September 9th, 2013, 03:51 PM | #1 |
Petcock gaskets?
I have a 1990.
Finally got my bike back together earlier... Runs like magic! Except the petcock decided it wanted to start leaking out of the knob itself. (That and some place off the carb started leaking randomly but that's for another thread. >_< ) What would be the recommendation to fix this? It looks like a simple gasket swap around the knob. Could I be missing something or is this what usually fails? This being said, does anyone know the diameter of this gasket off hand? |
September 9th, 2013, 04:46 PM | #2 |
Did you try putting more pressure on the exterior spring-washer?
It may stop leaking after more time in contact with gasoline; all these neoprene parts shrink some when dry. No, I don't know the diameter. Some useful reference here: http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap
September 9th, 2013, 05:13 PM | #3 | |
September 9th, 2013, 05:34 PM | #4 | |
If all else fails, order a new one from the dealer. The front gasket is actually a pretty unusual place for it to leak. Does it do it when its turned to OFF? Are you sure it isn't actually coming from your diaphragm weep hole? If you temporarilly stick a small tube on the small port and suck on it, and you get air or gas, then the diaphragm is shot.
September 9th, 2013, 10:46 PM | #5 | |
It's definitely dripping through the knob... It is kinda weird with the lack of fuel going into the carb though when the engine is running as well. Could definitely be the diaphragm... If that's the case, what would be the best solution? |
September 10th, 2013, 06:34 AM | #6 | |
You'll probably need, the knob O-ring (92055-1085) and the washer with holes in it under the knob (43049-1103). If the diaphragm itself (43028-1068) is bad, then it should be replaced. If it drips when ON and no vacuum, then the o-ring on the diaphragm (92055-1664) is bad. Its possible that the o-rings can be bought at the local hardware store. The o-ring that goes on the diaphragm is industry standard size "-007". The one behind the know is industry standard size "-019". The oval shaped o-ring that goes between the petcock and the tank is a special one that has to come from kawasaki. If you are 100% certain the leak is from the knob, try replacing the knob o-ring first. Make sure you get one that is gasoline resistant. Nitrile or Viton will work.
September 10th, 2013, 11:59 AM | #7 |
It came with the bike but it didn't do this last time I had it running. The only thing that has changed with it was swapping it onto a new none rusty gas tank. I don't mind rebuilding it at all. Just was hoping for an easy fix... Just a matter of tracking down the right parts at the store. What makes matter worse one of the small screw holes on the face plate is apparently stripped at the end...
September 10th, 2013, 03:32 PM | #8 | |
Maybe trying a little washer between the head of that screw and the washer-spring?
September 10th, 2013, 07:59 PM | #9 | |
It's holding so far so I can live with that. Thanks for the help guys. |
September 10th, 2013, 08:04 PM | #10 |
September 11th, 2013, 06:24 AM | #11 |
As long as it stays fixed, all is well.
September 11th, 2013, 12:54 PM | #12 |
Well that was short lived... those ridiculously small face screws just blew out. Probably the slight extra bend I put on that o-spring. Completely stripped now. Lovely.
September 11th, 2013, 02:21 PM | #13 | |
September 11th, 2013, 02:28 PM | #14 |
September 11th, 2013, 02:41 PM | #15 | |
Worst case, ebay -> new petcock.
September 12th, 2013, 06:02 AM | #16 |
I opted for the later at this point and just see how it goes... Even worse worst case scenario I have to buy a brand spankin new one. =/
08 and up cylinder base gaskets | bruce71198 | Items Wanted | 3 | June 19th, 2014 07:48 PM |
Gaskets | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 10 | November 6th, 2013 06:27 AM |
Make your own gaskets | cuong-nutz | General Motorcycling Discussion | 4 | October 11th, 2013 03:09 PM |
Vacuum nipple came off petcock - fix or replace petcock? | fierostetz | 1986 - 2007 Ninja 250R Tech Talk | 3 | November 24th, 2012 11:03 AM |
I need some float bowl gaskets ... | Jim Moore | 1986 - 2007 Ninja 250R Tech Talk | 9 | November 1st, 2012 10:59 PM |
