December 22nd, 2013, 08:42 AM | #1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
15,000 mile service
When I bought the bike at 11,300 miles, I replaced the coolant, oil, oil filter, tires, chain and sprockets, and just recently the air filter
I'm thinking all I will have to do now is the valve adjustment, spark plugs, and lube the steering bearings, and replace the brake lines. Is there anything else I should check? Should I replace fork and shock oils/seals? Anything on these bikes that wears faster than the manual says? |
December 22nd, 2013, 06:05 PM | #2 | |
return, no drag) - inspect and lubricate Choke operation - inspect and lubricate Engine vacuum synchronization - adjust after valve adjustment Fuel leak (fuel hose and pipe) - inspect Fuel hose damage and installation condition - inspect Coolant level - inspect Coolant leak (radiator hose and pipe) - inspect Radiator hose damage and installation condition - inspect Air suction system damage - inspect Clutch operation (play, disengagement, engagement) - inspect and lubricate cable and lever Tire tread wear, abnormal wear - inspect and align if needed Wheel bearing damage - inspect Drive chain lubrication (each 200~400 miles) Drive chain wear - inspect and adjust slack if needed Drive chain guide wear - inspect Front forks/rear shock absorber operation (damping and smooth stroke) - inspect (no need to replace oil or seals yet) Front forks/rear shock absorber oil leak - inspect Rocker arm operation - inspect and lubricate Tie-rods operation - inspect and lubricate Swingarm pivot - lubricate Steering play - inspect Steering stem bearings - lubricate Chassis parts - lubricate Bolts and nuts tightness - inspect Replace Brake fluid and bleed systems (no need to replace the brake lines) Lubricate all external shifting mechanism Lubricate both brake levers Brake fluid leak (brake hose and pipe) - inspect Brake hoses and installation condition - inspect Brake operation (effectiveness, play, no drag) - inspect and clean pistons and lubricate pins as needed Brake fluid level - inspect Brake pad wear - inspect Brake light switches operation - inspect
600 mile service | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 14th, 2012 07:48 PM |
600 mile service? | beqwarrior | 2008 - 2012 Ninja 250R Tech Talk | 10 | November 4th, 2011 07:10 AM |
Is the 600 mile service necessary? | Lil_Green_Demon | 2008 - 2012 Ninja 250R Tech Talk | 41 | August 28th, 2011 10:49 AM |
[roadracingworld.com] - 15,000-Mile Service Intervals For Engine Of New Ducati Multis | Ninjette Newsbot | Motorcycling News | 0 | February 5th, 2010 01:20 PM |
600 mile service. | tinng321 | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 8th, 2009 03:23 PM |
