October 5th, 2010, 10:21 PM | #1 |
Join Date: Oct 2009 Motorcycle(s): 2008 Ninja 250r, 2006 Ninja 636 Posts: 175
proper downshifting?
:EDIT: Oops, sorry Alex!, should've put this on the Riding Skills page. is there a way i can move it myself without bothering you? lol
I've had my bike for just about 2 weeks now and I'm still learning how to ride properly... I was wondering if it's bad for the bike when you downshift and just let the clutch out (slowly, naturally) instead of blipping the throttle? I might be (probably am) wrong, but I feel like it's easier to slow the bike down without adding anymore throttle and letting the engine stop the bike? through newbtacular trial and error, I've discovered that merely letting the clutch out at 25 mph in 1st gear is a BAD idea. i pulled that clutch right back in hehe. Last futzed with by heylookitsfranco; October 5th, 2010 at 10:23 PM. Reason: posted on wrong forum section |
October 5th, 2010, 10:25 PM | #2 |
I'd suspect it'll accelerate your clutch friction plate wear. The question is how much vs rev-matching given the ninjette's practically a paperweight on wheels.
October 5th, 2010, 10:29 PM | #3 |
yeah dropping the clutch at 25mph in first is a bit much. plus you could cause the rear tire to kick out a bit. to be honest i don't do alot of blipping, but rahter gently release the clutch and then try to get rpm's back.
October 6th, 2010, 01:35 AM | #4 |
I never downshift the bike into first except when it's at a stop/just before rolling to a stop.
you can do a lot of engine damage if you spin the engine too fast by downshifting too early into an inappropriate gear. 25 in first is waaay to fast for first. use both your brakes and engine to help slow the bike. both your brakes and engine will thank you. think of the clutch as a gentle way to engage gears. imagine it as a variable pillow between the metal to metal blows the gears encounter when you shift. |
October 6th, 2010, 06:04 AM | #5 |
/moved to riding skills
October 6th, 2010, 06:34 AM | #6 | |
October 6th, 2010, 08:53 AM | #7 | |
October 6th, 2010, 08:57 AM | #8 |
Do HD riders blip? I think they over blip, more like a blap. Every freaking thing results in a blip of the throttle, downshifting, idling, using the turnsignals, seeing a fellow HD rider.
October 6th, 2010, 09:04 AM | #9 |
Join Date: Jun 2010 Motorcycle(s): 2010 Ninja 250R Posts: A lot.
i engine brake alllll the time. But I don't downshift more than one gear at a time. Lets say i'm coming to a red light, I down shift lets say from 4th gear to 3rd, I listen to the engine rawr then quiet down, then I shift again to 2nd, i let the engine do its thing, then I hold the clutch in and if I need to I'll drop it down to first and come to a complete stop, but usually, if i'm lucky, by that time the light turns green and I don't have to drop down to first, I just let roll the throttle on second and off I go.
sometimes I aim to please, but mostly I shoot to kill |
October 6th, 2010, 08:47 PM | #10 |
ahh, good to know I'm not doing it completely wrong hehe. I guess i just have to keep practicing using the brake clutch and shifter simultaneously. i was just thinking that by engine braking most of the time, i could reduce the amount of wear on my brake pads, but i suppose I'd wear down the clutch plates instead...
thanks for the replies, everybody! |
October 7th, 2010, 08:44 AM | #11 |
Franco, engine braking and clutch wear aren't necessarily synonymous. Just rolling off the throttle can produce engine braking especially in the lower gears, perhaps not so much in the 250 twin. Downshifting to slow the bike would increase clutch wear. I think the right approach depends on the situation and the combination changes depending on that situation. Obviously to come to a compete stop you would be downshifting and using the brakes, but to just roll off some speed you might just roll off throttle. Find a good place to practice and experiment to find whats right for you.
