February 14th, 2012, 09:44 PM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2002 ninja 250 Posts: 96
pregen ninja 250 stage 1-3 jet kit
jet kit for 88-07 ninja 250. stage 1-3 for aftermarket exhaust and or air intake.
$50 |
February 15th, 2012, 12:04 AM | #2 |
just to be clear, this is what is in the kit:
2 main jets 112.5 2 main jets 117.5 2 pilot jets 42-y 4 needle shims (for adjusting the stock needles. new needles are not needed) 2 nylon spacers 1 slide drill bit 1 plug drill bit 1 removal screw |
February 16th, 2012, 05:32 PM | #3 |
have the same kit. A must have if your running exhaust and k&n pod filter.
February 16th, 2012, 09:05 PM | #4 |
February 16th, 2012, 10:12 PM | #5 |
I have the discontinued 2-1 Yoshi exhaust. and K&N Filter Pod.
I live on the gulfcoast (sea level) so air is slightly more dense. I think it was 117.5. The instructions comes with a okay tuning guide. But online has in-depth carb tuning guide. You just gotta find the ones right for you with a-little riding and tuning. Just make sure to have your valves adjusted and carb sync for maximum performance! |
What stage jet kit? | Image5050 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 22nd, 2012 05:45 PM |
Dyno Jet Kit stage 2 08 and up | Shaol1n Monk | Motorcycle-related | 2 | February 2nd, 2012 10:56 PM |
Factory Pro Stage 1 Jet kit | pilotgeorge747 | Motorcycle-related | 6 | January 6th, 2012 12:39 PM |
Need help with jet kit stage | carlos | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 28th, 2011 10:16 PM |
FEELER: Dynojet stage 2 jet kit | 00v_Lucky | Motorcycle-related | 3 | July 13th, 2010 12:44 PM |
