July 25th, 2016, 10:20 AM | #1 |
[motorcycle.com] - 2017 Honda CBR250RR Announced
Honda‘s Indonesian subsidiary Astra Honda announced the new CBR250RR, the production version of the Light Weight Sports Concept showcased last year at the Tokyo Motor Show. The double-R is a significant step up from the CBR250R, offering aggressive styling, an all-new Twin-cylinder engine, throttle-by-wire, selectable engine modes and other features usually expected from larger-displacement sportbikes. At the moment, the CBR250RR has only been confirmed for Indonesia and Japan; Honda will likely introduce a larger-displacement version for western markets to compete against models like Yamaha‘s YZF-R3 and KTM‘s 390 Duke. The CBR250RR is powered by a newly developed water-cooled four-stroke parallel-Twin. No performance figures are available yet, but Honda says it is aiming for class-leading performance. A throttle-by-wire system allows for three selectable power modes to suit different needs. The chassis is comprised of a steel truss frame with an asymmetric aluminum swingarm design with the right side shaped so the exhaust can be positioned closer to the center line, allowing for a slimmer shape and more lean angle. The swingarm is hooked up to a Pro-link monoshock with five-step preload adjustability. Up front, the CBR250RR uses an upside-down fork. A twin-piston Nissin caliper is paired with the single 310mm front disc while a single-piston caliper is fitted to the 240 mm rear rotor. ABS is optional, at least for the Indonesian market. The CBR250RR’s face is a menacing grimace that is a dramatic departure from the CBR250R’s relatively friendly visage. The dual LED headlights appears to match the design patent that we first uncovered in April. The sharp lines continue through the sculpted 3.8-gallon fuel tank design and back towards the sharp tail. The 2017 Honda CBR250RR is offered in three colors: Anchor Graymetallic, Honda Racing Red and Mat Gunpowder Black Metallic. 2017 Honda CBR250RR SpecificationsEngine Type4-stroke, 8-valve, parallel-Twin cylinderDisplacement249.7 ccCooling SystemLiquid cooled with auto electric fanFuel Supply SystemPGM-FIThrottle SystemThrottle-by-wire system with accelerator position sensorBore x Stroke62.0 x 41.4 mmCompression Ratio11.5 : 1Transmission ManualManual, 6-speedStarting SystemElectric starterClutch SystemMultiplate wet clutch with coil springOil Capacity0.5 gallonsFrame TypeTruss FrameFront BrakeHydraulic disc, dual piston (STD Type & ABS Type)Rear BrakeHydraulic disc, single piston (STD Type & ABS Type)Front SuspensionInverted telescopic front suspensionRear SuspensionAluminum swing arm (5-way adjustable mono suspension with Pro-Link system)Front Tire Size110/70 – 17 54S (tubeless)Rear Tire Size140/70 – 17 66S (tubeless)Length81.1 inchesWidth28.5 inchesHeight43.2 inchesWheel Base54.7 inchesGround Clearance5.7 inchesSeat Height31.1 inchesFuel Tank Capacity3.8 gallons2017 Honda CBR250RR Announced appeared first on Motorcycle.com. Click here for full story...
July 25th, 2016, 03:46 PM | #2 |
Interesting.
July 25th, 2016, 04:45 PM | #3 |
Join Date: Sep 2013 Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold) Posts: 529
They have my attention.
"Take it easy driving. The life you might save might be mine." Last futzed with by kdogg2077; July 25th, 2016 at 04:56 PM. Reason: typo |
July 25th, 2016, 04:51 PM | #4 |
MOTM - Mar '13, Jun '14
I wonder if it's fast in the corners?
July 25th, 2016, 06:16 PM | #5 |
Power modes, huh? Interesting. Seems like they should name them "newb" and "intense"
Interested to see how they do this for a US model, potentially. I'm laughing that the engine bore and stroke are so similar to the newgen 250. Wonder if that was on purpose |
July 25th, 2016, 06:58 PM | #6 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Honda has my attention.
July 25th, 2016, 07:05 PM | #7 |
I'm still not comfortable with throttle by wire in cars and trucks so throttle by wire in a bike would be hard to get used to.
