Old August 11th, 2009, 07:53 AM   #1
NoobNinja
WTFBBQ?!
NoobNinja's Avatar
hard break in
so im about to come up on my first oil change. I didnt do the sissy way of breaking in the bike and change the oil every 10 miles so i was curious if i should keep running reg oil or switch to synthetic and what kind? im at 900 miles right now but when i go to do the first maint. i'm gonna tell the guy what i want done to it. i've talked to my uncle about it but he said its preference. so im trying to get some other opinions on it.
and i want to know which fender eliminator kit uses the same kind of plastic as the bike but is still no cut something that replaces the whole thing? i've looked thru the site but see alot of DIY fender elim.s and the others its hard to tell.
Done-Aluminum Two bros slip on, Pro grip tank pad, Vortex swingarm spools.
Still in the works-Jet Kit, snorkel removal/K&N filter, Fender eliminator, L.E.D blinkers, Red wheel stripes,
NoobNinja is offline   Reply With Quote
Old August 11th, 2009, 08:39 AM   #2
sofo
sofo's Avatar
Isn't the first maintenance supposed to be done at 600 miles?
Regardless, I'd stay with conventional oil until your next oil change, then switch to synthetic.
sofo is offline   Reply With Quote
Old August 11th, 2009, 09:06 AM   #3
Huh? A "hard" break in necessitates that you change the oil immediately and frequently througout while stressing the engine. The "easy" break in required you to change it over 300 miles ago having taken it easy on the engine. That means that you have gone more than 50% past the first official service interval (and latest recommended) while also being "hard" on the new engine?! And here I was feeling bad about taking it 600mi home and having it serviced at 680mi (even slow freeway driving = constant RPMS, which is bad for a new engine). I took my time too... ~14hrs to go 480mi of the way.
Anyway, the break in officially continues for the first 1,000 miles but actualoly continues even after that. You should not be switching to a lubricant which will prevent even the intended wear that SHOULD be going on in a new engine. Stick to dino oil.
Oh, and every FE kit I've seen is metallic except a full replacement undertail. Hotbodies is supposedly working on one too.
Old August 11th, 2009, 10:28 AM   #4
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Run synthetic oil.
Old August 11th, 2009, 12:37 PM   #5
NoobNinja
WTFBBQ?!
NoobNinja's Avatar
maybe i misled you with whati said. i talked to the dealer and they said that the 600 mile service is not gonna kill me but it should be in before 1000 miles at the most. i meant hard break in by b yim stressing the engine getting the parts worn in but at the same time im taking it easy. i did change the oil at 500 miles but have been pushing the bike alittle bit harder.
Old August 11th, 2009, 01:19 PM   #6
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
so im about to come up on my first oil change ... im at 900 miles right now ...
... i did change the oil at 500 miles but have been pushing the bike alittle bit harder.
NJD022588 is offline   Reply With Quote
Old August 11th, 2009, 01:51 PM   #7
sofo
sofo's Avatar
I am confused as well.
Old August 12th, 2009, 04:16 AM   #8
NoobNinja
WTFBBQ?!
NoobNinja's Avatar
Originally Posted by NJD022588 View Post
haha i know im sorry i forgot about that one i did. shame on me lol i totally mean my first actual maintanence check up im confused also lol
[visordown.com] - How hard is Dunlop pushing? This hard Ninjette Newsbot Motorcycling News 0 June 7th, 2013 11:20 AM
best way to break in a new bike Ravenger General Motorcycling Discussion 16 May 29th, 2012 10:42 AM
Break In akshay11 General Motorcycling Discussion 21 March 22nd, 2012 05:22 AM
[crash.net - MotoGP] - Rossi: A good break for the bad break Ninjette Newsbot Motorcycling News 0 August 10th, 2010 04:40 AM
Break In sm0kediver 2008 - 2012 Ninja 250R Tech Talk 48 July 31st, 2009 12:28 PM
