Old October 3rd, 2015, 01:14 PM   #1
pb3
Motorcycle(s): 09 n250, 14 n300, 22 n400
coolant filter?
hi all, going through PM schedule and see that the australian version gets a coolant filter? anyone know why?
pb3 is offline   Reply With Quote
Old October 3rd, 2015, 01:17 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
No, but I'm envious!
Old October 3rd, 2015, 01:24 PM   #3
^^same!
Old October 3rd, 2015, 01:51 PM   #4
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Don't see the need for a coolant filter. It's basically a sealed system. I've never drained coolant and found it to be dirty, just gets old and becomes less effective.
I wonder if there really is some kind of coolant filter on the bike or if it's just a miss print, and wonder why they would only have it on bikes for certain countries.
Old October 3rd, 2015, 05:09 PM   #5
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
just googled it, and they exist, i woulda thought the same, sealed pipes and all...
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old October 3rd, 2015, 05:11 PM   #6
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Yeah they exist, for diesel engines. Didn't see any for gasoline engines though.
Old October 3rd, 2015, 05:37 PM   #7
Being anal, i want one. Flaky pipes, possible corrosion, any damage particulate, idk. Maybe I'm just weird.
Old October 3rd, 2015, 05:40 PM   #8
dcj13
Participant
dcj13's Avatar
You're getting conservative in your old age.
Old October 5th, 2015, 09:06 AM   #9
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
I would love one too! I think it's a great idea! See if you can find/make one. I'd be interested...
Old October 5th, 2015, 09:11 AM   #10
Sign me up for one too. I have replaced too many clogged radiators in my life.
Old October 5th, 2015, 09:48 AM   #11
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Use distilled water. There's nothing in antifreeze that will cause the scale in a radiator, just mineralized water. But you must use the correctly spec'd antifreeze for your engine/radiator.
One exception might be something like water wetter coolant but I say that without any evidence or knowledge of it causing any issue whatsoever.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old October 5th, 2015, 10:29 AM   #12
spooph
spooph's Avatar
MOTM - Oct '15
This we know.. A filter would be nice to now remove the previous contaminants. Maybe CSmith12 doesn't have contaminants in his system, but I do, and I'd rather pull it out with a filter than disassemble the whole engine and physically clean all the passages.
Old October 5th, 2015, 10:33 AM   #13
dcj13
Participant
dcj13's Avatar
In this area, many of us put plain old tap water in batteries and radiators (we have soft water). I've seen only one clogged radiator in my life ('65 Ford from Alabama).
Old October 5th, 2015, 10:38 AM   #14
Ya'lls need to buy more used cars where the origin and history of the coolant is unknown. And don't get me started on kids or "young adults" that will put anything in the coolant system.
And one more thing... The filter that I would love to see on radiators is not for the coolant, it's for the transmission/oil coolers found on hauling packages (some are built into the radiator, so you have to replace the entire thing ).
Old October 5th, 2015, 10:48 AM   #15
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
A filter won't remove the mineralization held in liquid state from hard water unless it's a large filter filled with the same chemistry as what is used to filter hard water for drinking.
A simpler method to clean and keep it clean is run some CLR or similar product to resolve and remove the existing scale then refill with 50% antifreeze and 50% distiller water. Problems solved unless the corrosion is so bad the scale is what stops it leaking!
Old October 5th, 2015, 02:02 PM   #16
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
Old October 10th, 2015, 03:19 PM   #17
pb3
another oddity discovered in the general info section of the service manual, the AU version gets a 43 tooth rear sprocket.
To filter or not to filter that is the question cadd Videos 19 April 30th, 2015 01:11 PM
Oil filter crosses over with Honda filter smokinsingle 2008 - 2012 Ninja 250R Tech Talk 4 April 19th, 2014 08:47 AM
Coolant SafetyPaws 2008 - 2012 Ninja 250R Tech Talk 33 May 17th, 2013 05:46 AM
Anyone know an air filter I can replace the OEM filter with? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2012 09:34 AM
What Coolant Do You Use? RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 19 March 12th, 2012 03:50 PM
