April 13th, 2011, 06:34 AM | #1 |
Join Date: Dec 2010 Motorcycle(s): 2008 Ninja 250r 2009 Honda CBR600RR Posts: 178
New shift lever? help
Ok so the little rubber thing that covers the end of the shift lever has slowly cracked and now is completely gone. Anyone know how to get another one?? or a simple fix it yourself suggestion?
April 13th, 2011, 06:36 AM | #2 |
You can use some rubber hose or get one from a dealer.
April 13th, 2011, 06:44 AM | #3 |
April 13th, 2011, 07:11 AM | #4 | |
$6.00 @ Cheap Cycle Parts I paid $4.00 @ my dealer. The are tight but slide right on with a very light lube. Rubber hose is the same way., |
April 13th, 2011, 07:15 AM | #5 |
Awesome, thanks. Just curious, is there a manual, or diagram that has all the different parts and part #'s?
April 13th, 2011, 07:33 AM | #6 |
April 13th, 2011, 07:39 AM | #7 |
I replaced mine not to long ago and it was hell getting it on. Very, very tight fit. I would suggest a dab of dish soap.
April 13th, 2011, 11:39 AM | #8 |
I use a rubber protectant (armorall) on rubber parts when I want them to slip back on with minimum hassle. Any type of lube helps tremendously.
April 13th, 2011, 12:34 PM | #9 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
April 13th, 2011, 01:32 PM | #10 |
Be careful not to put too much lube on the shaft. You don't want the rubber to come off.
April 13th, 2011, 10:04 PM | #11 |
thanks guys. I just wrapped the cracked one with electrical tape to hold it on for now. Dealer has one for like 8.50
April 13th, 2011, 11:33 PM | #12 |
throw some small ties wraps around it. it'll hold.
Bolt to shift lever on too tight | antiant | General Motorcycling Discussion | 12 | July 12th, 2014 09:23 PM |
My shift lever fell! | LR1914 | 2008 - 2012 Ninja 250R Tech Talk | 14 | October 2nd, 2013 09:31 AM |
Shift lever not resetting | Malicious Logic | 2008 - 2012 Ninja 250R Tech Talk | 13 | August 5th, 2012 06:35 PM |
WTB: Left side turn signal/clutch lever/ shift lever/fairing (green/red or black) | daedrick | Items Wanted | 0 | April 3rd, 2012 12:44 PM |
Help! New Shift Lever! | Tofergstaff | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 18th, 2010 06:13 PM |
