Old September 17th, 2016, 06:50 AM   #1
Tango89er
Motorcycle(s): '89 Ninja 250 (#3650)
Starting problems
So, having a few problems with my EX 250F
Had it running a week after I bought it, with the help of fresh petrol, a new battery and a little bit of a Nulon spray called 'Start Ya Bastard'
Ran a little rough, idled nicely after about five minutes though, and revved right up to 14k rpm really well. Since then though, I've pulled out the carbies and gave them a clean, replaced the engine intake boots.
Unfortunately, it took me a few weeks to get it back together and now I can't get it started.
Any ideas?
Tango89er is offline   Reply With Quote
Old September 17th, 2016, 12:34 PM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
You getting fuel and spark?
I can't diagnose the problem without more info :/
Things usually run a bit rough at first when you start them on the spray.
Old September 17th, 2016, 03:35 PM   #3
Tango89er
Getting both fuel and spark. Just drained the carbies to check for water because the fuel tank has been sitting for a while, but it was fine
Old September 17th, 2016, 03:42 PM   #4
JohnnyBravo
It turns over but won't crank?
You sure the fuel is getting to the combustion chamber?
All it takes is fuel, spark, an combustion an things work like magic... Something ain't doing right
Is it flooded? If no...
Squirt it again, see what happens
Old September 17th, 2016, 07:05 PM   #5
If you drained the carbs you will need to do some extra cranking to get fuel to the floatbowls.
Charge the battery and give it another try.
Old September 17th, 2016, 11:36 PM   #6
Tango89er
How long should I crank it for? Is flooding a concern?
Old September 17th, 2016, 11:54 PM   #7
JohnnyBravo
Don't just hold down the starter button, you could burn out your starter
Just don't twist the throttle an you won't flood it
Old September 18th, 2016, 03:55 AM   #8
Tango89er
Awesome, I'll give that a try, see how it goes
Old September 18th, 2016, 05:56 AM   #9
I'd put on full choke, and crank for a max of 10 seconds at a time with 10 seconds between attempts.
As soon as you get a sputter, back the choke off a bit. Once it's going set the choke to keep the revs about 2000 to 2500. Turn it off completely as soon as it will idle without dying.
Did you remove the caps and set the idle mixture screws to 2.5 turns out?
Old September 18th, 2016, 07:27 AM   #10
Tango89er
So found a moment of reprieve from the rain to give the bike another look over (Perth weather is pretty bad at the moment). Turns out the problem was simply a leaking petcock and a half-flat battery. Letting everything drain for a bit while I charged the battery fixed everything.
Barely cranked at all before coming to life.
Just need to adjust the idle and throttle cables
Old September 18th, 2016, 02:02 PM   #11
JohnnyBravo
Sweet work man!
Old September 18th, 2016, 02:13 PM   #12
Snake
Snake's Avatar
Awesome!
Old September 18th, 2016, 02:15 PM   #13
For a leaking petcock to cause trouble, something else has to also be leaking, like the carburetor float valves.
Replacing the little O-ring on the petcock's valve plunger stopped mine from leaking. They're an industrial size 007 Viton O-ring, available from industrial suppliers. McMaster-Carr is one.
Old September 19th, 2016, 03:16 AM   #14
Tango89er
Could easily be the float valves, I didn't check them too well. Starts first time, every time now, but starts revving despite no throttle being applied. Cables are tight though, so I will adjust those as well as while I'm poking around
Old September 23rd, 2016, 01:46 AM   #15
Tango89er
So, finally ripped the carbs out again. Checked the float bowls, sorted out the idle adjust screws, gave the petcock a look over. Put it all back together and now we have this:
https://youtu.be/he5FqOfGE1o" TARGET="_blank">Link to original page on YouTube.
Starts from cold no problem, idles at 1500 rpm
Last futzed with by Tango89er; September 23rd, 2016 at 07:05 AM. Reason: Video problems, apparently
Old September 23rd, 2016, 06:54 AM   #16
^ Embed and link for the video doesn't work.
Old September 23rd, 2016, 06:58 AM   #17
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Goin' fast on slow bikes!
starting problems deanomyte 1986 - 2007 Ninja 250R Tech Talk 7 November 5th, 2012 06:59 PM
Problems starting engine Slono 2008 - 2012 Ninja 250R Tech Talk 7 March 31st, 2012 08:38 AM
starting problems dago 1986 - 2007 Ninja 250R Tech Talk 21 March 17th, 2012 01:50 PM
Problems Starting running a bike danius 2008 - 2012 Ninja 250R Tech Talk 0 October 28th, 2010 05:39 AM
Starting in First Momaru 2008 - 2012 Ninja 250R Tech Talk 11 April 12th, 2010 06:57 PM
