November 4th, 2011, 10:02 AM | #1 |
Join Date: Oct 2011 Motorcycle(s): 2015 Husky FE501S, 2007 KTM 525 EXC, 2002 KTM 250 EXC, 1998 Honda VFR 800 Posts: 113
What would you do? (Lane Position)
I am a firm believer that soft skills such as reading traffic, lane selection, and active scanning are just as important as hard skills such as braking, swerving, wheelie-ing etc. If this does not belong in this section please move.
So here is a situation from yesterday's commute home that I thought would be an interesting discussion topic on lane position selection. Interested in your opinion as to what course of action you would have taken given a similar set of circumstances. Basics: You are riding on a 4 lane (2 each way) city street in the outside (right) lane, there are two cars slightly ahead of you in the inside (left) lane, no other cars in front or behind in your direction of travel. Everyone is traveling at the same speed, ~30mph. There is one row of parked cars to your right. Variables: Approximately 100 yards ahead, there is an intersection with a smaller street, there are no traffic lights as it is a small intersection. You see the following things at this intersection: 1.) In the opposing direction of travel, there is a car stopped in the inside lane with it's left turn signal on. 2.) Just past the intersection, there is a car in the parking lane with it's left turn signal on and wheels turned to the left. 3.) There is a pedestrian waiting to cross the street at the intersection from your right to left, the cars in front of you do not seem to be slowing down for him. 4.) Just beyond the intersection there's a road sign showing that your two lanes will merge into one lane ahead. Questions: 1.) What lane would you choose? 2.) Where in your chosen lane would you ride (left, center, right)? 3.) What other actions would you take in conjunction with your lane selection? *Note, this is for discussion purposes only. As there are multiple ways to handle this situation, there probably isn't a "right" answer, though there might be some wrong answers |
November 4th, 2011, 10:44 AM | #2 |
Uhhhh I think at a first glance I would be picking the left lane in the right most side but more importantly, I would slow wayyyyy down and keep an eye on all other cars to see if they start moving. Stopping for a pedestrian is tricky. Sometimes I feel it is safe, other times I feel like it is asking for a rear ender.
If I were sandwiched between cars, I would do whatever they are doing. More than likely the cars trying to turn or merge in will wait for a long line of cars, with you in between, to pass before proceeding. |
November 4th, 2011, 10:59 AM | #3 |
never enough
Join Date: Sep 2011 Motorcycle(s): Blue 2010 ninja 250R Posts: 277
i would either stay in the right lane and move the to 1 position or switch to the left lane into the 3 position. depending on which i think would make me most visible to the other drivers.
custom graphics, zero gravity DB |
November 4th, 2011, 11:05 AM | #4 | |
I also did not actively slow because I felt that could invite the left turner to take the turn. |
November 4th, 2011, 11:08 AM | #5 |
I agree increasing visibility is important, however, I do not ride with any assumption that other drivers see me at all, no matter where I am or what I'm doing. Therefore I chose a lane position that gave me the most distance from all potential threats, hopefully giving myself the best chance at avoiding them.
November 4th, 2011, 11:36 AM | #6 |
"scandal!"
I think I would have gone left lane, left side. Keep an eye out for hazards.
November 4th, 2011, 12:27 PM | #7 |
So, where's the reverse?
I'm assuming that there would not be enough space to merge left after passing the intersection before you approach the parked car. So I would start to slow down, shoulder check, signal, check, merge left. As I approach the intersection, slow down slightly in case the left turner decides to go. If I have enough time, I might swerve from side to side inside that left lane to make myself more visible to the car.
If I had to maintain the right lane in this situation and noticed that the pedestrian didn't see me, I would beep my horn a few times. |
November 4th, 2011, 12:28 PM | #8 | |
never enough
November 4th, 2011, 12:29 PM | #9 |
November 4th, 2011, 12:41 PM | #10 |
Join Date: Oct 2011 Motorcycle(s): 2008 Ninja 250R (Sold - I'll miss you Ebony), 2009 Honda CBR 600RR ABS (Alexis), 2010 BMW S1000RR Posts: 93
Spacing
I agree with this. Probably best to try and make yourself visible while still giving yourself enough spacing in either situation...Maybe a bit of a lane drift from left to right with a temporary ride to the center as you continue to approach the moving car. The pedestrian most typically would either step back (human tendency) but you should have more room to navigate around/slow down with a human being. The car is most important to me as I've experienced blind soccer mom's pulling out of school parking lots quite a bit....I would much rather have a bit more space than assume I'm seen even if I try....
