike and sorry i could be confusing at times
November 9th, 2016, 09:16 AM | #19 |
Glad to help. Is your 300 for street or track?
November 9th, 2016, 09:33 AM | #20 |
Sorry that I never replied to this. Yes, this is my routine. Both track bikes whenever parked. I have velcro straps for this. Keeps the valve open and lets any air percolate up and out of the line.
November 9th, 2016, 10:22 AM | #21 |
November 9th, 2016, 10:50 AM | #22 |
What organization do you ride with?
November 9th, 2016, 12:28 PM | #23 |
November 9th, 2016, 12:40 PM | #24 |
What group do you ride in (white, red, blue)?
November 9th, 2016, 12:43 PM | #25 |
November 9th, 2016, 02:05 PM | #26 |
There's one more weekend coming up with TPM in North Carolina at NCNike. Fun track and not crowded.
November 9th, 2016, 06:41 PM | #27 |
Can Ninja 300 ABS system from EX300B be ordered/installed on non-ABS EX300A? EX250J? | CZroe | 2013 - 2017 Ninja 300 Tech Talk | 8 | April 20th, 2013 01:06 PM |
