April 3rd, 2010, 04:27 PM | #1 |
Whooshing sound?
When accelerating, I hear a "whooshing" sound on the clutch side of the bike. Any ideas what this could be? Is it the pump/cooling system? The sound doesn't seem to be there when the bike is on neutral and I rev the engine.
April 3rd, 2010, 09:25 PM | #2 |
Anyone?
April 4th, 2010, 07:16 AM | #3 |
Have you checked the cooling system level?
April 4th, 2010, 07:34 AM | #4 |
Thanks Snake. Cooling system fluid level is fine. I am using water with Waterwetter if that makes a difference.
Posted via Mobile Device |
April 4th, 2010, 07:50 AM | #5 |
Ok, my next question is, What type of oil are you using? If you are using energy conserving oil like a 10W-30 then it could be making your clutch slip.
April 4th, 2010, 07:54 AM | #6 |
MOTM - Mar '13, Jun '14
It is a bearing sound or an air flow sound?
April 4th, 2010, 10:25 AM | #7 |
I am using the kawi oem oil. The sound is kid of hard to explain. Almost sound like a turbo spool.
April 4th, 2010, 11:20 AM | #8 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Chain noise?
April 4th, 2010, 11:25 AM | #9 |
gas cap?
April 4th, 2010, 02:25 PM | #10 |
You might have to make a sound clip so we can get a better idea.
April 4th, 2010, 05:05 PM | #11 |
Join Date: Mar 2009 Motorcycle(s): '09 Ninja 250 Black Posts: A lot.
fan running?
I'm not small, I'm fun sized |
April 4th, 2010, 05:35 PM | #12 |
Flux capacitor recharging?
Oscillation overthruster spooling up? |
April 5th, 2010, 10:31 AM | #13 |
It's not the fan for sure, nor the flux capacitor. It might be related to the gas... I have a Cali bike and I deleted the Cali emissions and Kleen air. Plugged the holes per Kkim's tutorial and replaced the Cali emissions via Vex' DIY - blue gas tank hole is replaced with a hose, a fuel filter and PCV valve. Could that be it?
P.S. video is not going to work as all you would hear would be wind noise. |
April 5th, 2010, 10:44 AM | #14 |
You are sleeping
Every once in a while you will hear your tank dump through the PCV I think but it's kinda noticeable. You should be able to tell that's what it is. It's quick and comes right from the area you mount it. It's the same type of deal as the "eeeeeeeeert" you get from the gas tank.
Mine more often dumps through the tank vent, wherever that is (in the lid?) than through the PCV.. but I vaguely recall hearing mine do that too. I'll keep an ear out for any wooshing and let you know.
<Yeah, it's a 250. LMFAO! Weaksauce |
April 5th, 2010, 10:57 AM | #15 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
The sounds always there when accelerating but not noticeable when revving the engine, while parked?
April 5th, 2010, 07:59 PM | #16 |
Join Date: Mar 2010 Motorcycle(s): Suzuki 630CC Posts: 2
I have the same problem as well, when I accelerate I hear a whining noise similar to the gas cap squealing. When I'm at a stop its gone, and when I rev at a stop its barely noticeable, but bad when I accelerate. Anyone know what it is?
April 6th, 2010, 12:49 PM | #17 |
April 6th, 2010, 12:50 PM | #18 | |
April 6th, 2010, 11:32 PM | #19 |
No mods?
I was wondering about sucking air.... |
April 7th, 2010, 08:28 AM | #20 |
You are sleeping
Didn't notice anything yesterday and did 300mi.
I think I notice it more when it's warm out. We have a lil cold going on again at the moment. I'm sure I'll hear it again soon. Will report back. Right now I gotta chase down a little squeak in my front wheel. Might be a few different things beside the speedo cable being that I still have some bent parts on.
April 25th, 2010, 12:56 PM | #21 |
Did you figure this out yet?
April 25th, 2010, 01:12 PM | #22 |
Bob, the more I hear it and try to track the location of the noise (while driving as safely as possible), it to me seems to come from the PCV valve that I installed. So that is what I am going to assume for now.
April 25th, 2010, 01:12 PM | #23 |
Join Date: Apr 2009 Motorcycle(s): '09 Ninja 250R Posts: 171
sounds like you guys have something similar to what i had, the noise is a lot less but still there. Still haven't diagnosed it. I'll be free come Wednesday so diagnosis rides can commence.
Back on the road again Season 2010 Dam it feels good! |
What is this sound? Is this what out-of-spec valves sound like? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 24 | November 15th, 2021 05:48 PM |
no sound | Ghostt | Help | 5 | March 7th, 2015 09:59 PM |
Name that sound | Vancouverite | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 31st, 2014 08:56 PM |
Does this sound right? | KawiKid860 | General Motorcycling Discussion | 10 | October 31st, 2011 05:51 AM |
does this sound right | reaperw | Videos | 10 | September 7th, 2011 11:48 AM |
