March 1st, 2021, 08:20 PM | #1 |
[motorcycle.com] - Lithium Battery Buyer’s Guide
For ages, we didn’t think much about the batteries in our motorcycles. When you only have one option, the traditional lead-acid battery, there’s not a lot to think about. As long as it cranks the starter over and fires up the bike, you’re good. If not, time to shell out for a new one. But like all components on a motorcycle, eventually, new technology emerges to improve the breed. The battery is no different. With the emergence of lithium batteries the consumer now has more options.
To the average consumer, a battery is a battery. What separates one from the other? For starters, the internal chemistry is very different between the two, but for the purposes of this guide, we’ll stick to the practical differences. Generally speaking, lithium’s biggest advantage is its drastically reduced weight and physically smaller size compared to lead-acid. Lithium also has a significantly lower discharge rate – the amount of charge lost simply sitting – compared to lead-acid, faster recharge rate, more cranking amps (compared to a similar lead-acid application), and safer handling due to its internal chemistry not featuring lead and, yes, you guessed it… acid. The tradeoff, of course, is a significantly higher price tag. Despite this, there’s nothing wrong with lead-acid batteries, and if you’re looking for the lightest hit on your wallet to power your motorcycle, then by all means. However, if you’re looking for a performance edge and value slicing weight wherever possible, then read on as we highlight different companies in the lithium battery game. Table of Contents Antigravity <img class='vs-product-image' src=https://www.motorcycle.com/blog/wp-content/uploads/2019/01/013119-lithium-ion-batteries-guide-antigravity-8-cell.jpg> Antigravity has become one of the most recognized names in the lithium battery world, as it has products in a wide array of industries, not just powersports. Built in the USA, Antigravity batteries feature an all-brass terminal design, can be installed in any orientation, and in the case of the AG-801 seen here, weighs only 1.5 pounds. Antigravity says its batteries can hold a charge for up to one year, provided there is no parasitic draw while the bike is off (alarms, GPS, heated grips, etc.). Because the batteries are physically smaller than comparable lead-acid types, Antigravity batteries come with adhesive-backed foam strips to fill in the gap in your battery box. The AG-801 is rated at 240 cranking amps and 9 Ah, but there are several different varieties to choose from for your specific application. Shop Now BikeMaster <img class='vs-product-image' src=https://www.motorcycle.com/blog/wp-content/uploads/2019/01/013119-lithium-ion-batteries-guide-bikemaster.jpg> You might know BikeMaster for the numerous parts, tools, and accessories it sells. Included among those is its own private label line of batteries, including lithium varieties. Backed by a two-year warranty, BikeMaster backs what I said in the intro paragraphs, claiming its batteries weigh a third of the weight of conventional batteries but still have enough power to crank even the most stubborn V-Twins. These batteries utilize cylindrical cells (as opposed to plates in other batteries) and, in the case of the DLFP-5L-BS seen here, vital stats are as follows: Voltage: 12 Capacity: 3Ah Dimensions: 114Lx70Wx105H Height With Terminals: 105 Battery Weight: 1.5 pounds Normal Amps: 1.5 Max Amps: 6 CCA (-18c ): 90 Search the BikeMaster site for the appropriate battery for your application. Shop Now Bosch <img class='vs-product-image' src=https://www.motorcycle.com/blog/wp-content/uploads/2019/01/013119-lithium-ion-batteries-guide-bosch-blp5s.png> If there’s an electrical component on your motorcycle, chances are Bosch had something to do with it. So it only seems right that Bosch also has its own line of lithium-ion batteries. Like the other batteries here, its lithium chemistry means there are no poisonous lead or acid components. The battery lid on the Bosch batteries features a voltage tester and Battery Management System, the latter balancing the voltage level among the cells when charging or discharging. The voltage tester works in conjunction with the charge-status display to tell you how healthy (or unhealthy) your battery is. Shop Now Full Spectrum Power <img class='vs-product-image' src=https://www.motorcycle.com/blog/wp-content/uploads/2019/01/013119-lithium-ion-batteries-guide-full-spectrum-pulse-p10.jpg> The