March 4th, 2011, 03:42 PM | #1 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250r 09 SE Posts: 172
heated grip - recommendation ?
Anyone is using heated grip ? any recommendation ?
i would like a model with low/high control on ebay its only on/off switch ... |
March 4th, 2011, 06:15 PM | #2 |
http://www.motorcyclegear.com/parts/...p_heaters.html
This is what I have. I love it. I have the one with the round black rocker switch. Works great and heats up fairly quickly. Instructions are easy but if you have the money, I would add in a relay system instead of tying into an existing circuit. |
March 4th, 2011, 09:50 PM | #3 |
Join Date: Nov 2008 Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold) Posts: A lot.
I have the same ones as Satasai, and love them. They heat up fast, low is good, and high is very hot, I barely ever use it (only on the 20 degree days, and just to heat them up fast, then I switch to low)
I have an auxillary fuse panel, so wiring them in on a separate circuit was very easy. Here is the DIY for the fuse panel. |
March 11th, 2011, 07:18 PM | #4 |
Join Date: Jan 2011 Motorcycle(s): (08 Ninja 250) (07 Suzuki Hayabusa) (08 Suzuki GSXR 1000) (Yamaha dirtbikes) Posts: 33
Oxford Heaterz are the best and last the longest. I have had both the touring and sport style grips. They are worth the money. My wife uses hers every day. I use mine often as well. Not sure what the prevous posters have because the link did not work for me but I recommend these 100%. One of the best and one of the first mods I do to any bike I buy is add heated grips. It makes a huge differance when riding year round in the north west.
http://www.twistedthrottle.com/trade/productview/5220 |
March 11th, 2011, 09:31 PM | #5 | |
http://www.motorcyclegear.com/browse...h?query=symtec If that link doesnt work then search for "symtec" and it should come up. They're not as expensive as Oxford and have worked flawlessly for me so far and I use them practically everyday as well. Although, If you prefer, I've heard positive things about Oxford as well so either one should serve their purpose. |
March 11th, 2011, 10:07 PM | #6 |
The obvious nice thing about the symtec grips is you use them under the grips and therefore can use any grip you want. They are limited by only two settings and some people complain that the direct contact to the bars rob the heat by transfering directly into the left handle bar causing uneven heating between the two grips. I have used them on my snowmobiles and they work ok. My complaint is that low is too cold and high it too hot so I find myself turning them on and off constantly. That is just my opinion and I know that many people use them and seem to be happy with them.
The oxfords are nice becuase the heating element is molded into the grip and they do not directly contact the bar so there is no uneven heat transfer. Also the oxfords have 4 settings so it is easy to find a happy temp for any given day. But, the downside of course is that you are stuck with that grip and the controller is larger than a toggle switch. That is not a problem for me and I find the grips comfortable and have actually used them on a trackday and was happy with the feel. The oxford grips last a long time. Just something to consider. They are both good products. |
March 12th, 2011, 06:21 PM | #7 |
Oh, I actually wrapped the clutch handlebar with electrical tape for insulation. Similar to tennis racket grips, I wrapped it at an angle so in the end it's about 2 layers. That helped insulate it fairly nicely.
Then to help the grip dissipate the heat more evenly, I wrapped the heating elements with aluminum tape that's usually used for duct work. It kinda acted like a heatsink and helped the heat spread around the grips evenly. I wasnt expecting this but the final benefit is I didnt need to use any grip glue because the aluminum tape held the elements and cables in place and the extra thickness kept the grip on pretty tight. |
November 4th, 2016, 11:42 AM | #8 | |
cadd cadd cadd
MOTM - May '15
Riding it like I financed it. |
