Old January 14th, 2013, 08:45 PM   #1
tubarney
Another Keihin 31mm CR Carbs Question
Does anyone know if these carbs are round slide or flat slide? Had a look in the threads about them but couldn't find it anywhere.
Old January 14th, 2013, 10:42 PM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Round
Worlds fastest 250 ninja
Racer x is online now   Reply With Quote
Old January 15th, 2013, 04:18 AM   #3
tubarney
Thanks Racerx, the keihin website is rubbish. What carbs do you have on your bike?
My tuner told me to get flat slides to maximise the gains from the cylinder head porting, he recommended mikuni so I'm going to see if one of their models fit tomorrow. Will let you know how I go.
Old January 15th, 2013, 05:50 AM   #4
Racer x
Racer x's Avatar
Mikuni makes the flat slide carb. I have 31mm CR Specials by Sudco. I absolutely love them. Jeff at Carb Parts Warehouse sells them at a good price. He can help you will tuning and all the parts. He just helped me convert my carbs to E85.
Old January 15th, 2013, 07:08 AM   #5
tubarney
I will be getting myself a pair of those if the mikuni's won't fit.
You might be interested in this. I spoked to my builder (http://www.ramsheadservice.com.au/) today and he said theres no chance of getting custom valve springs in Australia, unless I want 400! He did say that for him figuring out spring pressure is easy. He is going to do it for me and tell me if there is an engine I can get some out of. He seemed confident and says he even puts car valve springs in these things. If you want his help once you've figured out your cam and valve specs I will be happy to talk to him on your behalf.
He also told me everyone in Australia uses web cam camshaft so I'm going to give them a shot also. Have you looked into valvetrain modifications in the past?
Old January 15th, 2013, 07:16 AM   #6
Racer x
Racer x's Avatar
Thanks..my builder has one of those computer operated milling machines to do head porting.
I am having cams made at megacycle. I think you can use 600 springs. I will find out what year.
Old January 15th, 2013, 07:32 AM   #7
tubarney
Do these guys work with new cams or the stock ones? Are you thinking about going with a longer duration cam?
Old January 15th, 2013, 07:36 AM   #8
Racer x
Racer x's Avatar
Megacycle only works from original cams. No blanks.
My builder is going to increase valve size, lift and duration.
Old January 15th, 2013, 07:52 AM   #9
tubarney
I'm planning on doing the same. Please post what your builder chooses to go with when you get around to it. I know your experimenting with e85 at the moment. I'll post what I end up doing as well.
Old January 15th, 2013, 11:02 AM   #10
HKr1
IC2(SW)
HKr1's Avatar
Originally Posted by Racer x View Post
Round
And Smooth Bore.
Old January 15th, 2013, 11:16 AM   #11
Racer x
Racer x's Avatar
Yes, round slide and smooth bore. you can change the bore size also. And they are not vacuum operated slides. Fully mechanical.
Old January 15th, 2013, 08:48 PM   #12
tubarney
Do they have a pump accelerator? I was told by a supplier that CR specials do not.
Mikuni 33mm are a no go. There isn't enough room in the frame to fit them. Not to mention the price with custom cables is more than double the Keihin's. The 33's are designed to run on single engines so the way they have mounted the accelerator creates a lot more width, also running two pump accelerators with 33 mm carbs is a bit of overkill on this engine (so I was told).
Old January 15th, 2013, 10:02 PM   #13
tubarney
Racerx, find out what year model the 600 valve springs come from. My tuner said he has heaps and will give them to me for nothing. Even the new 636 springs. Will post you some if want to pay postage, which is something like 10 bucks to you guys in the states.
Old January 15th, 2013, 10:05 PM   #14
Racer x
Racer x's Avatar
You will like the CRs. But they don't have a pump. You don't need one. The throttle response is great. Unlike CV carbs you just have to be careful opening the throttle. Not a big deal.
The throttle cables are tough . You can use the stock 250 ninja cables . But they are tight around the hose coming from the head.
keihin main jet Q?? cuz 2008 - 2012 Ninja 250R Tech Talk 3 September 10th, 2011 08:27 PM
keihin racing catbs bikeboyben14 2008 - 2012 Ninja 250R Tech Talk 7 July 26th, 2009 11:00 PM
Keihin Needle Spreadsheet g21-30 2008 - 2012 Ninja 250R Tech Talk 5 December 24th, 2008 12:34 PM