November 4th, 2011, 01:18 PM | #11 | |
What makes cagers so sure they can beat a motorcycle in an acceleration race? I mean really!?! |
November 4th, 2011, 01:30 PM | #12 |
I'd stick to the far left of the left lane and poke out a little to make sure the guy trying to turn left saw me while maintaining speed behind the two cars
November 4th, 2011, 01:38 PM | #13 | |
Also our smaller size/profile may contribute to the poor distance/closing rate perception. Finally, I think cagers may be more inclined to take chances if they perceive the risk to them is smaller with a motorcycle. If there was a Dodge Ram coming at them, they'd probably think twice before shooting for the gap. |
November 4th, 2011, 01:40 PM | #14 |
Not dead yet!
Join Date: Apr 2010 Motorcycle(s): 2009 Ninja 250R Posts: 315
I would close my eyes, punch it, lay on the horn, and hope for the best.
November 4th, 2011, 01:42 PM | #15 |
Join Date: Oct 2011 Motorcycle(s): '06 Ninja 250 Posts: 87
Right lane, position 3 for me. Maybe slow some, but like other have said, not enough to invite the left turner to go for it. Had to swerve today to miss someone pulling out from being parked like that...
Behind every great man is a woman rolling her eyes. - Jim Carrey |
November 4th, 2011, 01:43 PM | #16 |
November 4th, 2011, 01:53 PM | #17 |
Is position 3 the left side of the lane or the left? I think it's 1 left 2 middle 3 right? Is that how you mean it? If so, why choose to be closer to the pedestrian and parked car?
November 4th, 2011, 01:56 PM | #18 |
Yeah, that's right. And it would make it easier to get out of the way if the left turner did decide to go, and hopefully the parked car wouldn't be pulling completely into the inside lane.
November 4th, 2011, 02:15 PM | #19 |
Interesting, so you are saying you give your self maximum distance from the left turner as he presents the biggest danger, and rely on your ability to swerve to avoid the parked car if he makes a move. I think that could work, but maybe I would begin to move left after I've cleared the intersection to give more room for the parked car. Still uncertain how this would work vs. the pedestrian though.
December 6th, 2011, 05:33 PM | #20 |
"scandal!"
December 7th, 2011, 11:24 AM | #21 |
forever a newb
Join Date: Aug 2011 Motorcycle(s): 07 ninja 250 Posts: 33
I think it matters alot how far ahead the cars are. Where I live people are going to take every opportunity to do what they want to do. If you slow down at all they think you are letting them in and pedestrians are just the same, they will walk out in front of you and expect you to stop.
I would stay in the #2 but in the 1st position, speed up a little and try to use the cars as blockers, knowing that right after the intersection I'm going to brake and fall in behind the cars and expecting to swerve from the parked one pulling out. |
December 20th, 2011, 08:34 AM | #22 | |
That way the oncoming left-turning car can see you. The pedestrian is the lesser hazard as the pedestrian is not going to be fast enough to T-bone you, and probably won't start across until the cars going your way are past anyway. Besides, a collision with a pedestrian is a whole lot less painful than a collision with a car. |
December 20th, 2011, 04:43 PM | #23 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Not for the pedestrian.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
December 20th, 2011, 07:22 PM | #24 |
lane-split the cars, wheelie through the intersection to get the left-handers attention. make sure to rev it out so the pedestrian gets an ear-full. (remember, loud pipes save the lives of pedestrians who don't look) do a stoppie when the second parked lefter cuts you off. (it's probably a hot chick anyway, they never look)
December 20th, 2011, 09:21 PM | #25 | |
Done here.
Flip cagers off if possible. |
Lane Splitting on a Single Lane Road | Snowieflake | Riding Skills | 33 | August 28th, 2014 02:50 AM |
Lane Splitting Through Slow Cars on Two Lane Freeway | jeffb502 | Videos | 40 | April 6th, 2014 08:59 PM |
[motorcyclistonline] - Lane Position | Street Savvy | Ninjette Newsbot | Motorcycling News | 0 | January 4th, 2012 12:10 AM |
Lane Position.... | Mr.E | Riding Skills | 41 | October 13th, 2011 07:38 AM |
[sportrider - latest stories] - Lane Position In Street Riding | Ninjette Newsbot | Motorcycling News | 0 | July 2nd, 2009 12:10 PM |
