Old July 10th, 2009, 09:37 PM   #1
minuslars
Motorcycle(s): '03 EX250
Oil Pressure Indicator Question
As you all know, the oil indicator light briefly lights up after starting the engine. When I bought my ninjette from the previous owner, it would turn off within 1 or 2 seconds after a cold start. I'm not sure what oil was in there, but it was fully synthetic. I've changed the oil to Mobil 10w-40 synthetic and switched out the oil filter as well to a Fram CH6012 (or whatever it is that's compatible with the ninja 250). On cold start now, the oil pressure light will stay on for several seconds, sometimes as long as 6-7 seconds after starting. Is this a problem? Any idea why there might be the difference (i.e. weight of oil, characteristics of filter brand, something I did wrong during oil change, etc)
Anybody else have something comparable?
minuslars is offline   Reply With Quote
Old July 10th, 2009, 09:39 PM   #2
did you set the oil level correctly in the sight glass?
Old July 10th, 2009, 10:06 PM   #3
Purspeed
Purspeed's Avatar
The reason why that is happening is because of the oil fill level. The prior oil fill level was such that it filled the fuel filter nice and good.
Now, it's taking a bit longer because you have less oil in there. It has nothing to do with oil type or viscosity.
If you want, you can add some oil to the upper line (not past that line) and that will fix your delay.
At the same time, while the light is on, DO NOT rev your engine.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008)
Purspeed is offline   Reply With Quote
Old July 11th, 2009, 07:42 AM   #4
Snake
Snake's Avatar
This is normal. This always happens to me when I change the filter and oil. The oil filter itself probably holds at least 8 Oz. of oil.
Old July 11th, 2009, 10:22 AM   #5
Purspeed
Purspeed's Avatar
This is why it's good practice to fill the oil, then run the engine. Wait. Then check the level and top off. But, keep the oil level BELOW the top line.
This will ensure a complete fill and quick pressurization of the oil...or, in other words, the red light will turn off quick.
Old July 12th, 2009, 08:31 PM   #6
minuslars
Interestingly, I actually put MORE oil in there than was in there previously. While doing the oil change, I did put approx 1.5 L in, started the engine for a few seconds to pull oil into the filter, and then topped it off to about 1.8 L total (judging by the graduations on the oil cans. When I check the sight glass, the oil level is juuuussst below the top line (I check with both wheels on the ground and the bike level / perpendicular to the ground).
Well, it's strange but I suppose as long as it's not doing any damage it's no biggie?
Old July 17th, 2009, 10:41 AM   #7
bobaab
bobaab's Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250
As long as it's disappearing and NOT coming back while you are riding, you should be fine.
bobaab is offline   Reply With Quote
oil pressure light contact148 2008 - 2012 Ninja 250R Tech Talk 28 June 21st, 2018 06:54 AM
[motorcycle.com] - RightPSI Tire Pressure Indicator to Begin Kickstarter Fundraising Ninjette Newsbot Motorcycling News 0 February 6th, 2014 05:20 PM
Oil pressure light question... Iffita 1986 - 2007 Ninja 250R Tech Talk 3 October 9th, 2012 07:44 PM
Tire Pressure Question headshrink 2008 - 2012 Ninja 250R Tech Talk 28 September 19th, 2012 07:50 PM
Oil pressure switch randomwalk101 2008 - 2012 Ninja 250R Tech Talk 13 February 23rd, 2011 06:58 PM
