Old December 28th, 2011, 05:14 PM   #1
NDspd
1/4 English, 3/4 Kick Ass
NDspd's Avatar
Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold)
Bridgestone Tires
I went to a superstore to look at gear and other things for my ninjette and I fell upon tires. I was looking at the various brands, models and sizes. This probably has been a repeat thread, but some new tires have come up. I was looking at the Bridgestone BT-023's. I want the 110/70/17 for the front, which they have. But, would the 150/70/17's fit on the rear? Any experience with Bridgestones that would work as good as the BT-023's or at least similar? Or...are there other Tire brands that are similar to the BT-023?
Thanks for the help guys.
NDspd is offline   Reply With Quote
Old December 28th, 2011, 06:50 PM   #2
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
I think for the Bt-016 people use a 150/60/17 but I am not sure how the difference between 60 and 70 effects it.
RR stands for Responsible Riding... Right?
kingkang204 is offline   Reply With Quote
Old December 28th, 2011, 07:17 PM   #3
Going with a taller tire makes a noticeable difference. When I went from an 80 height tire to a 90 height tire, I noticed that my bike didn't pull quite as hard. Now that I need a new chain, I'm going +2 on the back sprocket while I'm at it to get back to the same final drive as stock. Maybe it's not a HUGE difference, but it's definitely noticeable.
Old December 28th, 2011, 08:21 PM   #4
NDspd
NDspd's Avatar
Really the only things I want to change is the compound, longevity, wet and dry performance, etc. It's the height and thickness I don't want to mess with, just the width really. Any thoughts on the 150 BT-023's?
Old December 28th, 2011, 08:48 PM   #5
94fiveohvert
Motorcycle(s): ninja 250r, crf 50
I have the bt-090r's and love them. my rear is a 140 though fits great.
94fiveohvert is offline   Reply With Quote
Old December 28th, 2011, 08:50 PM   #6
I'm gonna have to defer you to someone who's used those specific tires, seeing as I have a pre-gen and run 130/90-16's
but just for reference,
stock size on the rear of your bike is 130/70-17
130 x .7 = 91 mm
150 x .7 = 105 mm
150 x .6 = 90 mm
140 x .7 = 98 mm
140 x .6 = 84 mm
Bridgestone also makes the BT-92 that looks to be in sizes that are recommended for rim sizes closer to the rim size of the 250R. There is a 140/70-16 and 140/60-17 size rear tire, and a 110/70-17 for the front
*edit*
a little research shows that the BT-090, BT-003R, and the BT-45 all also come in the 140/17-17 size (BT-45 also comes in the stock size and I really like the BT-45 rear, but I've had some issues with the front scalloping)
*/eift*
Old December 29th, 2011, 06:35 AM   #7
NDspd
NDspd's Avatar
I'd love the BT-92 but, I can't find them anywhere online. I can do the BT-023's for the front, but it's the rear as a 150 that I'm concerned with. Is it too large?
If I can get the BT-92's that's great, they seem to me to be a lower end version of the 023's.
Old December 29th, 2011, 07:22 AM   #8
DaBlue1
DaBlue1's Avatar
The BT-023 is a good Sport Touring tire designed for heavier bikes. Has a dual compound (soft outsides for better grip and harder in the middle for longer wear life). So with the lightweight Ninja it should be a good blend of performance and longevity. However the BT-023 does not come in a 150/60/17 which would be a good fit for what you are looking for. The closest BT-023 comes to fitting on the Ninja is a 150/70/17 which will look like a balloon on the bike and pinched on the rim. Rec. rim width for it is a 4.50 in.
If you are looking at putting on a 150/60/17, take a look at Continental Conti Sport Attack, Michelin Pilot Power, as well as the Bridgestone Battlax BT-016. Others have used them before. The search and wiki is full of info on tires.
http://www.ninjette.org/wiki/New_gen_tire_options
Old December 29th, 2011, 11:18 AM   #9
NDspd
NDspd's Avatar
Yeah you all make a good point. I went to a couple dealers today and I think I found my next tires. I'm looking at the Pirelli Sport demons or the Diablo Rosso II's, both now finally come in our sizes and are exactly what I'm looking for.
Bridgestone S20 Tires menikmati 2008 - 2012 Ninja 250R Tech Talk 54 March 28th, 2015 04:14 PM
F/S: Any Bridgestone Tires Nemesis Motorcycle-related 1 June 7th, 2013 07:04 AM
TIRES Bridgestone Vs Pirelli xxjarrodxx 2008 - 2012 Ninja 250R Tech Talk 3 December 27th, 2012 09:26 PM
Tires / Bridgestone BT-45 Wear? indr 2008 - 2012 Ninja 250R Tech Talk 8 February 14th, 2011 06:16 PM
best place to buy Bridgestone BT-45 tires? shift_6 2008 - 2012 Ninja 250R Tech Talk 2 June 2nd, 2010 10:50 AM
