June 30th, 2012, 09:09 PM | #1 |
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R Special Posts: 78
Modifying the snorkel
Has anyone every modded their snorkel?
I was thinking about either cutting it down to make it shorter or removing the diaphragm that runs down the center of it. I don't have that much experience with small engines like this and wondered if doing this mod would do much if anything at all. I have an aftermarket DanMoto exhaust and I will be shimming the carb needles soon. I noticed that you are supposed to remove the snorkel and the question crossed my mind. Thanks! |
June 30th, 2012, 09:49 PM | #3 |
I've done both. Neither made a significant difference, although removing the resonator out of the middle makes it easier to put the snorkel back in. Removing the snorkel altogether is much better.
July 1st, 2012, 07:06 AM | #4 |
Should I still shim the needles after I remove the snorkel? Or won't it matter that much since I have a slip on and snorkel removed?
July 1st, 2012, 08:31 AM | #5 |
July 1st, 2012, 10:45 AM | #6 |
Don't touch the snorkel and don't put shims in your carbs. If you want power buy a full exhaust and a jet kit.
July 1st, 2012, 08:42 PM | #7 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
Stock Exhaust modifying ? | DuplexUno | 2008 - 2012 Ninja 250R Tech Talk | 9 | February 22nd, 2014 02:12 PM |
Shimming vs Snorkel out | vmax | 2008 - 2012 Ninja 250R Tech Talk | 4 | December 7th, 2013 07:30 PM |
Relocating or modifying the kickstand mount? | StevieMac | Ninjettes At Speed | 3 | August 4th, 2012 01:11 AM |
modifying stock exhaust | dbking321 | 1986 - 2007 Ninja 250R Tech Talk | 25 | March 28th, 2012 11:05 AM |
Modifying my 250r | wellcraft | 2008 - 2012 Ninja 250R Tech Talk | 15 | January 7th, 2010 08:45 AM |
