Old October 15th, 2016, 12:27 AM   #1
Sonofswin
Old Guy, New Bike
Sonofswin's Avatar
Motorcycle(s): 2011 Blue Ninja 250R, Yamaha SRV250
BKMOTO BiXenon HID projectors Short
I installed the BKMOTO BiXenon HID projectors with angel eyes halos kit back in 2014. I have been very happy with them.
However, a couple weeks ago they stopped coming on. Since they both went out at the same time, I was thinking maybe a fuse went out. (They wouldn't come on using the high-beam switch either - ruling out a problem with the switch.)
After stripping off the fairings, I tested the connectors with another HID ballast and bulb and found that bypassing the BKMOTO control box I was getting power.
So, I took a look at the control box and found that the positive feed from the battery and one of the positive leads for the headlights had worked its way out and shorted.
I rigged a fix by trimming the main plug down and adapting a male plug to fit tightly over the post in the control box. I then re-did the wires that had come loose. (You can see that the small red & yellow wires are also loose, in the final picture.) The fix worked, but I consider it only temporary until I can get a replacement plug. I was glad the control box wasn't fried.
What I need to know now, is what you call that white plug so that I can search for it on the Net.
I have the control box zip-tied down and had the black rubber cover zip-tied as well since it seemed loose, so I'm not sure why this happened, but I went and zipped it all down again just to be sure.
(Nice upside-down pic!!)
Gaijinagain.com Mods: Tyga Stainless Exhaust, PC V, Auto-tune, Front/Rear Beet Hard Suspension Springs, Battlax S20-R's 110 front & 140 rear, BKMoto HID Projectors, Steel brake lines
Sonofswin is offline   Reply With Quote
Old October 27th, 2016, 01:45 PM   #2
Is it up and running?
Old October 27th, 2016, 04:12 PM   #3
Sonofswin
Old Guy, New Bike
Sonofswin's Avatar
Yeah, everything is working well. I do want to replace the plug. You wouldn't happen to know what it's called would you?
Old October 27th, 2016, 04:26 PM   #4
Maybe a large Molex style connector? I'm not entirely sure, you'll have to get creative on some electrical supply websites.
Old October 28th, 2016, 07:00 PM   #5
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
try looking for "8 pin xx.x mm single row female header"
where xx.x is the dimension in millimeter.
like chone said, creativity might be your friend...
broken neck is offline   Reply With Quote
HOW-TO: Install BKMOTO BiXenon HID projectors with angel eyes halos 2008+ Ninja 250R borka 2008 - 2012 Ninja 250R Farkles 66 March 3rd, 2015 09:46 AM
BKmoto Projectors Rekognize 2013 - 2017 Ninja 300 Farkles 10 January 15th, 2013 10:03 AM
HID projectors matchbox 00NissanNinja 2008 - 2012 Ninja 250R Farkles 17 July 26th, 2012 01:50 AM
HID projectors/halos for cheap? massacremasses 2008 - 2012 Ninja 250R Farkles 36 February 10th, 2012 07:54 PM
HID Projectors compared to HID Lights? or are the the same? Mr.E 2008 - 2012 Ninja 250R Tech Talk 22 September 19th, 2011 07:07 PM
