#1 |
Join Date: Oct 2009 Motorcycle(s): 2003 Ninja 250 Posts: 17
small hole in vacuum piston which way do they point?
I was checking the vacuum pistons for cracks and noticed that each one has another small hole on each one at the bottom by the jet needle hole. Does the second hole go closer to the butterfly or closer to the intake side?
I was looking at the manual and it says nothing about what side the hole goes too. thanks for any help. Jonathan |
#2 |
the slides can only be installed into the carb in one direction. try it... they are not symmetrical.
#3 |
once again you are the bomb kkim. I got my new jets in yesterday and had the carbs apart to make sure everything is clean and clear. I will update my previous post about hanging idle when i complete the cleaning and adjustment.
Jonathan aka- fixture |
#4 |
cool... looking forward to good news.
#5 |
Slide lift hole goes downstream of the needle in each carb.
vacuum point - installing scottoiler | BikersPOV | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 21st, 2014 03:13 PM |
FREE right side clutch cover (with only 1 small hole in it)! | PartsNinja | Free stuff! | 3 | September 13th, 2013 12:20 PM |
[motorcyclenews.com - news] - Small bikes for a small budget | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 09:40 AM |
Blew a Hole in Muh Piston! | csmutty | 1986 - 2007 Ninja 250R Tech Talk | 19 | July 8th, 2012 08:57 PM |
[nytimes.com] - For Motorbike Dealer, There Are No Small Parts, Only Small Plans | Ninjette Newsbot | Motorcycling News | 0 | November 12th, 2008 11:58 PM |
