March 8th, 2016, 01:10 PM | #1 |
[motorcycle.com] - 2016 Triumph Thruxton, Thruxton R Specs Released
Triumph has released full specifications for the 2016 Thruxton and Thruxton R to coincide with the new models’ press launch. Tom Roderick’s first ride review will be up later this week but let’s take a look at the numbers. Both versions of the new Thruxton share the same 1200cc parallel-Twin engine. As with the rest of Triumph’s 2016 classic models, the engine uses a 270° crank instead of the 360° crankshaft used in the previous models. The engine boasts the same bore and stroke as the one powering the Bonneville T120 but has a higher compression ratio. Triumph says the Thruxton received a “high power” tuning, claiming 96 hp at 6750 rpm, or about 21.5% more power than the new Bonneville. Claiming 82.6 lb-ft., the Thruxton also gets a bit more torque than the T120, but the Bonneville and its “high torque” tuning reaches its peak at a lower engine speed. The base model comes with Kayaba suspension while the R model gets upgraded to fully adjustable Öhlins twin rear shocks and Showa fork, though it also loses the classic-looking fork gaiters to show off the gold-colored fully-adjustable fork. The Thruxton R also gets Brembo monobloc front brake calipers instead of Nissins, but both versions come standard with ABS. The R version also gets a tank strap, seat cowl and a brushed stainless steel exhaust instead of the chrome finish on the base model’s exhaust. Pirelli supplies the tires for both Thruxton models; the base model receives Pirelli’s Angel GT tires while the up-spec R model comes with Diablo Rosso Corsas. The 2016 Triumph Thruxton will be offered in Jet Black, Pure White with a black tank stripe or Competition Green with a metallic gold tank stripe. The Thruxton R also gets three color options: Diablo Red, Silver Ice and Matte Black. Check back here on MO later this week for Tom’s first ride review. 2016 Triumph Thruxton and Thruxton R Specifications2016 Triumph Thruxton2016 Triumph Thruxton RTypeLiquid-cooled, 8 valve, SOHC, 270° crank angle parallel-TwinCapacity1200ccBore/Stroke97.6 x 80 mmCompression Ratio11.0:1Maximum Power96 hp @ 6750 rpm (claimed)Maximum Torque82.6 lb-ft. @ 4950 rpm (claimed)Fuel systemMultipoint sequential electronic fuel injectionExhaustChromed 2 into 2 exhaust system with twin chrome silencersBrushed stainless steel 2 into 2 exhaust system with twin silencersFinal driveX ring chainClutchWet, multi-plate assist clutchGearbox6-speedFuel Economy4.6 l/100km / 61 MPG (claimed)EmissionsEURO 4 Compliant, CO2 – 106.0 g/kmFrameTubular steel cradleSwingarmTwin-sided, aluminumTwin-sided, aluminum – Clear anodizedFront Wheel32-spoke 17 x 3.5inRear Wheel32-spoke 17 x 5inFront Tire120/70 ZR17 – Pirelli Angel GT120/70 ZR17 – Pirelli Diablo Rosso CorsaRear Tire160/60 ZR17 – Pirelli Angel GT160/60 ZR17 – Pirelli Diablo Rosso CorsaFront SuspensionKayaba 41mm cartridge forks, 120mm travelShowa 43mm USD big piston forks, fully adjustable, 120mm travelRear SuspensionKayaba twin shocks with adjustable preload, 120mm rear wheel travelFully adjustable Öhlins twin shocks with piggy back reservoir, 120mm rear wheel travelFront BrakeTwin 310mm discs, Nissin 2-piston axial floating calipers, ABSBrembo twin 310mm floating discs, Brembo 4-piston radial monobloc calipers, ABSRear BrakeSingle 220mm disc, Nissin 2-piston axial floating caliper, ABSLength2105 mm (82.9 inches)Width745 mm (29.3 inches)Height1030 mm (40.6 inches), without mirrorsSeat Height805 mm (31.7 inches)810 mm (31.9 inches)Wheelbase1415 mm (55.7 inches)Rake22.7º22.8ºTrail90.8 mm (3.57 inches)92 mm (3.62 inches)Dry Weight454 lb. (claimed)448 lb. (claimed)Fuel Capacity3.8 Gal.Standard EquipmentSwitchable ABS Switchable Traction Control Ride-by-Wire Riding Modes LED DRL headlight Monza cap USB socket Immobilizer LED rear lightSwitchable ABS Switchable Traction Control Ride-by-Wire Riding Modes LED DRL headlight Monza cap USB socket Immobilizer LED rear light Tank strap Seat Cowl2016 Triumph Thruxton, Thruxton R Specs Released appeared first on Motorcycle.com News. Click here for full story...
[sportrider - features] - 2016 Triumph Thruxton and Thruxton R First Look | Ninjette Newsbot | Motorcycling News | 0 | October 29th, 2015 02:30 PM |
[faster and faster] - 2016 Triumph Thruxton R rocks our world | Ninjette Newsbot | Motorcycling News | 0 | October 29th, 2015 10:00 AM |
[motorcycle.com] - 2016 Triumph Thruxton and Thruxton R | Ninjette Newsbot | Motorcycling News | 0 | October 27th, 2015 06:40 PM |
[motorcycle.com] - 2014 Triumph Bonneville, Bonnevile T100, Thruxton and Scrambler Re | Ninjette Newsbot | Motorcycling News | 0 | August 22nd, 2013 04:30 PM |
[motorcycle.com] - Triumph introduces 2010 Thruxton SE | Ninjette Newsbot | Motorcycling News | 0 | December 16th, 2009 08:00 PM |
