April 27th, 2012, 10:26 AM | #1 |
Join Date: Apr 2012 Motorcycle(s): 2007 EX250F, 97 BMW k1100LT, 1982 BMW 100 Posts: 11
Gas tank overflow problem
I have a 2007 that I am restoring and trying to get back on the road. I took it out for the first time today and stopped to fill up. I fueled up to the beginning of the filler neck, as recommended in the manual, then noticed that fuel was dumping from the filler overflow tube. To make a long story short I had to pump out gas from the tank until it was about two inches down before the flow would stop. If I pull the filler cap to expose the filler drain and blow air into the drain tube at the back of the tank and block the upper drain I can hear air blowing into the tank. I can only assume that this is not a good thing!
I have the non California model with only one tube at the back of the tank. I fed a scrap piece of electrical wire down the upper drain through the tube until it came out the back. My guess is that the tube has a hole in it! Has anyone else dealt with this problem? Is there a fix short of a replacement tank? Thanks Rod |
April 27th, 2012, 01:24 PM | #2 | |
However, I would register the bike with Kawasaki. There are recalls out on the tanks that may include your bike. Nothing like a brand new tank to fix the problem.
April 28th, 2012, 03:04 PM | #3 |
I have a solution, I hope!
Thanks to BobA for pointing me in this direction. My bike is a low budget restoration, I have a total of $550 in it, including the cost of the bike, right now. A new tank is more than that.
I did search on the older thread and found some ideas. there. What I first did was get a 2' length of Number 8 trimmer gas line and slide it through the old tube. I tried some sealant first at top and bottom but I was unhappy with the results. After some fiddling and false starts I used a tube that I think came from a vacuum gauge, it is equivalent to the Number '8' size line but more rigid. I slid a 1 inch piece of 1/8" id fuel line over the end and forced it into the rear drain tube. I could get about 1/2 an inch in. My intent was to form a seal at the bottom which I think I have. I couldn't get that to work on the top so I then used the sealant at the top only to keep water out of the tank. It should drain through the new tube now. The 1/8" sized tubing would have been a perfect fit but I couldn't get more than an inch or two to feed through. I had visions of feeding it all the way through and essentially relining the tube, but it just wouldn't go. The Number 8 size fed through, loosely but required some creative sealing. I haven't refilled the tank yet, the sealant requires 6 hours to set up. I will report back. Thanks, Rod |
April 28th, 2012, 03:43 PM | #4 |
Hopefully that will work like you want. But what I meant to say before is that if the bike is on the recall list, then you can get a FREE brand new tank from Kawasaki. Its definitely something to look into.
April 28th, 2012, 04:13 PM | #5 |
A new tank would certainly be a good thing!
While I haven't talked to a dealer yet, I did do a web search. The only thing I found was a recall for slightly older models and not for my 2007, that had something to do with the main fairing mounting bolts being too long and punching through the tank side. There was nothing about this drain. I will contact a dealer and inquire, but I am not terribly optimistic. Thanks for the suggestion Rod |
April 28th, 2012, 06:13 PM | #6 |
I've heard about the fairing bolts before, but not about the drain. Mine is a 2006 and Kawasaki sent me a letter saying it was recalled. So 2006 is on the list. It won't hurt to register with Kawasaki.
Go here, put in your VIN and see what it says.
April 28th, 2012, 06:21 PM | #7 |
Out of Warrantee, no surprise there, and no outstanding recalls.
Thanks for the link Rod |
April 28th, 2012, 06:32 PM | #8 |
In that case, I'd be really tempted to just cork it off and be done with it. I don't think it actually vents the tank, but rather the lip around the outside of the filler tube beneath the lid. Its possible that its purpose is to keep water from collecting in that area and is actually a drain for that. If yours has a leak inside the tank, then its a good chance its been leaking water into your tank as well as letting gas out. If you cork it, I'd do both ends with RTV or something.
April 29th, 2012, 03:30 PM | #9 |
My fuel fill test sorta worked. I still have a slow fuel seep. I hadn't applied sealer to the lower end, thinking the two layers of tubing would seal. Apparently not! So I cleaned things up and removed the original outer layer of 1/8" tubing, forced sealant around the smaller tube and up into the original drain, then applied sealer to the inside of a new piece of 1/8" tube and pushed it all back together to cure. Of course making sure the bottom of the inner tube was still open. I'll see what happens tomorrow.
If that doesn't work I guess I will seal the drain off with a vacuum plug and keep it dry. It lives in a garage. Then I'll start slowly looking for a good tank. Thanks Rod |
April 30th, 2012, 01:22 PM | #10 |
Well sealing the bottom of the tube didn't work any better. I got a lawn mower fuel valve and stuck it in the drain hose under the seat. I found that the vacuum plugs weren't fuel proof. At least now I can use the bike.
That should do me until I find a better solution. Rod |
May 2nd, 2012, 02:41 PM | #11 |
Plugging just the bottom of the tube won't do it. Either by capillary action or venturi effect gas will be sucked UP through the drain and wash out of the fuel cap assembly and over the top of the tank. There may be some heat expansion there too. The path of least resistance is up the tube.
The guys that told me to plug both ends were correct! Now I know why! JB Weld plugs now in place at the top and bottom. Already did the VIN number check, no recalls apply to mine. My total cost for this repair attempt was about $10. Thanks for all of the advice. Rod |
May 2nd, 2012, 03:36 PM | #12 |
That sucks. Literally. Did the JB Weld fix it? Might be some way to force it into the tube a little bit for extra sealing. Just be sure to clean it with a non-residual cleaner of some kind. JB weld wont stick good to oil or gas.
May 3rd, 2012, 10:11 AM | #13 |
Test rode it today, no leaks now!
I read the directions on the JB Weld, imagine that, and it suggested cleaning with acetone. Then I pushed a fair sized glob into the tube with a small wood scrap. Rod |
May 3rd, 2012, 10:31 AM | #14 |
Ms. Personality
May 5th, 2012, 10:58 AM | #15 |
Seems to be working just fine.
Rod |
Fuel Overflow Problem | CWLESQ | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 26th, 2013 05:39 AM |
2010 Ninja 250r Gas Tank Problem | 2010ninjablue | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 26th, 2013 08:58 PM |
hoses on my gas tank and antifreeze overflow | J>A>V | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 11th, 2012 05:53 PM |
Weird Gas Tank Paint Problem | Scattcatt | General Motorcycling Discussion | 19 | May 21st, 2012 12:45 PM |
Gas Tank Petcock Problem? | jboyd12 | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 2nd, 2012 09:15 AM |
