December 4th, 2015, 04:30 AM | #1 |
[visordown.com] - First impressions Honda Africa Twin CRF1000L
I'M on the launch of the Honda Africa Twin in South Africa, where we've just done the first morning of a two-day test ride. Very first impressions are that it's really compact, with a low seat height, at 870mm adjustable to 850mm. At 232kg, kerb weight is about the same as a base model R1200GS's 230kg, but the Africa Twin immediately feels smaller. It's narrow between your legs, helped by the parallel-twin engine configuration. At 5'9", I'm usually on tip-toes at best on big adventure models but on this I can almost get both feet flat on the ground, and that's on the higher of the two seat settings. At 100hp, it doesn't feel super fast but that power is super accessible thanks to a very linear delivery across the range. The throttle response is smooth, and really gentle rolling on from nothing. The 998cc engine feels a bit like the parallel-twin plant from the NC750 range but making twice the power. The red line isn't quite so low, at just below 8,000rpm compared to about 6,000rpm on the NC, and it's not quite so easy to bump into, but there's the same smooth, unsurprising build from a strong bottom end to a strong top. We haven't tried the Africa Twin off road yet, only on tarmac and gravel. We also haven't yet tried the automatic Dual Clutch transmisson version. On twisty roads, there's enough low-down drive to stay in a high gear through bends and then enough revs to accelerate fairly hard to the next corner. Obviously you'll get there faster by changing down to get the peak power earlier. I think the NC750 with DCT does a really good job of giving you it's full 52hp all the time in 'S' mode. I'll be interested to find out what that's like with 100hp. On the gravel roads, that broad useable spread of power means you don't have worry about changing gear as you rise and descend hills. I probably changed gear more than necessary. Easier just to leave it in one and enjoy the scenery. It's all very well for a Dakar veteran to jump on a GS and make it look like a lightweight enduro bike. For lesser riders, a more compact machine reduces intimidation factor on dirt, even if weight is the same, and that makes the Africa Twin a less ominous proposition. In level one, the traction control lets the back spin and kick up the gravel. I haven't tried level three, the highest, but Honda says it's for novices and intervenes so much you'll struggle to get up a gravel hill. Once, on the twisty tarmac, the dual-sport Dunlop Trailmax tyres threatened to loose traction in a bend, at both the front and back I think. It was a moment when you lift the bike up a bit and think: did it just do that? The front also sometimes seemed to struggle for grip under hard braking. That's it for now. I'll bring you a full review when I've finished riding.
Honda Africa Twin price revealed Honda Africa Twin debuts. Again. Honda Africa Twin shown in Milan Honda Africa Twin revealed Honda employee says new Honda is good Click here for full story...
[sportrider - features] - 2016 Honda CRF1000L Africa Twin Second Look | Ninjette Newsbot | Motorcycling News | 0 | July 24th, 2015 03:50 PM |
[visordown.com] - Honda CRF1000L Africa Twin more patent pictures | Ninjette Newsbot | Motorcycling News | 0 | May 19th, 2015 04:40 AM |
[visordown.com] - Hondas CRF1000L Africa Twin in detail | Ninjette Newsbot | Motorcycling News | 0 | May 15th, 2015 09:20 AM |
[sportrider - features] - 2016 Honda CRF1000L Africa Twin First Look | Ninjette Newsbot | Motorcycling News | 0 | May 12th, 2015 02:40 PM |
[motorcyclistonline] - Honda Confirms CRF1000L Africa Twin With DCT For 2016 | UP TO | Ninjette Newsbot | Motorcycling News | 0 | May 12th, 2015 02:41 AM |
