#1 |
Tried shimming, got stuck
I got stuck being unable to unscrew those ridiculous screws on the carbs. I KNOW there have been other people that had the same problem (the top right screw) i did everything I could/read and it's almost stripped so I had to stop. I didn't see any solution to getting it out easily. It's really put me in a pretty bad mood because I bought the JIS screwdrivers JUST so this wouldn't happen, and that screw just won't come out. I think pulling my carb out would be a little over my head. I could really use some advice. Thanks in advance guys.
#2 |
A little late for you now, but you need to apply down ward pressure (lots of downward pressure) as you turn the screw. If the screwdriver starts to slip out of the head, you need to exert more downward force and then turn.
Others in your predicament have used some vice grips on the screw, if you can get it in there or slot the head with a dremel, then use a screwdriver to get the stubborn screw out. last resort is to pull the carbs or leave the bike as is after putting back the screws you have removed. |
#3 |
Yea i read about the downward pressure in the other thread so I put as much as I could. The palms of my hands hurt from pushing down on it, but I still couldn't get it. IDK if we have any vice grips, but I'll check tomorrow morning. I'm calling it quits for tonight.. I'd hate to have to put it all back on because my exhaust is in the mail and I'd really like to figure this out. Thanks Kelly, I appreciate the help as always
#4 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Try the dremel trick, I think (correct me if I'm wrong) you have to cut a little slit in the screw then just unscrew it.
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
#5 |
Join Date: May 2009 Motorcycle(s): 09 ninja 250(red) Posts: 193
I would try using vice grips first and if that does work then break out the dremel. If you use the dremel you want to make the screw a flat head.
Also you are going to have to get new screws. Your best bet is to go ACE, Home Depot or Lowe's. The size is 4mm-.70 x 16mm. I would get allen head type of bolt. http://www.ninjette.org/forums/showthread.php?t=24285 |
#6 |
Ok cool, thanks guys. I didn't know what a dremel was, and I definitely don't own one, but if the vice grips don't work, I'll try that
#7 |
Nathan - you can also use a file to file a slot into it, but the dremel is much faster. A friend of my dad's told me this weekend that he saw a variable speed rotary tool (aka a generic dremel) at advance auto for $20 a week or so ago...
#8 |
Thanks Kim, I'll check that out. I got a pair of needle nose vice grips, and that stupid screw won't budge. It's made immensely harder by being almost totally inaccessible. Even with a file, dremel, etc. can someone help me out by either telling or showing me the easiest way to get into that screw? I've been going at it from the top (angled towards the carb cover), but if there is an easier way, please let me know.
#9 |
Frak It
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250R Posts: 199
I had to use the dremel trick. The cutting disc was a bit big so I made it smaller by cutting on a rock for a couple of minutes. It was then small enough in diameter to get in there comfortably. After cutting the slot I used a flathead and it came out fine. I used that screw on another hole. Wish I would have thought to get replacement screws before putting everything back together, but I made sure everything was snug.
I also had to use a small needle-nose vices on other screws. Those darn things can really ruin your day. ![]() |
#10 | |
![]() how about some words of encouragement for ARF? Was it worth the headaches? |
#11 |
Frak It
Absolutely. My confidence in my Ninjette went up several orders of magnitude. It no longer sputters when taking off from a stop, accelerates faster, and with the removal of the snorkel, sounds a lot meaner. Warming up doesn't take as long, either. I haven't even noticed a drop in fuel economy.
You bet, absolutely worth the headaches. ![]() |
#12 |
Thanks guys, I really appreciate it. Unfortunately I think I'm just going to have to shell out and pay for a jet kit. I'm driving up to school tomorrow and I really don't have any garage or place to work with tools like that or for long periods of time. Thanks again for all the help and advice every
Stuck bikeless | Toly | The Ex-Ninjetters Lair | 18 | January 29th, 2015 07:44 PM |
This is now stuck in my head. | Alex | Off-Topic | 7 | December 17th, 2014 07:41 AM |
Stuck in Whittier! | heroin300 | 2013 - 2017 Ninja 300 General Discussion | 9 | September 13th, 2014 09:40 PM |
Cold and stuck | blink | General Motorcycling Discussion | 6 | November 21st, 2011 03:06 PM |
Stuck in Neutral | ninjabadger | General Motorcycling Discussion | 11 | December 5th, 2009 11:00 PM |