October 7th, 2010, 12:58 PM | #12 | |
Join Date: Aug 2010 Motorcycle(s): 2007 Blue Ninja 250R Posts: 650
October 7th, 2010, 03:11 PM | #13 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE Posts: 564
I never had a problem downshifting without blipping on my Ninja, just need to ensure the clutch is not dumped, and that you are not going to over rev the engine (this is required for downshifting in general, blipping or not.) and not going around a corner so as it does not upset the bike.
1st gear on the Ninja is too short to be usable, but on my Daytona, I am often in 1st and still in it over 60mph...
2008 GREEN Kawasaki Ninja 250R. AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen |
October 7th, 2010, 03:55 PM | #14 | |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
I typically won't go to first unless I'm already going about 5mph. I always match engine speed by blipping.
Addicted to anything that has an engine and rolls. |
October 7th, 2010, 05:09 PM | #15 |
Join Date: Jun 2009 Motorcycle(s): CBR600RR Ninja 250R(sold) Posts: 144
LOL!
It was opposite for me. When I first started riding I had a habit of blipping just about every time I down shift. Sometimes I blap even though I meant to blip and jerk forward a little. Very embarassing and even dangerous. |
October 7th, 2010, 08:47 PM | #16 |
^^ lol
October 28th, 2010, 07:21 PM | #17 |
Join Date: Oct 2010 Motorcycle(s): Current: 2011 ZX6r Owned: 2010 EX250R "Special Edition" Posts: 71
What does "blipping" mean?
October 28th, 2010, 10:06 PM | #18 |
Tasty!
Join Date: Mar 2010 Motorcycle(s): EX 250, 2010 250R Posts: 8
Blipping is, when the clutch lever is pulled in, giving a squirt of throttle while downshifting. This helps bring the RPMs up higher, hopefully making the downshift a bit smoother when you release the clutch lever. It's probably named this way because of the "blip" on the RPM gauge when you give the throttle a little twist.
here is a short youtube video that give you an idea of what it is.
Link to original page on YouTube. |
October 29th, 2010, 06:31 AM | #19 |
The more accurately you blip, the faster you can have the clutch out in the next gear without upsetting the chassis. In riding aggressively, I would go crazy having to deliberately ease the clutch out to keep the back wheel from hopping all over the place.
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
October 29th, 2010, 11:46 AM | #20 |
That is impressive...my downshifting is no where near that smooth...I need to work on that quite a bit still...among other things.
October 29th, 2010, 02:31 PM | #21 |
You aren't saving time, blipping makes the downshifting/slowing process take longer.
October 29th, 2010, 08:40 PM | #22 |
Compared to what? Without blipping, if you just pop out the clutch in the next lower gear you will get bad rear-wheel skidding or hopping. Compared to just slowly letting out the clutch to allow the engine to calmly catch up to the drivetrain without rev-matching, blipping is as fast as you can get while still maintaining some control over the rear wheel.
Unless you are talking about just jamming it down through the gears and taking advantage of a back-torque-limiting clutch?
October 31st, 2010, 12:31 PM | #23 | |
October 31st, 2010, 06:31 PM | #24 |
How would it be smooth? If I am at 10k in 3rd (about 65mph for me) and shift down to 2nd without even a blip, the engine will be spinning almost 25% lower than it needs to be. I can guarantee my rear tire would be hopping and chirping.
BTW, if I am using the clutch to downshift, blipping does not add any time to what is already required to squeeze in the clutch and get the transmittion to the next lowest gear. Takes me about 1/4 to 1/3 of a second, without any loss of control of the rear, and is not affected by whether or not I do any quick throttle blipping.
Downshifting woes | RogerPapaMike | 1986 - 2007 Ninja 250R Tech Talk | 14 | April 30th, 2014 10:20 AM |
Proper Camera, Proper Bike (07 Ninja 250) | elninoloco7 | Pictures | 5 | May 22nd, 2012 10:32 AM |
Downshifting | akshay11 | Riding Skills | 17 | March 18th, 2012 02:52 PM |
Downshifting 101 | JoeLansing | Riding Skills | 39 | July 19th, 2011 03:47 AM |
Downshifting Problems | Neoki | Riding Skills | 22 | June 1st, 2010 12:01 PM |
