Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old August 2nd, 2012, 04:52 AM   #401
mpobad
mpobad's Avatar
Motorcycle(s): ninja 250r
From the tmcblog:
- Daya maksimum: 23,5 kW (32 PS) / 11.000 rpm
- Torsi maksimum: 21,0 Nm / 10.000 rpm
That equates to a bit over 31.5 horsepower and a bit under 15.5 ft. lbs.
So yeah, a tad beefier than the current bike. With normal losses at the rear wheel, power might turn out a bit lower compared to a current bike with a full exhaust, jet kit, etc.
Stock this is going to kill the CBR for those who want a bit more performance. The CBR is already down on power compared to the 08-12 Ninjette. I'm sure that once the aftermarket catches up with the new bike things will get very interesting.
I'm also interested in the ergos and want to see if the fairings can accommodate clip-ons (and whether or not we still have 37mm forks). That's months away, of course….
So far I'm really liking it. Would have liked to see a gear indicator and suspension adjustability, but whatever. It is what it is.
from what ive seen.... it accomodate perfectly clip ons (the adjustable ones) and i think theyre still 37mm forks....
mpobad is offline   Reply With Quote
Old August 2nd, 2012, 05:09 AM   #402
silentIm
silentIm's Avatar
Motorcycle(s): 2011 red ninja 250r
Good photo on the size compared to cbr 250.
silentIm is offline   Reply With Quote
Old August 2nd, 2012, 05:11 AM   #403
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
We'll just have to wait and see. There's a difference between being able to fit clip-ons and being able to set them the way you want them. I have the Shinto adjustable clip-ons on my 2008 bike and the fairing lowers prevent me from getting them exactly the way I'd like… the blocky switch gear gets in the way.
Old August 2nd, 2012, 05:58 AM   #404
Miles_Prower
One Loyal Fox
Miles_Prower's Avatar
Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R
ughhhhh whyyy.
I wanted a white bike so badly! I'm running through scenarios of how I can get one..crash das bike collect das insurance and get das white bike??!!
Alas, I should not be greedy. Our current bikes are still very good and mine definitely get's the job done with a smile and a laugh. And I have gotten pretty attached to it. If, knock on wood, I do crash again, this new new gen will be mine!!
My riding blog! Check it out if you are bored!aninjaridingpandabear.blogspot.com
8.10.12
Miles_Prower is offline   Reply With Quote
Old August 2nd, 2012, 06:05 AM   #405
Crashing is not an option. Bodily harm is not worth it in mind
Posted via Mobile Device
Old August 2nd, 2012, 06:24 AM   #406
From the tmcblog:
It appears to be slightly less than the current FI bike (23.5 kw instead of 24), and only the slightest bit stronger than the carb bike (23.5 kw instead of 23.4). Here are the kawi specs from the service manual for the 2008-2012 FI bike in Europe:
Cylindrée cm³ 249 cm³
Alésage x course 62,0 x 41,2 mm
Taux de compression 11,6:1
Distribution DOHC, 8 soupapes
Puissance maxi 33 ch (24 kW) à 11 000 tr/min
Couple maxi 2,24 kgf m (22 Nm) à 8 200 tr/min
Type d'alimentation Injection : 2 x ø 28 mm (Keihin) Double papillo
Here are the carb version specs:
Type: 4-stroke, DOHC, 2-cylinder
Cooling System: Liquid-cooled
Bore And Stroke: 62.0× 41.2 mm (2.5 × 1.6 in.)
Displacement: 249 cm³ (15.2 cu in.)
Compression Ratio: 11.6
Maximum Horsepower: 23.4 kW (31.8 PS) @11 000 r/min (rpm),
Maximum Torque: 22.0 N·m (2.24 kg·m, 16.2 ft·lb) @9 500
Carburetion System: Carburetor, Keihin CVK 30× 2
Old August 2nd, 2012, 06:33 AM   #407
Miles_Prower
One Loyal Fox
and by crashing i mean...accidentally dropping the bike and letting it fall down the ditch near my apartment!
but i agree..i couldn't willfully crash..i'm not a lemming!
8.10.12
Old August 2nd, 2012, 07:25 AM   #408
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Andrew, from what I see there's many space for other clip ons to the back but to the front it looks like it's limited.
If on the second gen you go with the Woodcrafts and also take the riser spacer from them you're able to play with positioning them.
My clip ons now are 15 mm above the upper triple clamp and 30 mm in the front of it. With this setup the bike feels absolute great.
For not hitting the fairings I use this: http://japan.webike.net/products/19841668.html
But I'd need to cut it by 3 mm, so it'll fit better and doesn't limit the steering so much (excuse me for my english, I hope you understand what I'm talking about).
Please take a look at my pictures.
Last futzed with by Somchai; September 6th, 2012 at 10:08 PM.
Old August 2nd, 2012, 08:37 AM   #409
mpobad
mpobad's Avatar
first video friends...
