July 31st, 2014, 06:25 AM | #1 |
Join Date: Feb 2013 Motorcycle(s): Frankenstein Posts: 49
Loud knocking at idle
Just picked up a cheap bike as a source of spares, fired it up today to find a loud knocking noise coming from the motor at tickover. It's a deep/low pitched noise so not the sort of noise I'd associate with top end problems, it's so bad that each knock vibrates the frame.
But twist the throttle a little and the knocking stops instantly and the bike sounds smooth as the day it was made. Am I looking at a shot big end/crank bearing? |
July 31st, 2014, 07:05 AM | #2 | |
Ninjas make odd sounds when cold at idle. Does it do the same when warm and the idle is at the correct 1300 RPMs? Oil level and condition look OK? |
July 31st, 2014, 02:36 PM | #3 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Does it still do it at idle in gear?
Does the oil light go out in a reasonable time after starting?
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. |
July 31st, 2014, 02:52 PM | #4 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
Sounds like clutch clonking from an uneven idle. It is surprisingly loud and sounds just like big ends but it isn't so don't worry.
Does it diminish when you pull the clutch in? That's a good test. |
August 2nd, 2014, 03:28 AM | #5 |
Thanks for the info/suggestions. will post again when I've had a chance to fire it up again (in the middle of moving the shed contents around to make room for it)
Idle issues - Idle is different every time I start up. | 106 | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 13th, 2014 04:57 PM |
What's this knocking sound? | Seattle_Chris | 2008 - 2012 Ninja 250R Tech Talk | 20 | May 13th, 2013 01:39 PM |
Loud clacking sound coming out of my engine when I'm idle. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 110 | July 19th, 2012 09:24 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
Engine knocking? | hoodadooda | 2008 - 2012 Ninja 250R Tech Talk | 12 | January 20th, 2012 01:35 PM |
