Old April 20th, 2015, 11:05 AM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
clutch cable replacement
hi there is ther a step by step or video on changing the clutch cable on a ninja 250
also what gear should bike be in when I change the clutch cable
james250ninja is offline   Reply With Quote
Old April 20th, 2015, 11:30 AM   #2
Ghostt
Ghostt's Avatar
Not that I know of, gear makes no difference, just remove old one, install and lube new one, and adjust it so there is a little bit of slack to your liking.
Just be sure the follow the same cable routing as old one, to avoid binding, excessive bending etc...
As long as your lubing the clutch cable, lube all the other ones too.
This is what I use, and swear by it.
violente et ignorantia
ZX-2R BLOG
Old April 20th, 2015, 11:52 AM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Easiest way to ensure correct routing is to duct-tape end of new cable to other end of old cable and pull it through.
Old April 20th, 2015, 11:54 AM   #4
Ghostt
Ghostt's Avatar
ZX-2R BLOG
clutch cable james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 July 27th, 2013 10:20 AM
Please help!! Clutch cable replacement complication Dustinfools 2008 - 2012 Ninja 250R Tech Talk 31 November 29th, 2012 01:34 PM
Clutch Cable atomicrm 2008 - 2012 Ninja 250R Tech Talk 2 December 17th, 2011 12:22 PM
Help on Clutch Cable kashun84 2008 - 2012 Ninja 250R Tech Talk 6 March 31st, 2011 08:55 PM
2008 model clutch cable snapped @ 17,800 miles. Replacement? CZroe 2008 - 2012 Ninja 250R Tech Talk 9 December 14th, 2010 05:40 PM
