Old April 1st, 2012, 03:03 PM   #1
Liist
Liist's Avatar
Where Clutch Should Engage
When I got my bike, the clutch engaged near the middle of the pull and that's the way it's been until I let the mechanic test ride my bike. When he test rode it, he adjusted where the clutch engages near the end.
It was quite a shock at first trying to take off but it didn't take long to get used to. I can now rev match on downshifts easier but still forgetting where it engages when I'm at a stop.
Where do you like the clutch to engage and why? Is having it engage near the end the way it's supposed to be?
Liist is offline   Reply With Quote
Old April 1st, 2012, 03:04 PM   #2
That's the way mine is. Seems normal to me?
I purchased adjustable levers (and an ex500 clutch perch so I can mount them on my pregen) so I can hopefully bring the engagement point in, without putting so much slack in the clutch cable that the lever vibrates and buzzes.
Old April 1st, 2012, 04:26 PM   #3
Originally Posted by Liist View Post
........, he adjusted where the clutch engages near the end.
What end?
Old April 1st, 2012, 05:01 PM   #4
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
I like it in the middle so I don't have to pull it all the way to shift, I'm lazy lol. It doesn't really matter where it engages, just as long as it doesn't slip
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old April 1st, 2012, 05:06 PM   #5
shiftyninja
Motorcycle(s): 09' EX250J, 01' EX250R
Should be where you feel comfortable. The mechanic should have asked you before adjusting or adjusted it back. Mines about halfway like others. As Felipe said as long as it doesn't slip, you should be fine.
Posted via Mobile Device
shiftyninja is offline   Reply With Quote
Old April 1st, 2012, 08:27 PM   #6
Liist
Liist's Avatar
Originally Posted by Motofool View Post
What end?
End away from me, towards the front of the bike.
Old April 1st, 2012, 08:31 PM   #7
If it bugs you that the engagement point is that far out, either buy adjustable levers to bring the engagement point in, or adjust a little slack into the cable, and the lever will come closer to you and bring the engagement point along with it
Old April 1st, 2012, 08:32 PM   #8
Then verify that he did it in a way that there is a minimum of 2 mm of cable slack at the very end.
If not, the clutch is not getting fully engaged because the cable does not completely release the lever that enters the clutch cover, which could ruin the discs and springs.
Old April 1st, 2012, 08:40 PM   #9
Liist
Liist's Avatar
I know the clutch is fully engaging. There is about a half inch before I feel the friction zone. Just more out than I'm used to.
Old April 2nd, 2012, 06:18 AM   #10
Sigma.40
Motorcycle(s): 1999 "1000cc" ZX9R
Mine engages at the end. It took a little getting used to, but I think I like it there now.
Sigma.40 is offline   Reply With Quote
Old April 2nd, 2012, 03:13 PM   #11
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
give or take 4-6 mm from the middle is where mine is
blink-182
blink is offline   Reply With Quote
Old April 23rd, 2012, 09:41 AM   #12
Miles_Prower
One Loyal Fox
Miles_Prower's Avatar
Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R
mines out towards the end, and so far I'm not sure if I like that, though it may be because I've only put 25 miles on my bike so far LOL. It's just an awkward feeling when I think I've nearly let my clutch out all the way, yet the bike doesn't start moving. Already had an instance where I thought I was in neutral so I pulled it back in and tried to downshift (was in 1st already).
To make it worse, I'm tiny, and I have small hands so I kind of have to "reach" to get the lever.
Miles_Prower is offline   Reply With Quote
Old April 24th, 2012, 07:44 AM   #13
raybolic
Motorcycle(s): Ninja250R
If it's near the end.. isnt it a lot harder to feather the clutch when going low speed or low speed cornering? I find myself feathering whenever I am going extremely slow in traffic..
raybolic is offline   Reply With Quote
Old April 24th, 2012, 08:16 AM   #14
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
The important part of clutch adjustment is making sure that adequate freeplay exists between the lever and the base when the clutch is released. 2-3 mm is enough. If your clutch is engaging near the end of the lever's travel, it's possible that you have no freeplay, which can eventually burn your clutch if this situation causes slippage.
On the other side of that coin, adjusting in too much freeplay for the purpose of earlier engagement can cause a lack of complete disengagement when you fully squeeze the lever, causing rough shifts and eventual transmission damage, as well as accelerated clutch wear due to it being partially engaged when the bike is stopped.
Adjustable levers are great for putting the friction point where you want it. I'd be hesitant to use the cable adjuster for this purpose.
cbdallas is offline   Reply With Quote
Old April 30th, 2012, 07:03 AM   #15
My understanding is that the friction zone moves forward as the clutch wears regardless of the adjustment slack. Mine doesn't engage until it is almost completely forward, meaning it's probably time for a new clutch.
Old April 30th, 2012, 08:52 AM   #16
Felipe the Ant
Only if your cable is adjusted as tight as possible and isn't stretched beyond spec
Old April 30th, 2012, 09:13 AM   #17
New cable.
Old April 30th, 2012, 09:22 AM   #18
zzrguy
zzrguy's Avatar
Motorcycle(s): 2002 ZZR 250
get adjustable levers they are op! When in heavy traffic you can save your clutch hand!
zzrguy is offline   Reply With Quote
Old May 2nd, 2012, 09:44 AM   #19
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Mine is adjusted to grab as the lever is just about the reach full pull (so pulling it in all the way) I like it that way because i can launch quicker with it
----> My Youtube! <----
Old February 27th, 2016, 02:38 AM   #20
vkuchhal
vkuchhal's Avatar
Motorcycle(s): ninja 250r -2010
Friction zone Question
Sorry to have revived an old thread. but after going thru all the post available on the ninjette. have a question regarding the zone.
Have attached in image the discusses the friction zone. my question is that what happens if from position 3 to 4 is very small. does it reflect the the clutch plates are gone.. I am unable to identify any clutch slippage in the bike.. please guide..
PS: There is 2 mm of free play in the lever.
vkuchhal is offline   Reply With Quote
Old February 27th, 2016, 02:40 AM   #21
Flying
Motorcycle(s): 2010 Ninja 250
The friction zone on the Ninja 250 is a little small, that's normal and not indicative of excessive clutch slippage.
Old February 27th, 2016, 08:25 AM   #22
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
A trick I use when adjusting cable clutches is to use a nickel. You should be able to insert a nickel in between the lever and the perch.
Goin' fast on slow bikes!
!!CLUTCH ISSUES!! need help!! actuator/bolt will not engage pacificgreens 1986 - 2007 Ninja 250R Tech Talk 7 October 18th, 2014 01:58 PM
250 won't engage to 3rd reroka 2008 - 2012 Ninja 250R Tech Talk 48 June 12th, 2014 03:07 AM
[roadracingworld.com] - Yamaha Is Ready To Go Racing And Engage The Fans At The GEICO Ninjette Newsbot Motorcycling News 0 April 25th, 2014 02:40 PM
[motogp.com] - Schwantz and Puig engage in war of words over Pedrosa Ninjette Newsbot Motorcycling News 0 April 29th, 2013 05:10 AM
[kropotkin thinks...] - Dorna's New Owners Engage In More Debt Refinancing Ninjette Newsbot Motorcycling News 0 November 5th, 2012 11:20 AM
