July 11th, 2016, 06:37 PM | #1 |
Join Date: Jul 2016 Motorcycle(s): 09 ninja 250R Posts: 9
Gear lever fell off, (questions/concerns) help please
Hey guys,
So I was on the highway today and as I get off and attempt to downshift I notice my gear lever is missing, confirming that it was still hanging attached to the pivoting arm I realize it's the bolt holding the clutch lever in place that I had lost someeheres. I have jimmied another gear lever bolt together with an 8 mm bolt some washers and electrical tape to be snug fitting within the gear lever hole that isn't the hole with the threading. I ended up having to get it going in 5th gear from a standstill 3 times before I finally put it into first manually and drove it the rest of the way home. It sounds like it's making a bit of a rougher sound now from 3rd gear onward which sortof scares me.. it's not the transmission going is it..? The bike only has 10k kms on it and wasn't drive hard at all by the previous two owners. Does anyone know what the noise would be or why it's soundimg like that now? Im not driving it at the moment because of that noise. Can someone please help me..? |
July 12th, 2016, 05:43 AM | #2 |
Join Date: Jul 2016 Motorcycle(s): 2016 Honda fury Posts: 6
Ok I just have to know how hard was it to get that bike moving in high gear from a stand still?
July 12th, 2016, 07:18 AM | #3 |
I guess I would get the shifter adjusted and tightened down properly then put the bike up on a rear stand so you can put it in gear and listen to the transmission.
Having the shifter fall off shouldn't have done any damage to the transmission though. Check the splines on the shifter shaft on the engine and the shifter. Also check the threads on the shifter to make sure they are not stripped. Starting in 5th gear would be hard on the clutch, but not necessarily the transmission. |
July 12th, 2016, 08:24 AM | #4 |
It actually wasn't that bad at all compared to say starting say in third.. Lol bike didn't even stall once and she just took a bit to get up to speed once I had finally released the clutch but it did sputter a couple of times once the clutch was out.
July 12th, 2016, 08:36 AM | #5 |
MOTM - Sep '14
Have you replaced the Jury-rig bolt with the OEM yet?
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
July 12th, 2016, 08:39 AM | #6 | |
July 12th, 2016, 08:43 AM | #7 |
No I haven't, are you thinking that could be the noise? I had taken the bolt out again last night and ended up putting some lithium grease on the electrical tape to have a bit of lube for the gear shifter. It seemed like the pedal last time had a bit of wiggle room but this time none with the grease and I don't believe I'm hearing the sound anymore now:s
July 12th, 2016, 08:45 AM | #8 |
You bet.
Sounds like it's all good then. Maybe keep an eye on the pinch-bolt on the shifter. If it wants to loosen you could add some blue loctite n the threads or a star washer under the head of the bolt to secure it. Not sure how familiar you are with the Ninjas, but keep and eye on the oil level. They do lose some oil into the airbox, especially when running at high revs in hot weather. Running the level low can make shifting rougher, as can running the wrong oil or just running the oil too long. |
July 12th, 2016, 09:02 AM | #9 |
Let's hope so, but definitel what I'm gonna do till I get an OEM one for it again. Not sure if I have any locktite on hand but if it ends up loosening Il put some on forsure.y yeah I'm still learning as I go but the oil did come to mind too last night so I did check the gauge. Put the like level not on the kickstand and the oil seemed pretty close to full but it's really dark almost black so thinking it's time for an oil change.
gear/downshifting questions | syoo | Riding Skills | 25 | May 26th, 2014 11:26 AM |
My shift lever fell! | LR1914 | 2008 - 2012 Ninja 250R Tech Talk | 14 | October 2nd, 2013 09:31 AM |
Gear questions | dwright0723 | Motorcycle Gear | 26 | July 7th, 2013 11:35 AM |
Just bought an '08; gear questions | Goetterdaemmerung | Motorcycle Gear | 2 | October 31st, 2010 08:19 PM |
fell with no gear | backinthesaddleagain | Off-Topic | 9 | June 20th, 2009 07:23 PM |