big talking point surrounding the Pulse IPT battery is the IPT Reset feature. Basically, if you somehow leave something on while the bike is turned off – like your lights or heated grips, for example, the battery’s internal circuitry can recognize the parasitic drain and will initiate a power cut off before it’s drained below 12 volts. This way the battery still has enough power to start your motorcycle again. In essence, this eliminates the need for a jump start and means you won’t be stranded. Pulse IPT batteries come in all shapes and sizes to fit several different applications, and all have the following features (from the Full Spectrum Power website): * IPT Battery Management System (BMS) – Every Pulse IPT battery comes with an integrated BMS which controls the function and behavior of the battery. This means better performance, longer life, and emergency start capability. * IPT Reset – Intelligent Pulse Technology does two things: 1. Leave the key in the “on” position for a few months? Press the IPT Reset button, and you will be able to start your bike. You will need to recharge your battery by either riding the bike, or putting it on a charger- but there will be enough power to start your bike once. 2. It will prevent the battery from being drained, and damaged beyond repair. Lithium batteries can be damaged beyond repair if they are drained below 12 volts. The IPT will prevent this from happening. * Universal Charger Capability – Most commercially available battery chargers work with the Pulse IPT batteries. *Advanced Case Design- Lighter and stronger than our previous case, it rejects heat, vibration, gas and oil. *Advanced Cell Design- We designed the Pulse IPT cells to cope with the demands of motorsports. Every component of our cells were designed and optimized for motorsports, based on a decade of experience building engine start batteries. These are only available from Full Spectrum Power. * V Direct Multi Terminal – Our solid copper terminals have 4 threaded mount holes. Attach your accessory wires without having to use long screws on one small terminal. * V Sleeve Silicon Terminal Covers – Color coded for polarity, our silicon terminal covers protect against short circuits. Shop Now Shorai <img class='vs-product-image' src=https://www.motorcycle.com/blog/wp-content/uploads/2019/01/013119-lithium-ion-batteries-guide-shorai-lfx07l2-bs12.jpg> Shorai has been in the motorcycle battery business since 2010. In that time the company has gone from relatively obscure, to a major player in the battery biz. In fact, our own John Burns, and former E-i-C Kevin Duke, put one in their own Yamaha R1 and Ducati 900SS, respectively, and had mostly nice things to say. Like nearly all the batteries here, Shorai has a complete line to fit whatever motorcycle is in your garage. Using the $99.95 LFX07 shown here as an example, it measures 4.45in. x 2.28in. x 3.50in, weighs 0.97lbs., and provides 102 cold-cranking amps. Shop Now Western Power Sports <img class='vs-product-image' src=https://www.motorcycle.com/blog/wp-content/uploads/2019/01/013119-lithium-ion-batteries-guide-western-power-sports.jpg> Western Power Sports is better known as a distributor for many of the powersports products we know and love, but did you know the company also has a line of private label lithium batteries, too? As you can see in the image above, the batteries are called Featherweight, and with a name like that it better deliver. WPS says its 6.2 in. x 2.8 in. x 4.6 in. battery comes in at 1.7 lb. But what makes the WPS battery different from the rest is its on-board LED test gauge that will indicate the battery’s charge at the push of a button. It’s not quite as helpful as, say, the Pulse IPT battery that will leave enough juice for you to start your motorcycle, but it’s still a nice feature. Shop Now We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works. The post Lithium Battery Buyer’s Guide appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - Battery Charger Buyer’s Guide | Ninjette Newsbot | Motorcycling News | 0 | January 21st, 2021 10:41 AM |
[motorcycle.com] - Lithium Battery Buyers Guide | Ninjette Newsbot | Motorcycling News | 0 | January 31st, 2019 06:16 PM |
[motorcycle.com] - Battery Charger Buyer’s Guide | Ninjette Newsbot | Motorcycling News | 0 | December 14th, 2018 05:54 AM |
[motorcycle.com] - MO Tested: Shorai LFX Lithium-Iron Battery Update | Ninjette Newsbot | Motorcycling News | 0 | November 4th, 2015 06:20 PM |
