September 19th, 2012, 05:30 PM | #1 |
Join Date: Sep 2012 Motorcycle(s): 2002 ninja 250 Posts: 100
Maybe i got lucky
WELL I PURCHASE MY 2002 NINJA 250 AROUND THREE WEEKS AGO AND HAD IT BROUGHT TO ME ON A PICK-UP TRUCK. I PARKED IT FOR THREE DAYS THEN WHEN I WENT TO START IT WITH THE CHOKE ON IT RAN FINE BUT WHEN I CLOSED THE CHOKE IT WOULD STOP RUNNING OVER AND OVER. ON DAY TWO SAME THING ( I HOPE THE MAD FACE CAME OUT) SO ON DAY THREE I ADDED THIS THING CALLED """SEA FOAM""" (I HEARD FROM THIS FORUM SOMEWHERE) AND JUST DROVE THE BIKE (SHABBY AT FIRST) BUT AFTER A TANK(TWO DAYS OF DRIVING) IT STARTED TO RUN NORMAL-----GRRRRREAT, I DID HAVE TO MESS WITH A BLACK KNOB ON THE LEFT SIDE A LITTLE--THE POINT IS SEA FOAM MIGHT BE THE ANSWER WHEN YOU HAVE I BAD IDLE OR WITH NO CHOKE THE ENGINE SHUTS OFF
September 19th, 2012, 06:06 PM | #2 |
Join Date: Feb 2010 Motorcycle(s): 2009 Ninja 250 2016 Ninja 300 1994 KTM 300 EXC Posts: 123
Sounds like the carbs could be gummed up happened to my pregen when I had it. I also took my tank off and emptied it and cleaned it out. Sea foam helped but I would def get the carbs cleaned.
September 19th, 2012, 06:08 PM | #3 |
Jigglin' your Jiglets
MOTM - Apr '13
I THINK YOU YELLING AT THE BIKE SCARED IT INTO WORKING AGAIN
September 19th, 2012, 07:34 PM | #4 |
Join Date: Aug 2012 Motorcycle(s): 2013 White 300 Posts: 221
Maybe you could put some seafoam in your keyboard as well, i think your caps lock key is broken!
September 19th, 2012, 07:37 PM | #5 |
"scandal!"
September 19th, 2012, 07:49 PM | #6 |
Cool story bro!
September 20th, 2012, 01:05 AM | #7 |
September 20th, 2012, 01:07 AM | #8 |
MOTM - Apr '13
Do you deal a lot on craigslist?
September 20th, 2012, 01:55 AM | #9 |
Join Date: Jun 2012 Motorcycle(s): 09 ninja 250r Posts: 191
I can tell you are from allcap city.
oh and um, did you just add the seaform into the gas tank?
"trust me, I am not a lawyer." |
September 20th, 2012, 04:50 AM | #10 |
September 20th, 2012, 05:29 AM | #11 |
Oh ok.
I am gonna try putting seaform in first tmr..if it doesn't work then rock it is.
September 20th, 2012, 07:17 AM | #12 |
September 20th, 2012, 07:18 AM | #13 |
September 20th, 2012, 08:45 AM | #14 |
Join Date: Sep 2012 Motorcycle(s): 2010 Kawasaki Ninja 250R SE Posts: 38
Glad you got it working right. Thanks for telling us about this.
September 20th, 2012, 09:38 AM | #15 |
time is running out....
Join Date: Sep 2012 Motorcycle(s): pregen ninjari Posts: 412
mine does the same kinda. when its warm just leave the choke adjust just right to keep the rpms up...but if it has to stay at like 3-4k rpms to stay alive. carb work is needed.
The King |
September 20th, 2012, 11:35 AM | #16 |
September 20th, 2012, 12:15 PM | #17 |
MOTM - Apr '13
Hey you fixed your caps lock! Nice job
September 20th, 2012, 12:49 PM | #18 |
Very, Very, Very, Lucky Biker | akima | Videos | 5 | September 13th, 2013 02:48 PM |
[superbikeplanet.com] - Marquez: Lucky, Lucky Boy | Ninjette Newsbot | Motorcycling News | 0 | June 4th, 2013 10:00 AM |
Lucky Girl | akima | Videos | 14 | September 20th, 2012 01:26 PM |
lucky mother | alex.s | Videos | 8 | July 10th, 2012 06:16 PM |
Flaming lucky | Kevin2109 | Videos | 8 | September 9th, 2011 07:21 AM |
