Old February 14th, 2016, 09:15 AM   #1
UFOmoplata
UFOmoplata's Avatar
Motorcycle(s): 2007 Hoodrat 250
Brakes thread
There wasn't an organized thread on brakes, so I made one because I have a question.
I know Ghostt has a bunch of input on brakes.
My question was mainly about replacing the stock MC with one from a 636. After adding clip-ons, the brake line hits the gauge cluster making left turns impossible. I was looking at the 636 MC and the hose inlet is in a different position. Has anyone tried this mod?
https://www.google.com/search?q=636+...YnCM0Q_AUICCgD
So far:
-Can pregen rotors swap onto newgen wheels, and vice versa? NO
-Can newgen calipers mount to pregen forks, and vice versa? NOT without bracket.
-Swap out to DOT 5.1
-Do pregen and newgen SS lines interchange? WE SHALL SEE.
Any other relevant pregen brakes info?
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes."
UFOmoplata is offline   Reply With Quote
Old February 15th, 2016, 11:12 AM   #2
agentbad
agentbad's Avatar
So far:
All I can tell you is sintered EBC pads up front with galfer SS lines made a pretty big difference over stock. I feel like I can get maximum braking power now since the brake feel is more noticeable and easier to control.
Old February 15th, 2016, 01:42 PM   #3
Ghostt
Ghostt's Avatar
I'm getting ready to swap out my OEM master cylinder, to one from a zx600.
Kawasaki Master Cylinder ZX600 ZX 600 zx600 zx 600 Ninja 88-91 43015-1345
The porpoise of this is it has a larger piston 5/8", hence more braking force, and better feel.
I've seen this done before, and it had favorable results from what I read about it, but I can't remember where I seen it.
We shall see.
If anyone wants me to post my write-up here on brakes, just let me know.
violente et ignorantia
ZX-2R BLOG
Old February 15th, 2016, 06:42 PM   #4
UFOmoplata
UFOmoplata's Avatar
We shall see.
That'd be awesome.
Line comes in tomorrow. Need some 5.1.
Old February 15th, 2016, 06:50 PM   #5
Ghostt
Ghostt's Avatar
I ordered mine thru Amazon
ZX-2R BLOG
Old February 15th, 2016, 07:09 PM   #6
HoneyBadgerRy
HoneyBadgerRy's Avatar
I'm sure nobody cares, but I like the stock brakes. I've ridden a lot of bikes, changed a lot of brakes, went back and fourth with a lot of stuff, and spent a lot of money over at hel preformance. And the stock ninjette brakes with fresh dot4 (or whatever it reccomended idr) feel great to me. I can stop on a dime, and on a 250 I don't use the brakes enough to experience any fade. (Maybe I'm just not fast enough).
Old February 15th, 2016, 09:10 PM   #7
Ghostt
Ghostt's Avatar
The key is a property maintained system, which some people don't do.
One must remember that just like everything else on the bike, brakes have service intervals
http://faq.ninja250.org/wiki/Service_Schedule
I proper maintained system will be fine for the majority of owners.
ZX-2R BLOG
Old February 16th, 2016, 09:44 AM   #8
UFOmoplata
UFOmoplata's Avatar
That's good, homie. Do you. I figure SS lines are one less failure point. How hard is it to bleed the lines? Never done that before.
Old February 16th, 2016, 01:18 PM   #9
Ghostt
Ghostt's Avatar
Depends on the bleeding method, I prefer vacuum method it's fast, easy and works, but my caliper guide covers bleeding.
So far as a failure point goes, even Stainless steel braided lines needs to be replaced periodically, they do offer a better feel some say, but if your brakes are spongy due to the hose, odds are it needs replacement, Stainless steel braided lines are often cheaper than OEM, and they look awesome, and even can come in different colours.
HFS (TM) 2 in 1 Brake Bleeder & Vacuum Pump Test Tuner Tool Kit New https://www.amazon.com/dp/B00NP60URE..._Ct4Wwb0RV9MGY
ZX-2R BLOG
Old February 17th, 2016, 08:10 AM   #10
UFOmoplata
UFOmoplata's Avatar
Who's able to make this bracket? Or at least the dimensions?
Old February 17th, 2016, 08:22 AM   #11
HoneyBadgerRy
Some Flatstock off flebay, a drill press, taps, and an angle grinder is all that would be needed. You could make due with a hack-saw, a drill, and some taps.
Old February 17th, 2016, 03:59 PM   #12
Ghostt
Ghostt's Avatar
Am I missing something? Why the changet to NewGen calipers? What are the benefits?
ZX-2R BLOG
Old February 17th, 2016, 04:18 PM   #13
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
The purpose of this is it has a larger piston 5/8", hence more braking force, and better feel.
The larger piston means you'll have to squeeze harder to get the same brake system fluid pressure as the stock setup. And the brake handle won't have to be pressed far.
Better feel? That's in the eye (ok... hand) of the beholder.
Old February 17th, 2016, 04:31 PM   #14
Ghostt
Ghostt's Avatar
Good point, worst case scenario, I could easily change it back if I don't care for the feel. I have $13.50 invested so no big loss.
ZX-2R BLOG
Old February 17th, 2016, 05:13 PM   #15
dcj13
Participant
dcj13's Avatar
Let us know how you like it!
Old February 17th, 2016, 05:28 PM   #16
Ghostt
Ghostt's Avatar
I shall , and of course I will make a blog post/write-up on it. I just wish I know where I read about, but I shall keep looking.
ZX-2R BLOG
Old February 17th, 2016, 08:01 PM   #17
UFOmoplata
UFOmoplata's Avatar
Honestly? Farkle reasons.
I swapped to 17 up front and rotors don't swap over, so I gotta use newgen calipers. I have access to a drill press so I will whip up a bracket.
Old February 17th, 2016, 08:16 PM   #18
verboten1
verboten1's Avatar
MOTM - June '15
I have a caliper and bracket to upgrade to a 4 pot caliper. I never got to use it!
Ride more, worry less.
Old February 17th, 2016, 08:29 PM   #19
Ghostt
Ghostt's Avatar
Ahhh okay gotcha. Did you go 17" on the rear as well?
ZX-2R BLOG
Old February 17th, 2016, 08:48 PM   #20
UFOmoplata
UFOmoplata's Avatar
Not yet. I used @InvisiBill tire calculator and determined 130/90/16 will be close to stock heights.
Stock tire heights aren't equal either so I figured what's the harm?
Old February 17th, 2016, 08:50 PM   #21
UFOmoplata
UFOmoplata's Avatar
Will it mount to pregen forks? Got pic?
Brakes what would you do? crazymadbastard General Motorcycling Discussion 7 March 30th, 2015 11:27 AM
Brakes momoru 1986 - 2007 Ninja 250R Tech Talk 7 August 10th, 2014 07:26 AM
Better brakes?? LittleRedNinjette 2013 - 2017 Ninja 300 Tech Talk 39 July 11th, 2014 08:42 AM
Brakes marc_previtera 1986 - 2007 Ninja 250R Tech Talk 5 October 3rd, 2013 05:22 AM
Brakes Jesse8931 1986 - 2007 Ninja 250R Tech Talk 7 April 11th, 2011 06:17 PM
