July 7th, 2012, 07:47 AM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2012 black Ninjette Posts: 75
How to Quieten down a muffler
So long story short, I got fined for having a too loud yoshimura slip on...
SO angry! Anyway.. is there a way I can quieten down my slip on?? Home made silencer maybe? I've heard of the steel wool method, but apparently it's only temporary? Please any suggestions! Perhaps a silencer from another brand that will fit on my exhaust?? I REALLY NEED HELP! thanks
Ride safe, be safe..! |
July 7th, 2012, 08:45 AM | #2 |
How old is it?
If the muffler is assembled with screws, it could be repacked. I would call yoshimura and ask if they make a silcencer. If you decide on fighting the charge, get a sound cert from yoshimura. Most their mufflers meet requirements for DOT. Then when in court ask how the policeman captured the sound and when his sound meter was calibrated and the make and model of the meter. If he presents all this, then ask him if he remembers if there any other vehicles present. After everything, present the cert as evidence stating that it is indeed legal. And lab tested. Upon leaving, suggest the officer get his hearing checked |
July 7th, 2012, 07:14 PM | #3 | |
It's a brand new muffler... I put it on, and in the next couple days I got pinged... It was actually the muffler that attracted attention, then the cops got me for not having a license plate light... But he mentiond that this is my "warning" and I should to change to stock, as it's too loud... I agree, it is slightly too loud... Yoshimura do make a silencer, but its a stupid idea, as it only gets rid of about 2 dB.. Is there perhaps a baffle or silencer I can make or buy and insert it instead? It needs to be under 96db here in Australia in order to comply... Stupid pigs....!!! AND Im still pissed....
July 7th, 2012, 09:09 PM | #4 |
40 on the road
Join Date: Oct 2010 Motorcycle(s): 2008 Ninja 250, 2012 Ninja 650, 2006 Bonneville, 1990 Sportster Posts: 67
After following the advice in previous posts, send us your new address, including cell number, and we'll be glad to visit when in-country.
Best get over being 'pissed' before you ride again. |
July 7th, 2012, 10:52 PM | #5 | |
If anything the silencer makes it just under legal. If you have access to a welder you can make cylinder packed with fiberglass and place it inside the end cap. Did the policeman take pictures? |
July 7th, 2012, 10:59 PM | #6 | |
E
I'm not sure about the nuances of the legal system,but if he shows them he repaired the muffler and license plate, there is a possibility the charges will be dropped. I agree that anger towards the officer should placed toward working to get out of the ticket. Then getting the laws relaxed afterwards. Last futzed with by lgk; July 8th, 2012 at 01:18 AM. |
July 8th, 2012, 01:54 AM | #7 | |
But apparently it is... Yoshimura quoted me a 106dB without the silencer and 104 with... The silencer helps, and it is noticeable, but not noticeable enough... It needs to be slightly quieter I reckon in order to comply. Nah he didn't really fixate on the exhaust, just mentioned it and pinged me for the plate light.. I think he thought it would be easier to fine me for the plate light, rather than the hassle of the exhaust.. I put some steel wool in the end pipe today.. Quietened it down considerably.... I'm just not sure on the damage aspect.. I could smell the weird smell of the steel wool burning, but am not sure if its doing damage to the engine? Any suggestions? Also, how exactly would I make a cylinder with fiberglass, I was thinking that I would buy/obtain a metal pipe the same size diameter as the silencer insert, fill it with wrapped fiberglass (the wrapping version that's a bit like steel wool) I would then place it in the pipe, and place the whole pipe and wrap into the exhaust and then place the silencer back in... would the fiberglass damage the engine/exhaust at all? Would it be better to drill holes in the cylinder pipe? Thanks mate!
July 8th, 2012, 07:13 AM | #8 |
thats good, around here you can get away withe license plate fine if you show receipts that a repair was made. when it happened to me i showed the judge a receipt for a light bulb, and a picture of it working at night, and got the fine dropped.