July 25th, 2016, 07:33 PM | #8 |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally Posts: 384
Nice little motorcycle...
I like it a lot in its red delivery... I don't know if Suzuki will catch the train with something more than the GW250... |
July 25th, 2016, 07:44 PM | #9 |
I think Suzuki is a lost cause but at least they fixed the SV650 after that mistake they called the Gladius.
"Take it easy driving. The life you might save might be mine." |
July 25th, 2016, 11:26 PM | #10 | |
The Asian Caucasian
Name: Abu Mishary Mohd Fairus
Join Date: Jan 2016 Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current) Posts: 796
MOTM - Jan '17
But I am more intrigued if the USD fork could reply the OEM on the new gens. Hopefully it would. Starting to foresee an upgrade for mine!
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is. |
July 26th, 2016, 03:08 AM | #11 | |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
July 26th, 2016, 05:59 AM | #12 |
Private Joker
MOTM - Mar '14
I'm giving honda a shot here, I'll try the bike but I'm not sold on it just yet. At this rate the new kawasaki 300 will be coming soon which has me a bit more interested in that as an option
not to mention the sv650 has been stirring my soul wanting me to get a few of them for track and street use so it has stiff competition for my $$$
July 26th, 2016, 06:01 AM | #13 | |
EX500 full of EX250 parts
This looks like a neat little bike, but I'm worried that price and "It's a beginner bike" will win out on the US model.
July 26th, 2016, 06:40 AM | #14 | |
Private Joker
MOTM - Mar '14
July 26th, 2016, 06:42 AM | #15 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
I have a serious case of 250cc 4-cylinder blue balls now...
DISCLAIMER: I generally have no idea what I'm talking about. |
July 26th, 2016, 06:49 AM | #16 |
July 26th, 2016, 07:31 AM | #17 | |
The best you can reasonably hope for is what the Ninjette delivers: A budget street machine that's a hoot when you ride it really hard. This bike isn't a mini-supersport to begin with, so there's nothing to "strip." To me, a real supersport has a few defining characteristics: - Aggressive geometry - Aggressive ergonomics - Stiff, aluminum perimeter frame - Fully adjustible suspension, front and rear - Serious brakes A few other telltales, like actual clip-ons vs. fixed bars that kind of look like clip-ons, also come to mind. This bike, just like the Ninjette, R3, RC390 and existing CBR300, lacks all of these. It's just another in the field. Having said that, I do like the looks a lot and the ergos appear to be maybe just a tiny bit more aggressive than the norm.
July 26th, 2016, 09:27 AM | #18 |
Modes: NTN (Next to none), LIL (Lil' bit), ASG (All she's got)
July 26th, 2016, 11:13 AM | #19 | |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
Oh yeah.... Dibs on the first salvage CBR250RR for a racebike! |
July 26th, 2016, 11:18 AM | #20 |
MOTM - Nov '15
July 26th, 2016, 11:25 AM | #21 |
July 26th, 2016, 11:39 AM | #22 |
MOTM - Nov '15
July 26th, 2016, 02:09 PM | #23 | |
It goes a little something like this: (start at 1:39 unless you like Teen Titans GO!) |
[motorcycledaily.com] - 2017 Honda CBR250RR Unveiled in Indonesia (with video) (Bike | Ninjette Newsbot | Motorcycling News | 0 | July 25th, 2016 07:50 AM |
[motorcycle.com] - 2017 Honda CBR250RR Teaser Video | Ninjette Newsbot | Motorcycling News | 0 | July 11th, 2016 09:30 AM |
[motorcycle.com] - 2017 Honda Montesa Cota 4RT260 Trial Bike Announced for Europe | Ninjette Newsbot | Motorcycling News | 0 | June 30th, 2016 01:40 PM |
[motorcycle.com] - 2017 Honda Grom Announced for U.S. | Ninjette Newsbot | Motorcycling News | 0 | June 9th, 2016 12:10 PM |
[motorcycle.com] - Honda Headlight Patent Hints at Upcoming CBR250RR | Ninjette Newsbot | Motorcycling News | 0 | April 5th, 2016 02:10 PM |
