Old April 11th, 2012, 06:58 AM   #1
jus4fun
Motorcycle(s): BMW F800ST Honda Rebel CMX250
oil type, qty and automotive filter option
New owner here. What type of oil should I use for the 250?
What quantity?
Is there an automotive oil filter option that is recommended or do I need a kawasaki filter?
Thanks
jus4fun is offline   Reply With Quote
Old April 11th, 2012, 07:31 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Rotella T6, just under 2 quarts and you can use pretty much any filter that will fit. I use K&N #401
AFM #676
Supersports are for n00bs
Old April 11th, 2012, 07:32 AM   #3
gilmorec61
gilmorec61's Avatar
@Jiggles , is mobile 1 better that the rotella t6?
gilmorec61 is offline   Reply With Quote
Old April 11th, 2012, 07:33 AM   #4
I use a WIX 24941 filter because I've never read about any issues with them, like there have been with FRAM filters.
For oil, I will be switching to Rotella T6 5W-40 because I've heard from multiple people that they really really like it and I've seen good results on it from a study a while back.
also, if your bike is under 1000 miles, use traditional oil, not synthetic.
Check the DIY oil change thread for a good list of filters that work with this bike.
Old April 11th, 2012, 07:37 AM   #5
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Idk, I only use rotella t6, I like it
AFM #676
Old April 11th, 2012, 08:08 AM   #6
etiainen
CBR250R Traitor
etiainen's Avatar
Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold)
T6 all the way
etiainen is offline   Reply With Quote
Old April 11th, 2012, 08:34 AM   #7
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
T6 and Wix
cbdallas is offline   Reply With Quote
Old April 11th, 2012, 08:35 AM   #8
etiainen
CBR250R Traitor
etiainen's Avatar
I've used the FRAM filters before without an issue, but I did prefer the K&N ones.
Old April 11th, 2012, 10:18 AM   #9
DaBlue1
DaBlue1's Avatar
As far as oil filters go, you have a few options. They are located in the Wiki http://www.ninjette.org/wiki/Oil_Filters There may be some debate about Fram filters. There are 2 types that are made. Canister and cartridge type. The Ninja 250 uses the cartridge type filters and there have been no reported problems with them. Many riders have been using them for years. The same filter that fits the Ninja 250 also fits over 50 other Kawasaki models. Even the reported problems with the canister type filters were recalled and addressed years ago.
Oil. So I don't get into a big oil debate, here's what the owner's manual recommends;
Recommended Engine Oil
Type: API SE, SF or SG
API SH, SJ or SL with JASO MA
Viscosity: SAE 10W - 40
Capacity: 1.3 L (1.4 US qt) (When filter is not removed)
1.6 L (1.7 US qt) (When filter is removed)
NOTE
○Although 10W-40 engine oil is the recommended oil
for most conditions, the oil viscosity may need to be
changed to accommodate atmospheric conditions in
your riding area.
What is also listed in a chart is 10w-30,10w-50, 20w-40 & 20w-50
What it does not list is 15w, which falls in between 10w & 20w
There are also alternative oils that meet the type requirement recommended by Kawasaki and recommended by many in the motorcycle community.
These are formulated so close to motorcycle oil that they meet the recommended certification requirement.
1. Castrol RX Super 15w40
2. Chevron Delo 400 15w40
3. Mobil Delvac 1300 Super 15w40
4. Pennzoil Long-Life 15w40
5. Quaker State 4X4 Synthetic Blend 15w40
6. Shell Rotella-T 15w40 (favorite among other motorcyclist who change oil frequently)
7. SuperTech 2000 (WalMart) 15w40
8. Valvoline All Fleet 15w40
9. Castrol Syntec Blend Truck and 4X4 15w40
You will be fine with 10w-40 if it is in the temp range you ride in. As for me I ride longer distances at higher speeds more than the average rider. I'm also a little heavier too, so I use CASTROL Act>evo Semi-Synthetic 4-Stroke Motor Oil 20w 50 and change it frequently. Why? because the book says I can. Besides, it makes the bike ride smoother. Keep in mind the Ninja 250 is a high revving bike and any oil you put in it will breakdown. How fast, depends on your driving conditions.
Everybody has their own choice and reason for what they use. Kawasaki gave us very good options, that they know the bike can handle.
Last futzed with by DaBlue1; April 11th, 2012 at 02:25 PM.
Old April 11th, 2012, 11:20 AM   #10
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
i hated the rotella t5 and t6 clutch/gear action. Pulled the trigger on a gallon of Maxima Maxum4 Extra 10w40 and you wont believe the shifting
Wix filter all the way to
GlassAnkles is offline   Reply With Quote
Old April 11th, 2012, 12:53 PM   #11
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
Theirs a page in the manual about oil weight.
oil brand: personal preference really i tired motorex & kawasaki.Really your choice just choice the right weight the manual answers that.
Oil Filters:
K&N http://autoplicity.com/products/3784...gn=GSNOFITMENT
WIX http://www.discountfleetsupply.com/wix24941.html
THE GOOD LIFE
cuz is offline   Reply With Quote
Old April 11th, 2012, 01:12 PM   #12
DaBlue1, The weights for the alternative oils should have been 5W-40, not 15W-40. 15W-40 would be thicker and be worse for lubricating when cold.
http://faq.ninja250.org/wiki/Preferred_Brands
Old April 11th, 2012, 01:32 PM   #13
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
Shell Rotella & Mobil 1.
