#1 |
Ninjette Noob
Join Date: Apr 2012 Motorcycle(s): 2004 YZF-600r ---- 2006 Kawasaki Ninja 250r Posts: 227
Overheat Issue
So I bought a Ninja 250r 2006 a few days ago, my first bike! It runs perfect besides a broken hi-beam and this new problem I have discovered. When stopped at a red light or stop sign the temperature gauge will rise from just under the red, into the red (and gets to middle of red if it's a long stop). After accelerating again, the bike will cool down from the wind... getting anywhere between the middle and just under the red line. I'm not sure why this is happening, but maybe one of you does! Maybe it's normal? I have no idea... but keep in mind I live in Arizona, and when I just noticed this problem it was 93 degrees F.
Let me know if there's anything I should check or fix in order to repair this problem! Thanks ![]() |
#2 |
If an EX-250 is idling above 1,300 to 1,500 RPM it'll get really hot at stoplights. What is your idle set at?
Is the bike dirty? More specifically, is the radiator really dirty? A dirty radiator doesn't transfer heat to the atmosphere nearly as well as a clean radiator. Have you looked into the coolant system? Does it need to be serviced, i.e. removed and replaced? Do you know whether it has ever been changed? You'd be surprised how some prior owners just completely ignore the regularly scheduled maintenance items. |
#3 | |
Ninjette Noob
Because the coolant was so low, I figure that will solve all of the problems, but it also means that nothing else was most likely maintained recently. Where do I go to check the oil? The light is on when I turn on the bikes power, but shuts off when the bike is running (is this normal?) I'll look up cleaning the radiator, I assume all of this maintenance can be done by the average guy if he has seen some instructions, correct? Just adjusted the idle, it was running at 1k so I changed it to around 1.5k |
#4 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
I suggest you completely flush the cooling system with a new coolant just to be on the safe side. As to checking the oil, there ought to be a viewing glass of the right side of the bike with two indentations(marks) to indicate the level of oil (at least that's how it is on the new gens). Check out oil level checking and changing procedures at the site you referred to in your previous post. Good luck, it might be a bit daunting at first, but working on one's bike is most rewarding and does wonders to your self-esteem (at least it does mine
#5 | |
Ninjette Noob
#6 |
Coolant:
http://faq.ninja250.org/wiki/How_do_...ling_system%3F As for cleaning, keep the spray out of parts that have grease in them like the wheel bearings, the unitrak linkage, and don't blast the electronics too much. Personally, I use diluted Simple Green, a sponge, and a towel. The bike comes out nice and clean and that way I can keep all the important parts dry. |
#7 | |
Super Noob
#8 |
Ninjette Noob
Is anyone able to talk with me on an IM or some sort while I flush the coolant, I need help while I go along :P
If so add Trent_rand@live.com to MSN messenger |
#9 |
Join Date: Jun 2011 Motorcycle(s): EX250, C10 Concours Posts: 109
radiator fan question
Does your fan come on when the temperature rises?
If not, does it come on when you short the fan switch in the radiator? If the fan runs when you short the switch, but not when it gets hot, you probably have a defective fan switch in the radiator If the fan doesn't come on when you short the switch, you probably have a defective fan or a wiring problem. |
#10 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
Even if you determine that you have a cooling fan issue, you need to flush that dirty coolant out of the engine.
Drain the coolant from the water pump & engine with the two bolts in the pictures below. These pictures are from a 2008, but I don't think any of this stuff changed with the new generation. Drain the radiator by removing the bottom hose from the radiator. After everything's drained, re-connect the bottom hose, replace the drain plugs and remove the top hose from the radiator. Refill the radiator with water, place a pan under the top hose, and start the bike. It may take a few minutes of running before any water starts coming out the top hose. (The thermostat takes a few minutes to open). Be careful....it's hot water coming out of that hose. I bought a brass nipple and a section of hose to connect to the top hose so I could run it directly into a drain pan. Less messy that way. Keep the radiator full of water while the engine runs. This is flushing all the dirty coolant out of the engine. You don't have to do it for very long, because the drain plugs you removed got most of it out. After the water coming out the top hose becomes clear, stop filling the radiator and wait for the coolant flow from the top hose to slow down. DO NOT ALLOW THE BIKE TO CONTINUE RUNNING AFTER THE FLOW STOPS. Re-connect the top hose to the radiator, and fill the radiator with your new coolant mixture. Start the bike and continue filling the radiator as the engine sucks in the coolant. When the level stops dropping, stop the engine, fill the radiator to the top of the neck, replace the cap, and fill the reservior to the proper level. Take it for a ride and keep your eye on the temp guage. Riding slowly through neighborhoods with lots of stop-and-go is the quickest way to get the engine hot. If it still overheats and the system is full of coolant, and the radiator fan runs, you likely have a thermostat problem. ![]() |
#11 |
Ninjette Noob
Overheating
So I noticed my 2006 Ninja 250r is getting into the red zone on the temperature gauge. I flushed the coolant system and replaced it with new coolant. Now, it still reaches the red and when I turn off the bike it sprays coolant (and steam/smoke) out of the radiator cap (or somewhere near it) What should I do to stop overheating, and stop hot coolant from spraying out every time I shut off the bike?
#12 |
Ms. Personality
Did you replace your radiator cap? If not, do so.
Posted via Mobile Device |
#13 |
Could be the cap but the thermostat is probably more likely to be the culprit.
09 250R SE: Paying it forward one post at a time! ![]() ![]() ![]() |
#14 |
could be a janky thermostat. you can try simply taking it out. you dont need it, it just helps warm the engine up faster.
also could be your water pump. might be stuck or a fin could be broken or something.
#15 |
Are you absolutely sure the steam is coming out of the radiator cap? If so, either the cap's seal is compromised, or you didn't screw it on all the way. If the system is overheated and venting pressure, it should be going into the reservior, not out the cap.
After sitting overnight, fill the radiator all the way to the top of the neck, and when you replace the cap, turn it to the right until it stops, then push down and keep turning until it stops again. Then fill the reservior to the appropriate level. If it overheats again, you have a bad thermostat or pump. |
#16 |
Ninjette Noob
Just to let everyone know, in case you have the same problem, I went and picked up a radiator cap from the local bike shop and it hasn't had overheating issues since.
#17 |
Ninjette Noob
Flushed coolant system, replaced with Peak 50/50, and bought a new radiator cap. No issues since!
#18 |
#19 |
/threads merged
OVERHEAT | heyzeus | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 7th, 2014 07:08 AM |
Totally and completely lost on overheat issue | surlistyc | 1986 - 2007 Ninja 250R Tech Talk | 43 | August 28th, 2012 08:06 AM |
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 07:50 AM |
Overheat!! | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 14 | March 28th, 2010 01:42 PM |
Have a lean issue with my bike, issue with coasting enricher. | twiggy2cents | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 24th, 2010 06:54 PM |
