#1 |
MotorbikeLuv
Join Date: May 2010 Motorcycle(s): 2009 Kawasaki Ninja 250 (sold), 2006 Daytona 675 in Tornado Red (sold), 2007 Ninja 650 Posts: 272
Engine knocking?
Whenever it's really cold out and I have to use full choke to get the bike started, she seems to "miss a beat" every now and then. Sounds kind of like a thump. Once the engine is warmed up a little, it no longer does this and I have never heard it do this when riding or when it's idling. It has done this each winter and every cool fall day when I have to use full choke since I bought her in 2009. I would like to just say it's the nature of the carbed bike, but I'd like some opinions first.
You can hear it in the first half of the video with the choke on full and the second half of the video is just my bike idling without the choke. |
#2 |
Mine does the same thing. It's done it ever since it was brand new.
#4 | |
MotorbikeLuv
I don't believe you're suppose to rev a cold engine. I try to keep the rpms low while the engine is still warming up. You have a fazer that you took apart, right? You might understand the mechanics behind it a little more than I do. I just want to know why it does that. |
#5 |
you shouldn't redline a cold engine but its bad for an engine to run cold. you want it to warm up asap. some mild revving after a few seconds of running is fine and will heat it up to temperature quicker and spin the oil around better.
edit: apparently i didnt watch your video all the way through first time around. it sounds like you are warming it up while it idles. once it gets up to temp, the choke screws up the fuel mix and its too rich. maybe the mix gets too rich to fire and misses. i always say only use the choke until it will take enough gas to pull you away. get the choke off asap and let it warm up under load
#6 |
MotorbikeLuv
I definitely try to use the choke as little as possible and warm up the bike by actually riding it. I've read it in many places before about how to properly warm up your bike and idling for too long sticks out as something to be avoided. Trust me, I love my bike and try to take care of it. That's why the little things bother me lol. Also, that makes sense about the choke making the mixture too rich causing a miss. Thanks.
#7 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250 09 Posts: 31
did you figure it out?
#8 |
MotorbikeLuv
ya. nothing serious. just me being paranoid. I'm going with alex's theory on the mixture being overly rix with the choke on too long causing a miss every now and then. with it off, i have no problems. just have to warm up the bike properly and everything is in tip top shape.
#9 |
IC2(SW)
Sure doesnt rev very high with your choke on..?
![]() Ours will rev to like 5000 rpm full choke cold, then you back it off real quick to 2500. As the bike warms up, it will wanna rev higher, so you back the choke off(a little at a time) to keep it at 2500. Then finaly the choke will be off. |
#10 | |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
#11 |
Jigglin' your Jiglets
MOTM - Apr '13
I'm having a similar issue and thought I heard some pinging as well so I decided to try 91 octane to see if it helps at all. I wasn't sure if it was pinging or not so I figured this will answer my question =]
If the Ninja 250 doesn't have enough power for you, then you don't know how to ride it. AFM #676 ![]() Supersports are for n00bs |
#12 | |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
Posted via Mobile Device |
#13 | |
MotorbikeLuv
2009 ninja 250r engine ticking & knocking noise | ubxssangz | 2008 - 2012 Ninja 250R Tech Talk | 47 | January 26th, 2017 12:15 PM |
2012 NINJA 250 Engine Knocking/rattling? | drosvil | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 28th, 2014 12:13 PM |
Engine knocking noise | vinnyirl | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 8th, 2013 12:33 PM |
Engine Knocking Noise (w/Video) | simmr | 1986 - 2007 Ninja 250R Tech Talk | 16 | July 30th, 2012 01:48 PM |
Engine clunking, knocking under load. | Seattle_Chris | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 4th, 2011 01:33 AM |
