September 23rd, 2013, 09:19 AM | #1 |
Join Date: Jul 2013 Motorcycle(s): Pregen body with a newgen engine. Posts: 117
What if I'm missing the header gaskets/rings?
So I just had to reinstall headers and OEM mufflers, due to PO's idea of an exhaust upgrade....
So I noticed my bike did not have such gaskets or copper rings, I put it together like that I hear a quiet but noticeable air leak where the header connects to the engine. How bad is this, and do I need those gaskets, or would some high temp silicone fix this? I saw some gaskets on ebay made of something like braided steel that they claim work better than the copper rings... Any advice will be appreciated. Thanks! |
September 23rd, 2013, 03:40 PM | #2 |
Join Date: May 2013 Motorcycle(s): '89 klr 650, '00 250r Posts: 177
you should have the gaskets as without it, your exhaust is flowing more freely and causes a lean condition on your bike. do you need it? well it runs, as you just proved so no. should you have it, yes. and silicon belongs in fake bewbs only. i would go with OEM and not worry about it after. who knows what your buying on ebay. besides, gaskets are meant to be used once generally.
September 23rd, 2013, 05:37 PM | #3 | |
Missing idle circuit O rings? see photos... | baz666 | 1986 - 2007 Ninja 250R Tech Talk | 11 | July 3rd, 2019 02:50 PM |
what am i missing, 95 250R exhaust header bolt up questions (stock) | macantley | 1986 - 2007 Ninja 250R Tech Talk | 13 | May 19th, 2014 01:08 AM |
Gaskets | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 10 | November 6th, 2013 06:27 AM |
Petcock gaskets? | MasterCylinder | 1986 - 2007 Ninja 250R Tech Talk | 15 | September 12th, 2013 06:02 AM |
Engine-to-Header gaskets (NewGen) | USMCEvan | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 18th, 2012 09:45 PM |