Old August 2nd, 2012, 08:41 AM   #410
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Originally Posted by 2009zx6rider View Post
The Ninja 250 will be no longer. The bike is going to be transformed into a 300 twin fuel injected with the option of Abs. I have no proof except that some people have ridden this bike and that In the recent Kawi release there was no mention of the 250. But for everyone who pokes fun and says I don't know what I'm talking about please return to apologize shortly.
Apology?
http://www.ninjette.org/forums/showthread.php?t=110755
broilmebk is offline   Reply With Quote
Old August 2nd, 2012, 08:45 AM   #411
Um, its a 250 not a 300, so there's no apology necessary since the terms of that apology weren't met? He was wrong.
Old August 2nd, 2012, 08:48 AM   #412
broilmebk
broilmebk's Avatar
nvm..
Old August 2nd, 2012, 08:49 AM   #413
Joule
Joule's Avatar
Motorcycle(s): Black 2011 Ninja 250R FI
Wait the **** up O_O
ofcourse we are all so Jelly, who all think that it's front fairing might fit our new gens?
dat road rash game
Joule is offline   Reply With Quote
Old August 2nd, 2012, 08:50 AM   #414
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
English?
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old August 2nd, 2012, 08:54 AM   #415
broilmebk
broilmebk's Avatar
Old August 2nd, 2012, 09:17 AM   #416
ARc
Revolver Wario
ARc's Avatar
Motorcycle(s): 2003 Ninja 250
Logo Dude
Ain't gonna happen until Kawi USA is done prepping their marketing materials. Think a little bit about how corporations work, they're not that hard to understand. If Indo is ready for their press release, US is either not too far behind, or not doing it at all.
ARc is offline   Reply With Quote
Old August 2nd, 2012, 10:06 AM   #417
adouglas
adouglas's Avatar
There's already a double-bubble for it. Scroll to 2:30.
Old August 2nd, 2012, 10:17 AM   #418
srt4evah
Motorcycle(s): 2011 Ducati Monster 796, 2013 Ninja 300
Regarding the new engine, I would point out these bits of information:
Kawasaki has claimed the new engine increases low and mid range torque.
The engine specs posted show the same peak torque, 22nm, but note that on the FI model is comes on at 8200RPMs, vs 9500RPMs with the carbureted model.
srt4evah is offline   Reply With Quote
Old August 2nd, 2012, 10:26 AM   #419
oblivion007
"scandal!"
Motorcycle(s): 2011 250R(Crashed 2/26/2014), 09 ER6n
is it really made by Kawasaki Heavy Industries? ^_^ I hope so.
oblivion007 is offline   Reply With Quote
Old August 2nd, 2012, 10:57 AM   #420
massacremasses
Avid Kitteh Poster
someone can sub it.
Old August 2nd, 2012, 10:59 AM   #421
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
Originally Posted by bdavison View Post
I propose that we start referring to them as 1G, 2G, and 3G.
1G being the formerly known pre-gens
2G being 2008-2012 models
3G being 2013 till whenever they redesign again.
aren't the pregen technically '3rd generation'? and the newgen '4th generation'?
Then the 2013 should be 5th gen
iplante is offline   Reply With Quote
Old August 2nd, 2012, 11:00 AM   #422
iplante
iplante's Avatar
Also I'm gonna start accepting donations so I can afford one of those when it comes out!
PM me for paypal info!
:P
Old August 2nd, 2012, 11:25 AM   #423
ally99
Ninja chick
ally99's Avatar
MOTM - Dec '13, Feb '15
Wow, that is one HOT bike!! Dayum!
Postwhores are COOL! ~Allyson
Old August 2nd, 2012, 11:32 AM   #424
my bike looks so ugly now...god damnit.
Old August 2nd, 2012, 12:29 PM   #425
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I just realized that the powers of percocet caused me to accidentally predict this.
Originally Posted by Jiggles View Post
Ok guys...
2011: New Ninja 1000
2012: New Ninja 650
2013: New Ninja 250, it only makes sense when you follow the breadcrumbs...
I have a few pills left does anyone else need a prediction?
AFM #676
Supersports are for n00bs
Old August 2nd, 2012, 01:04 PM   #426
adouglas
adouglas's Avatar
My bike still looks sexy, but that's not stopping me from drooling.
Like I say to my wife "hey, look, I'm hard-wired to be attracted to beautiful women... that doesn't mean I'm about to run off with someone else."
Old August 2nd, 2012, 01:38 PM   #427
Originally Posted by Sonofswin View Post
This link will get you to their parts search page:
http://www.kawasaki-motors.com/for_u.../PCSearch.html
The first choice is model, second line is from what year to what. Or you can search using frame number at the second arrow. (May not work for non-Japanese models)
Or if you are looking for their official accessories then:
http://www.kawasaki-motors.com/model...250r/parts.jsp
If you use Firefox and have a need to look at Japanese sites - I highly recommend the add-on called Rikaichan. It will translate the Japanese for you one word or phrase at a time, making it easier to search around simple Japanese pages. (Not recommended for full text translation.)
Back on Topic:
I like the angular look of the new fairings but do think they should have kept the side covered a bit more. It will be interesting to see what options they send to The States.
