Old August 26th, 2015, 07:18 PM   #1
higear223
higear223's Avatar
Motorcycle(s): 08 Ninja 250, 09 650 V-Strom, 07 CRF230F
Clear tubing compatible with brake fluid
Does anybody know what type of clear tubing is compatible with brake fluid?
higear223 is offline   Reply With Quote
Old August 26th, 2015, 07:26 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
DOT 3 and 4?
Silicone tubing, Tygon tubing are ok.
Old August 26th, 2015, 08:35 PM   #3
MrAtom
MOTM - July '15
You mean for bleeding the brakes/changing out brake fluid, right? I just used clear vinyl tubing. No issues.
Old August 26th, 2015, 09:28 PM   #4
Ralgha
Ralgha's Avatar
If your needing tubing for bleeding, I don't think it matters much. If the fluid is going to damage whatever you use, it's not going to do it before you finish. I used whatever the local hardware store has, vinyl I think.
Old August 27th, 2015, 09:18 AM   #5
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
for bleeding, the regular vinyl you find at the hardware store will be fine. Run some WD40 through it afterward and you'll be able to use for a very long time.
To replace the rear brake reservoir where the fluid will stay in the tube for the life of the tube, you have to use Tygon as it won't be destroyed by the fluid.
Old August 27th, 2015, 03:00 PM   #6
higear223
higear223's Avatar
Looks like Tygon is what I need since I am contemplating replacing the rear reservoir. Now the question is where can I get it.
Old August 27th, 2015, 05:01 PM   #7
dcj13
Participant
dcj13's Avatar
A good hardware store. Not necessarily HD or Lowe's...
Old August 28th, 2015, 09:35 AM   #8
spooph
spooph's Avatar
MOTM - Oct '15
http://www.usplastic.com/catalog/default.aspx?catid=864
but since you only need 4" might want to call around your local automotive repair stores or moto dealers/shops. I found some at an industrial supply store and my local Kawi dealer.
Old August 28th, 2015, 09:45 AM   #9
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
@higear223 I have many many feet of Tygon tubing I use for master cylinder upgrades. How much do you want?
Old August 28th, 2015, 07:16 PM   #10
higear223
higear223's Avatar
Well, shoot! I already bought a foot of it off Ebay.
Old August 29th, 2015, 06:24 AM   #11
TnNinjaGirl
Ms. Personality
Tygon is still the way to go
Old August 29th, 2015, 09:27 AM   #12
US Plastic is super helpful for stuff like that. I used them for my bixenon retrofit needs, as well as Tygon tubing for all my carb fuel and vacuum lines. Works great. It's even this funny yellowish-green color.
Keep them in mind if you ever need bulk plastic for things. They're not cheap because you have to buy in bulk, but they're pretty competitive on pricing when you look at their unit price and you're going to use most of what you bought.
Old September 1st, 2015, 05:29 PM   #13
higear223
higear223's Avatar
What do you guys think?
Old September 1st, 2015, 06:28 PM   #14
dcj13
Participant
dcj13's Avatar
Lovely!
Old September 2nd, 2015, 08:20 AM   #15
spooph
spooph's Avatar
MOTM - Oct '15
You can cut it down to about 4". That's what mine is, just gotta be careful when you bleed it as a single pump of the master cylinder will drain the entire 4".
Old September 2nd, 2015, 04:46 PM   #16
higear223
higear223's Avatar
Does anyone have a better way to cap it off? I just clamped a bolt in it.
Old September 2nd, 2015, 05:14 PM   #17
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Hey do you think you could send some of that my way. I've been wanting to replace the rear brake master on the Aprilia cause the stock setup is ridiculous.
Thanks, and I'd be happy to pay for shipping and the tube.
Old September 5th, 2015, 08:26 AM   #18
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 45k miles
clear tubing . . .
Not all Tygon tubing is created equal. I talked to tech support and they recommended Tygon 2375.
I have two feet 3/8" ID x 5/8" OD and I used 3 inches on my Ninja for the track. PM me if you want this size. How about $7 for 4 inches mailed?
You might want to have a vent hole in the plug.
Fred
'09 Ninja 250R track only SOLD
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
Old September 5th, 2015, 09:43 AM   #19
higear223
higear223's Avatar
Yeah, 2375 is what I got, definitely the right stuff.
Maybe a vent hole is in order.
Old September 7th, 2015, 05:39 PM   #20
TnNinjaGirl
Ms. Personality
I have the 2375 which is what is required for brake fluid. PM me your address if you haven't already bought some (sorry it took me so long to get to you)
Old September 8th, 2015, 12:22 PM   #21
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The stock reservoirs have a diaphragm under the cap, so that as the fluid level drops during use, it can follow it down. Having a fixed volume sealed in there could have a minor effect on how the brake works, due to the vacuum resisting the flow of the brake fluid (similar to tank vent issues causing fuel flow problems). Maybe there's enough flex in the hose that it can collapse a little? *shrug*
Obviously it doesn't seem to be a major problem for everyone already using this setup, but it would be ideal if you could get some sort of diaphragm/vent in there.
Old September 8th, 2015, 01:00 PM   #22
TnNinjaGirl
Ms. Personality
I would be afraid that the vibrations could aerate (sp?) The fluid and cause issues.
Old September 8th, 2015, 02:05 PM   #23
spooph
spooph's Avatar
MOTM - Oct '15
definitely do not put a vent on that. Fluid might leak out and will slowly eat the paint off of everything it comes in contact with...
never had a problem with mine. If the brakes are properly bled, it won't cause any issues to cap off.
I used a brass sprinkler fitting from the hard ware store to cap mine off.
Old September 8th, 2015, 07:18 PM   #24
Other issue with vent: water, which will make your brake soft and lower the boiling temp. Not REALLY and issue with the rear brake, but still not something I'd prefer not to set myself up for. Plus you'd be leaving a system open that's intended to be closed. Unless you have a desiccant breather on there then... well... it's really just your rear brake, kudos for over-achieving but come on.
Old September 14th, 2015, 01:00 PM   #25
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
I hope this thread did lead to this.
Old September 14th, 2015, 07:26 PM   #26
^^ Bwahaha, that's brave! At least they have nice grips. Mini endurance race bike? Looks like just kill switch and starter button. I'd rock it.
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
brake tubing ID size? tiggen 1986 - 2007 Ninja 250R Tech Talk 0 January 8th, 2011 04:54 PM
How much brake fluid ? GiGs 2008 - 2012 Ninja 250R Tech Talk 5 December 31st, 2010 06:06 PM
Brake Fluid? ASecretNinja 1986 - 2007 Ninja 250R Tech Talk 4 January 20th, 2010 03:02 PM
