July 25th, 2016, 11:45 AM | #1 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Need help deciding whether I should Downgrade
Currently on a zx-6r, sorta interested in a 300/smaller bike. Not quite sure if I should though?
July 25th, 2016, 11:56 AM | #2 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
You try riding the 300 at the track, they just started that 15 bucks for a session. Start with body position and comfort and that will work you toward quicker laps.
Spoiler for topic:
July 25th, 2016, 12:05 PM | #3 |
What track is offering $15 track sessions?
July 25th, 2016, 12:07 PM | #4 |
#squid
MOTM - Jul '16
It's 75 for two sessions at NYST.
July 25th, 2016, 12:14 PM | #5 |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
You could spend a year riding a 250/300 then go back to the ZX6
July 25th, 2016, 12:14 PM | #6 |
Private Joker
MOTM - Mar '14
Yeah but those are stock bikes aren't they? Gotta at least switch the front tire for them to be fun and safe at track pace
edit: @AwDang is right, that is the ideal way to go about it I know tons of guys who own a 600/1000 and a 300. They improve so rapidly it's stupid. Running both bikes back to back continuously shows you ways to improve on the other
I see you over there seeing me, do you see the me I think you see? |
July 25th, 2016, 12:16 PM | #7 |
#squid
MOTM - Jul '16
I've got a few friends that wouldn't mind loaning me a 300 for a session.
July 25th, 2016, 12:22 PM | #8 |
I have one of each. 09 600 for track, z1K/250 for street. I run an intermediate pace (1:42ish) in NYST uptown. I want to improve entrance and exit speed along with bp, I didnt think about running 250 on track could improve that.
Pirelli demons decent enough trackday tire for 250? |
July 25th, 2016, 12:30 PM | #9 | |
#squid
MOTM - Jul '16
July 25th, 2016, 12:30 PM | #10 |
I like the A13's for cheap, durable and sticky
July 25th, 2016, 12:44 PM | #11 | |
Bluntness... Riding a lower hp bike around the track is humbling. You simply can't make up for lack of corner speed via the throttle on exit. You straight up have to be fast because YOU ARE. Period... Why? because 97mph in a corner is just the same as any other bike. CC's need not apply except on the straights. In due time, you may find that larger cc bikes are pulling on your on exit. At that point, out steer them and get back to the throttle sooner and that gain is erased. Then at some point you will start running into hella traffic on your "little bike". Time to move up or get a larger cc bike and take the time to get used to it before moving up a track day group. Simply put, you can't cheat skills on a low hp bike. And largely, aside of steering, vision and line skills, what you learn on a little bike is nearly 100% applicable to a larger cc bike. /real talk... My r6 lines, turn in points, braking markers, ect... are nearly the same as my 250's. Why? Because the machine is soooooo much more capable. If you want to accelerate your on track learning, get a little bike that you can just toss around with little to no effort. When you get something stronger power/faster between your legs, then adjusting to corner speed is not really a factor. Just adjusting to the new bike's capabilities. /100% honesty It took me about 4rys of solid track riding to finally outride the 250's abilities, perhaps a 300 is different, idunno until I can take one to max pace. At that same time, I have been riding my r6 and I would estimate that I am only at about 80% of it's abilities in stock form. And for full disclosure, you can drag an elbow on a stock r6. ijs.... Answering your question: Yes, the demons are enough for a track day with the right mindset of the rider. They are capable of near lap record paces with optimal track/weather/setup/rider conditions.
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; July 25th, 2016 at 01:50 PM. |
July 25th, 2016, 12:53 PM | #12 |
Also,
Now that Nick has a season or two behind him on the 600, I am not 100% sure downgrading is in his best interest based on forum posts. I would have to see him ride with my own eyes.
July 25th, 2016, 01:01 PM | #13 |
#squid
MOTM - Jul '16
The quickest I've gone is probably a 1:45ish which a mid intermediate pace. The quickest I've seen at the track is a 1:26, which is done by fast ccs and ama riders. A buddy of mine will let me ride their 300 this weekend.
I'd say I'm losing a lot of speed with corner entry. I just don't have the confidence in myself and the machine yet.
July 25th, 2016, 01:08 PM | #14 | ||
imho, stock kawi's have a pretty bad initial throttle roll vs what is possible. This holds riders back quite a bit when they are trying to work out their throttle control skills to the nth degree. This is especially true on a the zx10's. Perhaps that is a factor for you and you could use a custom throttle/fuel mapping to smooth it out a bit. Next would be to really hammer on your quick turn and vision skills. Once you get a handle on those, riding a bike faster becomes much easier. Because cc's don't matter on entry when your on the brakes. Quote:
July 25th, 2016, 02:42 PM | #15 |
#squid
MOTM - Jul '16
Gonna test ride a buddies cbr250 or maybe an r3, and I'll see what I think then.
July 25th, 2016, 02:49 PM | #16 |
r3!!!!
Please give a review if you would.
July 25th, 2016, 02:57 PM | #17 |
#squid
MOTM - Jul '16
I've ridden one a couple hundred feet and didn't like the throttle response, it felt very "carby". I'll try and ride the r3 on the track and let you know
July 25th, 2016, 03:07 PM | #18 | |
MOTM - Jan '16
You are asking people on the Ninja 250/300 web site if you should get a Ninja 250/300? That's kind of like asking drunks in the bar if you should have another drink. |
July 25th, 2016, 03:25 PM | #19 |
#squid
MOTM - Jul '16
If you read the above posts you'll see the mood is rather towards me keeping the zx
July 25th, 2016, 03:30 PM | #20 |
@stevect, sorry if my post come off as pushy (after rereading). Your input is welcome and well taken. :\ My bad...
July 26th, 2016, 12:22 PM | #21 |
Join Date: Nov 2010 Motorcycle(s): KTM 390 Duke Posts: 428
Why not get a literbike, eh?
July 26th, 2016, 12:32 PM | #22 |
For 2014+ 1000cc bikes, your statement may hold more truth than you might think. The newer bmw sr1000rr are amazing machines. The new yami r1's may even be better than that.
July 26th, 2016, 05:03 PM | #23 |
#squid
MOTM - Jul '16
One good reason is that I'll burn through less tires if I don't, as long as I keep mine from spinning.
downgrade! cha-ching! | alex.s | General Motorcycling Discussion | 13 | June 25th, 2014 05:02 PM |
Working on a downgrade... | alex.s | Pictures | 12 | May 27th, 2013 10:40 AM |
What to downgrade to after the 250? | rojoracing53 | General Motorcycling Discussion | 58 | May 17th, 2013 07:33 PM |
Need help deciding on boots please | userjh160 | Motorcycle Gear | 13 | February 17th, 2013 09:56 PM |
need help deciding | NHrider19 | 2008 - 2012 Ninja 250R Farkles | 14 | June 15th, 2012 06:48 PM |
