April 1st, 2011, 11:35 PM | #1 |
Join Date: Jan 2011 Motorcycle(s): 2007 Ninja 250, 2012 zx6r Posts: 24
valve adjustment tool
anyone know where to get this tool?! I havent been able to find it anywhere..
Any help would be greatly appreciated! the bike is a 2007 ninja250 |
April 2nd, 2011, 06:26 AM | #2 |
bikebandit.com cheapcycleparts.com etc...
search the OEM parts, select your make, model year, and model, then go to the tools and accessories category. Find the model number of the tool from the diagram and order it. They're usually cheaper than buying it from kawasaki for new oem parts. |
April 2nd, 2011, 10:10 AM | #3 |
ive gotta be missing something. I searched those sites but there i cannot find the adjustment tool. I searched in the valve category and in the tools category
April 2nd, 2011, 10:15 AM | #4 |
April 2nd, 2011, 12:42 PM | #5 |
thanks!
Just to be sure for the valve adjustment, the tool would be the tappet adjustment wrench set correct? Im sort of new to working on the engine of my bike. I know the procedure but want to be 100% sure on which tool to buy |
April 2nd, 2011, 12:47 PM | #6 |
April 4th, 2011, 06:24 PM | #7 | |
I have done the valves twice now on two different Ninjas. I can say for a fact that you don't need this tool. The only valves that need special treatment are the exhaust ones in the front. You need a SHORT 9mm socket with a SHORT extension to get it. And to get it in there, you have to move the crank a little to open up the space so it will fit. After its in there, the thinner extension doesn't take up as much room and you can move the crank back. Also, to do this properly, you need a helper to hold the crank on the mark for cylinder 1 (its under spring tension from the cams). Cylinder 2 will stay on its mark on its own. |
April 5th, 2011, 09:49 AM | #8 |
thanks everyone!
I have all but 1 adjusted. Im going to get back at it here in a few, thanks for all the help! |
valve adjustment tool is it necessary? | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 8 | July 20th, 2014 08:26 PM |
For Sale: Valve Adjustment Tool | cbdallas | Motorcycle-related | 2 | January 9th, 2014 04:03 PM |
digital caliper? right tool for valve adjustment. | NinjaBoyEddy | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 15th, 2013 01:50 PM |
WTB - Pre Gen Valve Adjustment Tool | Jim Moore | Items Wanted | 3 | June 20th, 2012 07:22 AM |
need help fast!!!! valve adjustment tool | 4x4kayak2112 | 2008 - 2012 Ninja 250R Tech Talk | 0 | May 6th, 2011 07:37 AM |
