Old August 2nd, 2009, 08:42 PM   #1
angrycrow
angrycrow's Avatar
Motorcycle(s): 09 ninja 250
calling all rim tape pros
hi i went through alot of rim tape and i cant seem to get it right . can anyone of you "rim tape pros" give me some pointers?
angrycrow is offline   Reply With Quote
Old August 2nd, 2009, 08:55 PM   #2
almost40
ninjette.org Monkey Spank
almost40's Avatar
You will never get it perfect, but I found the best way to apply it is to get the wheel off the ground so you can rotate it while you apply the tape. Good luck and take heart you will be the only one that will notice your mistakes.
Black 250R
Full Area P QC
Old August 2nd, 2009, 09:51 PM   #3
AnarchoMoltov
AnarchoMoltov's Avatar
Motorcycle(s): 2007 Suzuki GSX-R750
patience and persistence
AnarchoMoltov is offline   Reply With Quote
Old August 2nd, 2009, 10:29 PM   #4
also, spray the wheel with a solution of water and soap when applying. it allows you to reposition the vinyl to get it perfect before the adhesive begins it adhere.
Old August 2nd, 2009, 11:20 PM   #5
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Check this out, looks like it would helps heaps!!
DIY rim tape applicator
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old August 3rd, 2009, 05:02 AM   #6
norm_52
Motorcycle(s): 250r
the kit i bought came with an applicator that sits against the rim, mine came out perfect, i will post a pic up later today. best way t do it; hold the applicator at the bottom of the wheel and get someone to move the bike forward slowly for the left side and backwards slowly for the right. i dont mean to sound arrogant but it is literally perfect.
norm_52 is offline   Reply With Quote
Old August 3rd, 2009, 05:40 AM   #7
Rayme
Rayme's Avatar
Motorcycle(s): '04 sv650s
Get High quality vinyl. Those ebay one usually sucks and will break or stretch easily. If unsure, get a roll of 3m vinyl/reflective vinyl and cut your own (straight) ones. You can go as wide as 7-8mm without needing the pre-curved ones.
Clean wheels with alcohol. Put bike on strands, and have someone slowly rotate the wheel while you are applying with your 2 thumbs, one to hold it steady/press it against the rim and the other one to "align" it properly. That method worked best for me.
I didn't try the applicator but I'm sure it would give better results if use properly!
There's 2 types of people in this world, those who complain and those who act.
Rayme is offline   Reply With Quote
Old August 3rd, 2009, 07:47 AM   #8
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Ok, norm .... where did ya get this kit?
Old August 3rd, 2009, 09:11 AM   #9
CANTFUNCTION
CANTFUNCTION's Avatar
Motorcycle(s): 09 ninja 250(red)
ebay
http://cgi.ebay.com/ebaymotors/KEITI...Q5fAccessories
CANTFUNCTION is offline   Reply With Quote
Old August 3rd, 2009, 09:17 AM   #10
rockNroll
rockNroll's Avatar
Originally Posted by CANTFUNCTION View Post
Thanks
Pregen rim tape on silver rim? fr1dayn1ght 1986 - 2007 Ninja 250R Farkles 4 August 26th, 2013 04:45 PM
"Rim wrap" + thin rim tape as an alternative to powder-coating? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 July 21st, 2012 02:14 PM
Rim tape. blink General Motorcycling Discussion 14 March 31st, 2012 11:19 PM
Rim Tape??? tinng321 2008 - 2012 Ninja 250R Farkles 25 September 29th, 2009 01:31 PM
looking for the SE rim tape zartan Off-Topic 11 January 30th, 2009 03:09 PM
