Old July 19th, 2012, 09:24 AM   #1
capriccio
capriccio's Avatar
Bike has trouble starting
Recently, I have some trouble starting my bike. I had to press the Start button couple times before it fired up. This morning, I had it fired up, ran it a bit, stopped to drop a mail. When I came back, I had to press 20 times before it fired up again. Once it run, no problem though.
Any ideas ? Battery ? Spark Plugs ?
A little more info: Bike has been used regularly (at least 4 times a week), gas is almost full, oil is good, 7500 miles on it. Bike has been running perfectly before this happened. No recent mods.
capriccio is offline   Reply With Quote
Old July 19th, 2012, 09:26 AM   #2
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
starter maybe? =/
got a vid?
PsHYk is offline   Reply With Quote
Old July 19th, 2012, 09:28 AM   #3
When's the last time you adjusted the valves?
When you had trouble, did it start better with throttle or choke?
How hot was the engine when you had problems starting?
Have you touched your carbs at all?
Posted via Mobile Device
Old July 19th, 2012, 09:35 AM   #4
capriccio
capriccio's Avatar
I've never touch the carb. The valve has not been checked. It was 85 when I started it. When I pressed the Start button, just nothing happened, no sound, no click, nothing. After a couple times, it started like normal.
Old July 19th, 2012, 09:54 AM   #5
So, no electricity is reaching the starter?
Old July 19th, 2012, 10:04 AM   #6
Your button was just acting up on you. They do that sometimes.
You sure the kill switch was at the on position?
Old July 19th, 2012, 10:11 AM   #7
capriccio
capriccio's Avatar
@Motofool: Exactly. But why did it come back after a couple presses ?
@choneofakind: If the bike started with the kill switch at off position, it'll be even weirder :P
Old July 19th, 2012, 10:37 AM   #8
I would access the back of the starting bottom and would test it making a bridge with some wire.
That would indicate if that switch is the problem or if you need continuing checking the starter.
Trouble starting bike. Floki General Motorcycling Discussion 56 January 2nd, 2015 03:28 PM
Bike having trouble starting and running when cold jwollam 2008 - 2012 Ninja 250R Tech Talk 10 February 12th, 2013 06:47 PM
Trouble with starting speed vmlp 1986 - 2007 Ninja 250R Tech Talk 13 May 26th, 2012 09:12 PM
Trouble Starting dlebe250 1986 - 2007 Ninja 250R Tech Talk 7 January 12th, 2011 07:47 AM
trouble starting... n4v1n 2008 - 2012 Ninja 250R Tech Talk 4 August 9th, 2009 03:18 PM