still wasted a day at traffic court though... could have been the oil in the steel wool burning. the material should be degreased before using. if you packed the end with wool then it possible that it was too restrictive. the way to make a cylinder is to use perforated tube and weld top/bottom caps. or roll and fold/weld perforated sheet into a cylinder then weld top and bottom caps. then just fill the cylinder with muffler packing material from the auto parts store. the piece wont be too big, but using real packing material works great. take some pics of the inside of end cap and muffler first so you can figure out mounting options. as for designing something you'll have dismantle it and measure -the inside diameter -outside diameter -baffle length -inlet diameter then you can size how big the silencer has to be. |
July 8th, 2012, 07:28 AM | #9 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
I put the silencer in my yoshimira and quieted it down a whole lot. You could get the yoshimira silencer and mig an extra little baffle onto the end , or buy a universal baffle out of a catalogue or eBay and get a diameter that will fit
July 8th, 2012, 07:00 PM | #10 | |
Yeh nah, the cops pinged me too good... It's really hard to get out of fines here... :/ With the silencer, if you weld top and bottom caps, wouldn't it restrict the airflow too much?? It'd be like basicalled putting a solid pipe in, as the bottom end cap will completely shut off the flow...? Or maybe I'm just seeing it wrong in my head? Would you make the peforated tube smaller in diamtereter than the actual exhaust? A diagram would be better to understand... Not exactly keen on taking apart the whole muffler... I would just rather get a perforated tube, slip some fiberglass wrapping in there, and slip in the muffler.. Wouldn't that work aswell?
July 8th, 2012, 07:02 PM | #11 | |
How did you do it? Do you mind taking a couple pics, or drawing a diagram? What did you use to make the baffle?? Also I was looking at baffles on eBay, but am not sure of the reliability of them.... Do you have any recommendations or links? The diameter of the yoshimura pipe is 2" Cheers mate
July 8th, 2012, 07:25 PM | #12 | |
The mounting will he difficult to make without taking measurements of the interior. If feel you feel uncomfortable disassembling it, then i would try to alter the yoshimura one. My instincts are telling me that the yoshi silencer should be more than a 2 db reduction.... |
July 8th, 2012, 07:35 PM | #13 | |
July 9th, 2012, 04:41 AM | #14 |
July 9th, 2012, 04:45 AM | #15 |
I went to my local bike shop today... Quoted me for a custom baffle $180... Will do that instead and post pics, and a write up of what they did...
July 9th, 2012, 06:17 AM | #16 |
July 9th, 2012, 08:18 AM | #17 |
Intrepid Adventurer
Buy a Baffle that is od is the same as your yoshimira Id and then drill a hole where the mounting screw goes. I can take pics when I get home I am out of town.
I used this yoshimira one because it is made for my exhaust But you could use something like this http://www.jpcycles.com/product/443-...ed=0CGsQgwgwAg Or use one like this if you can put a little bend in it about 2" down like 15 degrees or so Mock it up as you bend it http://item.mobileweb.ebay.com/viewi...assified=false Or combine some of the perforated steel tubing by attaching a length of it onto the yoshimira baffle for extra noise deadening ... Without having to break your nice pipe all apart Wow 180$ for a baffle :/ seems really steep to me The yoshimira baffle comes with a Cnc made aluminum fitting and a steel dip tube then add a section of perforated tube and you still are only 60 bucks in |
July 9th, 2012, 10:49 AM | #18 | |
July 9th, 2012, 06:11 PM | #19 |
Yeh I have the yoshimura baffle, but it's minimal in reducation.... Noticeable but I need it a bit more quieter.... I was thinking of welding a perforated tube about 3" long to the end of the yoshimura baffle, packing the tube with firbeglass paking, with NO end caps.... I do this as I have stuffed some steel wool in my muffler, it is perfect in sound and I want to replicate it...
Or possible just but that baffle at jpcycles, and weld it to the end? Or maybe just weld a perforated tube with end caps and no firbeglass packing the the end of the yoshimura baffle? Fiberglass tends to break down quikly...
July 9th, 2012, 06:18 PM | #20 | |
i want to see why it doesn't work. |
July 9th, 2012, 06:20 PM | #21 | |
It does work, but it's pretty crappy at silencing the noise... I'll upload some pics when I get home in a couple hours.... What setup do you have on your yoshimura?
July 9th, 2012, 08:51 PM | #22 | |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
July 9th, 2012, 09:03 PM | #23 | |
Intrepid Adventurer
I would cut away the yoshimira baffle just below the bend and weld on a section of perforated tube as long as possible . Wrap it is fiberglass and then tie the fiberglass with some stainless wire. I have re packet lots of Mx style silencers and perforated tube with fiberglass pack wrapped about it really tunes it down a lot eve without end caps . Even a straight shot through... Now you have me wanting to experiment with my yoshimira carbon fiber slip on It's hard to find a good way to silence without restriction I have never heard of someone buying a yoshimira and wanting quieter... Sorta contradictory but it is possible. And yoshi s look so darn cool Last futzed with by Klondike1020; July 9th, 2012 at 09:14 PM. Reason: And |
July 9th, 2012, 09:15 PM | #24 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
I second this.