The way that they sweep the exhaust down to the left then under the engine is interesting. I guess since the fairings don't go so far back on the underside (as shown in this pic) it alleviates the clearance problem. It also allows them to sharpen the front of the fairings to a more aerodynamic point. Surely an improvement related to the heat coming up out of the fairings but wouldn't the twists in the exhaust constrict airflow a bit more than necessary? It's gonna be really interesting to see what the after-market exhaust manufacturers do with the reduced clearance on the sides of the fairings and all that open space underneath. I think I'm gonna like it
Thanks. I was hoping to find the parts fiche of the 2013 so I could really see what different. I agree that the sides should have stayed covered. Even without the false frame that's now part of the side fairings, it looks weird to see so much cosmetic shaping on the exhaust hanger/footpeg and then see a plain tube that it attaches to. It's clear that one was meant to be seen and one wasn't.
That's the division covering Indonesia, it seems.
Actually, that would make the Canadian 2003-2007 EX250 the "4th gen" and the new 2013 would be 6th gen. FWIW, it was called the ZZR250 in some markets.
Old August 2nd, 2012, 01:53 PM   #428
mpobad
mpobad's Avatar
wondering if my actual exhaust slip on will fit the new 250....
Old August 2nd, 2012, 01:55 PM   #429
I'm wondering if the new stock exhaust will fit my old 250 (may need passenger peg/exhaust hanger bracket).
Old August 2nd, 2012, 03:11 PM   #430
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Just found this thread. Lots of excitement in here Glad that kawasaki has done this. The new design doesn't look that great to me though: I think I prefer the 2008+ design: it's bubbly, friendly and looks 'fuller' from the side. The only things about the 2013 ninjette that really appeal to me are the ABS and the integrated turn signals.
I hope that you guys in America get F.I. with this new ninjette.
Time to sit back and continue enjoying the excitement
Old August 2nd, 2012, 03:36 PM   #431
mpobad
mpobad's Avatar
im from brazil.....cant wait for this....dunno how to sleep seeing this without knowing the release date
Old August 2nd, 2012, 03:37 PM   #432
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I think people are getting a little too excited for new fairings....
AFM #676
Old August 2nd, 2012, 03:53 PM   #433
s2kenny
Lean in
s2kenny's Avatar
Motorcycle(s): Pearl White 250r, Raven R6, Black 600RR, Silver Ninja 250
Well.. it seems like I'm coming back to Ninjette. I love every aspect of this re design. The fairings look superb, adds a little more aggressivness to it. The wheels are nice, the gauge looks nice, and if it comes in FI, I'll take two!
s2kenny is offline   Reply With Quote
Old August 2nd, 2012, 03:59 PM   #434
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
To be honest...kinda ugly. But It would probably look nicer with race plastics and a better exhaust.
Old August 2nd, 2012, 04:06 PM   #435
Both of those specs I posted are for the 2008-2012 motor. The 2013 motor reaches its maximum of 21 nm at 10,000 RPM.
In other words, the peak specs don't necessarily prove or disprove their claim, one would need to see a dyno chart to see what the hp/tq numbers looks like at 7k rpm or so on the two motors.
Old August 2nd, 2012, 04:09 PM   #436
massacremasses
Avid Kitteh Poster
engine, gauge cluster, FI, wheels, exhaust etc.
Old August 2nd, 2012, 04:21 PM   #437
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Engine produces .1kw over stock carbs, I'm just going to guess that jetted carbs will out perform in terms of power the stock EFI. I'll be very interested to see the dyno charts for both. My guess based on where they changed the peak torque to is that the stock carbed version will have more HP in the power band while the EFI has more HP down low. Either way I don't think the difference will be very noticeable.
The guage cluster is very cool. Personally I prefer my 250s analog cluster over my 1000s digital cluster but thats just me
FI certainly does make it more noob friendly. Only downside is it just got much more expensive to tune, change out exhausts and modify air intake.
The wheels are gay dude.
The exhaust is even gayer.
AFM #676
Old August 2nd, 2012, 04:23 PM   #438
massacremasses
Avid Kitteh Poster
I like the old wheels better as well. But the exhaust is 100 times better looking than the stock exhaust on the 08-12s youre crazy
Old August 2nd, 2012, 04:25 PM   #439
mpobad
mpobad's Avatar
i think the exhaust will be the same way to change as now....but for air intake i agree...will be more expensive...
Old August 2nd, 2012, 04:28 PM   #440
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Girl, you are crazy
AFM #676
Ninja 250 & 300 Valve Spring Thread garth285 2008 - 2012 Ninja 250R Tech Talk 30 February 19th, 2017 02:42 AM
Subjective 250 vs 300 thread to help potential buyers cadd General Motorcycling Discussion 54 September 8th, 2014 09:44 AM
2013 Formula 1 - Official Thread camaroz1985 Off-Topic 125 January 4th, 2014 07:40 AM
2012 Formula 1 - Official Thread camaroz1985 Off-Topic 115 November 26th, 2012 11:21 AM
Official Area-P Pre-08 Ninja 250 Exhaust Thread Purspeed 1986 - 2007 Ninja 250R Tech Talk 336 September 19th, 2012 06:01 AM
