June 17th, 2009, 05:23 AM | #1 |
Join Date: Apr 2009 Motorcycle(s): 08 black 250r (sold); '09 black zx6r Posts: 903
choke lever
I don't know if this is normal or not but on my bike I either use no choke or full choke. There's no in between. If I start to pull the choke lever slowly to full I didn't see any difference until the lever is at the full position.
Is this normal? How do I fix this? It was cold this morning. So I started the bike at full choke. It was reving at 7 rpm. I was trying to adjust it to 2-3 but at soon as I pull the lever down the rpm dropped down to 1-2 rpm like when the choke is fully off although the choke is only half way down. Thanks, Tin |
June 17th, 2009, 05:51 AM | #2 |
my seems to be open or closed as well, no in between. If yours is reving at 7000 rpm then there could be an adjusment that needs to be made.
June 17th, 2009, 05:51 AM | #3 |
It sounds like the choke cable needs to be adjusted. This is covered in the service manual and may be discussed in the owner's manual. The same thing happened on my bike. I discovered the problem when I did the 600 mile service and readjusted the choke cable.
July 28th, 2011, 12:26 PM | #4 |
Love Rival
Join Date: Jun 2010 Motorcycle(s): 2008 Ninja 250r Posts: 449
Did anyone try adjusting their choke cable to correct this issue? I have the same problem and would interested in learning if the adjustment worked and how involved the process was...IIRC I read somewhere that you need to get under the tank to make adjustments.
“Comparison is the thief of joy.” -Dwight Edwards |
July 28th, 2011, 06:39 PM | #5 |
Check the choke cable free play.
Choke Cable Free Play Standard: 2 ~ 3 mm (0.08 ~ 0.12 in.) |
August 1st, 2011, 07:22 AM | #6 |
Love Rival
Thanks!
August 1st, 2011, 06:11 PM | #7 |
Join Date: Jul 2011 Motorcycle(s): 2009 Kawasaki Ninja 250R Red Posts: 316
I hate having to use choke. My next bike will definitely by FI
My YouTube Channel |
Replacing a broken choke lever | nrninja | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 17th, 2012 05:02 AM |
Replacing a broken choke lever | Trailerboy531 | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 10th, 2012 11:45 AM |
choke lever | ninja_thresh_hold | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 29th, 2012 02:26 PM |
Ebay lever broke my clutch lever mounting bolt! | pilotgeorge747 | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 22nd, 2011 07:22 AM |
Choke lever replacement | shadowskater | 2008 - 2012 Ninja 250R Tech Talk | 4 | July 20th, 2010 05:53 AM |