July 9th, 2012, 09:23 PM | #25 |
ninjette.org *********
Join Date: Jul 2011 Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r Posts: 347
July 10th, 2012, 04:58 AM | #26 | |
the stock exhaust is restrictive and sounds like a moped. Putting it back is a terrible suggestion... what is wrong with you people... |
July 10th, 2012, 05:39 AM | #27 |
thankfully there's enough harleys around here, my bike sounds like a leaf blower compared to them, that I don't get bothered. I love my yoshi slip on.
personally, unless it was a "written" warning such that another officer could see that you were warned, I'd leave it as is, and just upshift when you're around police to keep the noise down. and fix the plate light, that's a sure way to get pulled over. |
July 10th, 2012, 08:23 AM | #28 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Didn't read everyone's post.
Here's my suggestion: Put your stock exhaust back on. Aftermarket exhaust for street = Not worth the ticket(s)
July 10th, 2012, 09:31 AM | #29 |
Seems like a good suggestion if he doesn't want anymore issues with the law regarding how loud his exhaust is.
July 10th, 2012, 09:46 AM | #30 |
July 10th, 2012, 09:59 AM | #31 |
Performance? Slip-ons provide minimal performance and those slight gains would only be felt when the engine is screaming and well over the legal sound limit.
July 10th, 2012, 10:25 AM | #32 | |
it just seems like you're are more afraid of the punishment, then honoring the law. |
July 10th, 2012, 11:35 AM | #33 |
lolwut.
July 10th, 2012, 11:50 AM | #34 |
i'm glad you think its funny, but a lot of people actually think this way.
they look at the fines/risk and end up quitting, instead of meeting the requirements of the law. when something is as harmless/simple as this, and people suggest quitting i don't know if i should laugh or cry... |
July 10th, 2012, 11:57 AM | #35 |
Heads-up, the OP is in Australia. I think he's likely more cognizant of the laws/regulations/fines that may come from the loud exhaust than the rest of the commenters in the thread. Perhaps it's worth it, perhaps it's not. If it is about improving performance, adding a slip-on for sound and then clogging it back up with baffles & packing seems like a waste of money and time (IMO), as any of the slight performance gains are going out the window anyway. But it's not my money, or my time, so it's certainly not up to me (or anyone but him) on what makes sense.
July 10th, 2012, 12:00 PM | #36 | |
hates stupid people
His yoshi obviously doesn't meet the requirements of the law there. Putting the stock one back on does. You're right, it's harmless and simple to put the stock one back on.
My vlogging channel: Ma1iciousLogic |
July 10th, 2012, 12:01 PM | #37 |
Nicely stated, Alex.
July 10th, 2012, 02:53 PM | #38 | |
it is easy to put the stock one back, but its not worth it until the exhaust is proved unworkable. selling a used exhaust that's practically new is fail. he wont get much money for it... since no one else can use it. |
July 10th, 2012, 03:36 PM | #39 | |
What are you going to do when the government mandates that no one can modify their exhausts other than what the manufacturer provides? Are you going flaunt the law and spend $$$$ on something that is, in my mind, almost totally worthless and risk huge fines and jail time? I'm aware the OP is from Australia, and yes, I've heard of the tactics used by cops there. However, every story I've heard, the cops had a legitimate reason to pull you over. If you kept your exhaust system stock and your bike in good shape (like your license plate light), you wouldn't be in this pickle in the first place. I don't think my bike sounds like a moped, I've been on mopeds/motorscooters while I was in Asiatic countries, I know what they sound like, and the 250 does NOT sound like that. If you want a exhaust that sounds like it comes from a bigger bike, buy the bigger bike. Don't try to make the 250R something that it is not. Edit: Alex, I know that you're trying to keep the peace here, but I'm sick of hearing folks trashing their bikes by modifying the exhaust without learning how to ride it in the first place and to understand why the bike's performance is this way.
July 10th, 2012, 04:06 PM | #40 | |
the law gets that restrictive because no one questions it. if you don't see the error of jailing someone over an exhaust you got issues. huge fines, really...? last i heard adding a yoshimura exhaust on a ninja is far from the classification of "trashing it". would it have made a difference if it was a full exhaust instead of a slip on. or 600cc instead of a 250cc bike. what is the threshold for an idea not to be "cool" anymore, and where can i download the rule book so i can be "cool". i was exaggerating a little about it sounding like a moped, lol. lighten up, francis |
Yoshimura 2-1, need a new muffler | mr2peak | Items Wanted | 3 | September 23rd, 2014 09:37 PM |
2010 + stock muffler and muffler cover | Boom King | Items Wanted | 2 | October 28th, 2012 03:42 PM |
Painting the muffler | eddiekay | General Motorcycling Discussion | 9 | July 15th, 2012 02:20 PM |
Muffler Paint... | bigrodge8 | 2008 - 2012 Ninja 250R Farkles | 22 | April 26th, 2010 07:06 PM |
