April 10th, 2012, 07:18 AM | #1 |
Drdriftking007
Join Date: Apr 2012 Motorcycle(s): 2007 Ninja 250 Posts: 67
Headlight not working :(
I have a 2007 Ninja 250 and for some reason my headlight does not turn on...neither the high beam. I check the bulb and it is not burned out. Anyone know what might be the problem? Any tips is appreciated!
April 10th, 2012, 08:06 AM | #2 |
MOTM - Mar '13, Jun '14
Does your bike run Lucas Electrics?
April 10th, 2012, 08:56 AM | #3 |
Really. Dumb. Question:
is the bike running when you expect the headlight to be on? It won't turn on unless the bike senses movement of the flywheel. aka, you have to start the bike to get the headlight to turn on, unlike many bikes where the headlight turns on right when you turn the key. |
April 10th, 2012, 09:04 AM | #4 | |
Drdriftking007
April 10th, 2012, 09:08 AM | #5 |
Then run through each part of the wiring and connectors with a multi-meter.
here's the wiring diagram for reference: http://faq.ninja250.org/images/a/a4/...matic_-_R4.pdf |
April 10th, 2012, 09:15 AM | #6 |
Drdriftking007
Thank you for the help, I am just new to this...I appreciate it.
April 10th, 2012, 02:46 PM | #7 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
"What a sweetheart."- ninja_sleeper to me |
April 11th, 2012, 08:15 AM | #8 |
Smoker
April 11th, 2012, 11:19 AM | #9 |
Drdriftking007
I checked the junction box and all the fuses and they are fine...bulb looks fine but ill buy a replacement for it and change it. Any other thing that could be wrong?
April 20th, 2012, 10:50 PM | #10 |
Join Date: Apr 2012 Motorcycle(s): 1990 Ninja 250 "Jolene" Posts: 68
I've been lurking for awhile, but this prompted me to finally sign up. I just had this problem about a month ago on my '91 and it was driving me crazy until I tore it all apart and checked every damn electrical connection there is on the bike. I believe around 94 they switched up some minor things in the electrical system, so hopefully this applies to your '07.
In the baby ninja, the headlight relay is inside the junction box, so if it's blown like mine was everything will work fine but your headlight. Use a multimeter to check the male connections for the 8 pin connector (the larger, copper colored ones on the upper right of the junction box). If i remember correctly, It is the topmost pair of connectors for the headlight, but could be the second from the top. Check the wiring diagram for the bike, and if you don't have one they have it on ninja250.org. If it's not that, it's possible you could have a bad diode in the rectifier, and there are guides available on how to check that as well. If it is the relay, there's probably a reason it blew. in my case, I had a short from a burned wire coming out of my rectifier. Find your short or it'll just happen again also, i believe there are at least one junction box and rectifier for sale in the classifieds of ninja250.org if you can't find any on here. DO NOT buy a vulcan 750 junction box. I did from a local guy because the internet 'confirmed' they were compatible, but they are not. I got about a mile down the road before my headlight went out again, and had to follow a truck back home in the dark while it turned on and off intermittently. Luckily he was nice and let me return it, but you might not be so lucky. FWIW, I paid something like 120 for a new one from my local dealer, so i'd go used if you feel comfortable with it. I'm pretty busy, but i'll try to get back here and offer any more advice i can! Good luck! |
April 24th, 2012, 09:15 PM | #12 |
Also, I checked the member map and there are a few other riders on here in the houston area... you could throw your junction box in their bike and check if their headlight's out after the swap. Then it'd be confirmed!
Help! Both Headlight Bulbs Not Working! | TheTKDSpartan | General Motorcycling Discussion | 11 | August 14th, 2011 11:15 AM |
Mounting stock headlight and gauges using headlight clamps? | SV_Hadder | 1986 - 2007 Ninja 250R Farkles | 0 | January 17th, 2011 09:15 PM |
Headlight lo-beam not working; burnt bulb? | HorizonXP | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 14th, 2010 02:39 PM |
