May 23rd, 2017, 06:16 AM | #1 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Fuel smell in garage
This is pretty far OT but I thought I'd ask you guys.
I have a gas can, a lawnmower, and a bike in the garage. I've narrowed it down and the lawnmower is putting out a ton of fumes into the garage. I put some cardboard underneath the lawnmower to see if it's leaking and if it is leaking nothing is making it to the ground. Any one have any hints for things I can check or things I can do to help reduce the fumes? It's gotten to the point where I have to leave the garage door open to air it out every day. |
May 23rd, 2017, 06:56 AM | #2 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
If it were me; I'd remove anything that might be leaking gas outside until it's resolved!
News at 11!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
May 23rd, 2017, 07:39 AM | #3 |
Gas cap on mower is most likely vented to atmosphere.
May 23rd, 2017, 08:16 AM | #4 |
not an actual panda
May 23rd, 2017, 08:21 AM | #5 |
not an actual panda
Actually I just put a plastic bag over the fuel cap and then secured it with a rubber band. I'll take off the bag when I run the mower. We'll see if this stops the smell.
Thanks for pointing out the venting caps. |
May 23rd, 2017, 10:51 AM | #6 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
It's a failed valve in the float bowl of the lawnmower's carburetor.
Verify by checking the oil level in the mower: It'll be way high, because the gas is leaking into the crankcase. Easiest solution is to install a $7 fuel petcock between the gastank and carb and change the oil. |
May 24th, 2017, 06:48 AM | #7 | |
not an actual panda
May 24th, 2017, 07:41 PM | #8 | |
Old and slow
Join Date: May 2014 Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250 Posts: 889
takes a little bit to figure out exactly how much gas is needed to mow the lawn but you'll figure it out that's what I do. But just so you know, your garage is supposed to smell like plywood, brake cleaner and kerosene ... just how it's supposed to be, Toss in a little gas and exhaust and fresh cut grass from time to time as well.
May 24th, 2017, 08:20 PM | #9 |
MOTM - July '15
you could put a condom over the gas cap and see how quickly it fills up. If it's not a significant amount, check how it seals. Still not, then the mower's probably not your problem.
May 25th, 2017, 06:48 AM | #10 | |
not an actual panda
I think I'll try your technique. I called a local shop and the guy wanted 75 bucks to pull the carbs apart. The lawnmower only cost 100 bucks I'm not sure it's worth it and I'm pretty sure I have just enough tools to disassemble the lawnmower but not enough tools to re-assemble the lawnmower. |
May 25th, 2017, 06:51 AM | #11 | |
not an actual panda
[motorcyclistonline] - GASOLINE 101: Let's Talk About Ethanol Fuel | MC GARAGE | Ninjette Newsbot | Motorcycling News | 0 | October 3rd, 2015 05:50 AM |
[roadracingworld.com] - AMAtv/Greg's Garage: AMA Vintage Days & E15 Fuel Issue | Ninjette Newsbot | Motorcycling News | 0 | June 19th, 2014 06:40 PM |
Burning smell anyone? | ricochet08 | 2008 - 2012 Ninja 250R Tech Talk | 29 | November 21st, 2013 08:45 PM |
Smell like a Monster! | Flashmonkey | Off-Topic | 8 | October 12th, 2010 07:15 AM |
Fuel Smell+Dropped it | snowboardenc | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 19th, 2009 08:27 PM |