Can't go wrong with either, I like the shell a little better since I buy it by the 5gal.
Rexbo is offline   Reply With Quote
Old April 11th, 2012, 01:53 PM   #14
DaBlue1
DaBlue1's Avatar
Thanks. You are correct about cold lubrication, however I was thinking summer. I meant to put Rotella T and Rotella T6 and maybe have added a couple of others, but I thought those few were enough.
There are other brands and weights that other riders recommend as well.
http://www.vfrworld.com/tex_vfr/tech/oil.htm
http://motorcycleinfo.calsci.com/Consumables.html
Old April 11th, 2012, 02:00 PM   #15
I know Rotella T6 is preferred over Rotella T because T is energy conserving.
Old April 11th, 2012, 06:44 PM   #16
trevor_shiggs
trevor_shiggs's Avatar
I use Kawasaki Oil And Filter. Being an automotive tech I have seen many problems with aftermarket filters leading to major engine failure. But thats me.
2010 Ninja 250 Danmoto Carbon Slip On,Factory Pro Jet Kit,K&N R-0990 Air Filter,10000K HID's,Carbon Fiber Shogun No Cut Frame Sliders & Swingarm Spools,SSR Lowering Links and more....
trevor_shiggs is offline   Reply With Quote
Old April 11th, 2012, 07:08 PM   #17
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
FWIW on filters: I've never had any issues with any filter on bike or car. However, one day at Cycle Gear I did open up the boxes and check out the two brands of filter they had on hand for the Ninjette: Fram and K&N. Every single Fram filter I looked at (at least six of them) had some kind of visible imperfection. All the K&Ns were identical and perfect.
I use K&N because of that.
Old April 11th, 2012, 07:11 PM   #18
Jiggles
Jiggles's Avatar
MOTM - Apr '13
My mechanic actually said not to use K&N because of some issues. There are 4 ducatis that had blown engines because the K&N restricted oil flow too much. Now, theres only been 4 instances of this in all of the US and its all happened on ducatis so I'm not that worried, but it is an issue I hadn't heard of before
AFM #676
Old May 16th, 2013, 10:02 AM   #19
LNasty
Daily Jap rider
LNasty's Avatar
Question Twin Power Oil
Just Got some Twin Power 20/50w synthetic oil from biker shop down the road. anyone use this stuff before?
Old May 16th, 2013, 10:53 AM   #20
Ktam
Been using Motul 10w40 and as for filters I've been using Hiflofiltro HF401 (some reviews say that this filter isn't so good, something along the lines of weird shifting and oil pressure light not going out - I haven't experienced this though)
IMO as long as you go with the recommended oil grades for your region and a filter that fits any aftermarket should do the trick - so long as you perform your changes with due diligence.
Cheers!
Ktam is offline   Reply With Quote
Old May 16th, 2013, 11:13 AM   #21
nick5446
Motorcycle(s): Too many
That's Harley stuff and really heavy. I probably wouldn't use it if I were you. Don't panic if you already did.
nick5446 is offline   Reply With Quote
Old May 16th, 2013, 11:17 AM   #22
LNasty
Daily Jap rider
LNasty's Avatar
I know its heavy, Live in texas and drive mainly on interstate (Hot as hell), everyone down here uses 20/50w, just don't know if the fact that it says v-twin means anything. from what I have researched It is no different than the synthetics that say 4 stroke
Old May 16th, 2013, 11:18 AM   #23
LNasty
Daily Jap rider
LNasty's Avatar
Actually just saw that it does say 4 stroke on it
Old May 16th, 2013, 01:49 PM   #24
nick5446
To my knowledge there's nothing V-twin specific about it. I imagine you're good to go.
Old May 16th, 2013, 02:09 PM   #25
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I only buy bottled water that says refreshing on the label. I don't want water that isn't refreshing.
Stay hydrated
AFM #676
Old May 16th, 2013, 02:14 PM   #26
LNasty
Daily Jap rider
LNasty's Avatar
Stay hydrated
Thanks Jiggs
Old May 16th, 2013, 04:47 PM   #27
SafetyPaws
SafetyPaws's Avatar
Motorcycle(s): Ninja 250r
I currently use conventional, ive tried kawi, some cheap mobile motorcyle oil (was plannin on doing a quick change after that), and used honda gn4. All conventional and i am most likely about to switch to the T6. Maybe it is because it is all conventional but i noticed no difference between brands but i did notice the change after the fresh change each time. 4000 on conventional - time to go syn, every time i wanted to change it out i was not able to squeeze time to run get oil and i had some extra while i was doing research. I have used kawi filter, bikemaster filter (picked up at autozone/o reileys when dealers were closed for the kawi), and just bought a k&n when i bought my air filter - that will go in with the T6.
Stay hydrated
ahaha
is the T6 good for cold weather too or is that where the T comes in?
www.SafetyPaws.org
SafetyPaws is offline   Reply With Quote
Oil filter crosses over with Honda filter smokinsingle 2008 - 2012 Ninja 250R Tech Talk 4 April 19th, 2014 08:47 AM
Quick, Decent Chain Oil Option... Thoughts? poo poo 2008 - 2012 Ninja 250R Tech Talk 12 April 15th, 2012 03:28 PM
Loss of oil and Air filter soaked in Oil 08ninja250 2008 - 2012 Ninja 250R Tech Talk 19 August 9th, 2010 05:35 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
