April 10th, 2014, 03:50 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2006 Ninja 250 Posts: 179
How To Change the Oil and Filter on Kawasaki Ninja 300 Motorcycle Video Tutorial
http://i857.photobucket.com/albums/a...ps2080efbb.jpg |
April 10th, 2014, 05:28 PM | #2 |
Noob question but why does the washer need to be replaced? I'm doing my 1st oil change tomorrow and I didn't buy the washer.
April 10th, 2014, 06:16 PM | #3 | |
You should be fine re using the washer in this case, the stock crush washer looked great on this 300
April 10th, 2014, 06:39 PM | #4 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
the crush washer is designed to deform when you torque it to create a 'perfect' seal (sort of a metal, one time gasket). If you reuse it then it is not going to be aligned in the same place and will not create as good a seal. 99% of the time you'll be fine, but I always replace mine anyway to be a perfectionist.
August 31st, 2014, 09:37 AM | #5 |
cadd cadd cadd
MOTM - May '15
With the slipper clutch is it OK to use either Rotella T, T5 or T6?
August 31st, 2014, 10:01 AM | #6 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Where the how to Twerk video
Ninja 300 K&N Air Filter How To Install Tutorial & Quick Review Video | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 12 | June 27th, 2014 07:15 PM |
change oil filter, without draining oil? | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 30th, 2010 01:08 PM |
