June 26th, 2011, 06:59 AM | #1 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
led flasher help
i just installed a set of flush mount led turns for the front of my bike, the rear is still stock lights, for now anyway.. but they are 2 wire leds.. yellow and a black wire. i used a EL-12 flasher and the signals still arent working right, when i hit the turn signal they just stay lit solid.. no instructions at all with the led signals, bought them from cycle gear.. im assuming there are only 2 ways to wire them and ive tried both.. one way they stay solid, the other way no lights at all?? do i still need a resistor wired in? i was assuming you change the relay and i wouldnt need a resistor.. any help would be appreciated it
June 26th, 2011, 04:33 PM | #2 |
Ridin Dirty
nevermind.. took it all apart and rewired it.. worked fine..loL! must of not had a good connection.
Flasher issue | Phoenix Cycle Shop | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 16th, 2014 05:52 PM |
Electronic Flasher Issue | 95XL | 1986 - 2007 Ninja 250R Farkles | 11 | August 1st, 2012 07:10 PM |
LED flasher relay part number | 808derek | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 30th, 2011 08:59 PM |
Flasher relay question!!!!! | danjaho | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 8th, 2011 03:03 PM |
Brake Light Flasher? | lux | 2008 - 2012 Ninja 250R Farkles | 2 | October 28th, 2010 06:34 AM |
