August 20th, 2014, 08:46 PM | #2 |
Join Date: Feb 2013 Motorcycle(s): Ninja 250 (2001) Posts: 135
That's on the left side, right? I believe that's a drain that lets water out of the spark plug chambers
August 20th, 2014, 08:59 PM | #4 |
Join Date: Dec 2013 Motorcycle(s): '04 Ninja 250R Posts: 367
Yea left side! Of the engine.
August 20th, 2014, 09:06 PM | #5 |
What Will said.
August 20th, 2014, 10:11 PM | #6 |
Feels a bit like oil coming from it as well!
August 21st, 2014, 01:24 AM | #7 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
then your valve cover gasket is leaking letting oil fall in to the spark plug hole.
Hey Unregistered never go faster than your brakes can be applied... |
August 21st, 2014, 01:25 AM | #8 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. |
August 21st, 2014, 01:27 AM | #9 |
August 21st, 2014, 11:50 AM | #10 |
August 21st, 2014, 11:51 AM | #11 |
August 21st, 2014, 11:54 AM | #12 |
its your valve cover. and seals as in the ones that you can club.
Breather element woes | LoD575 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 3rd, 2012 09:36 AM |
Crankcase Breather POD | zzrguy | 1986 - 2007 Ninja 250R Tech Talk | 7 | May 2nd, 2012 10:28 AM |
Valve Cover Block off Plates / Crankcase Breather ? | jboyd12 | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 29th, 2012 08:57 AM |
K&N Breather Filter | indr | 2008 - 2012 Ninja 250R Tech Talk | 8 | February 12th, 2011 11:35 AM |
breather? | WELLS | 1986 - 2007 Ninja 250R Tech Talk | 9 | April 27th, 2010 08:03 AM |
