Old August 18th, 2015, 07:26 AM   #1
22R88
Motorcycle(s): 2004 EX250R
Tire Fitment Questions
Will these tires fit on my stock 2004 Ninja 250R ?
https://www.motorcycle-superstore.com/checkout/payment
Any comments are appreciated
22R88
22R88 is offline   Reply With Quote
Old August 18th, 2015, 08:37 AM   #2
Suki2003
Ninjette Lurker
Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected)
The link takes me to an empty cart. what is the link to the tires on the website. http://faq.ninja250.org/wiki/What_ti...fit_the_250%3F
This is an excellent reference if you are doubting the fitment
Suki2003 is offline   Reply With Quote
Old August 18th, 2015, 08:47 AM   #3
22R88
Sorry see if this works ?
http://www.motorcycle-superstore.com...r-st-rear-tire
http://www.motorcycle-superstore.com...-st-front-tire
Old August 18th, 2015, 09:16 AM   #4
allanoue
allanoue's Avatar
MOTM - Sep '14
Your links have a few sizes that fit.
See link in post #2
Old August 18th, 2015, 09:30 AM   #5
22R88
Thanks I appreciate the link
Old August 18th, 2015, 10:38 AM   #6
Ghostt
Ghostt's Avatar
I have run the Kenda K671s on my EX500 for many years, it's a great tire for the money, excellent wet weather performance, and a great high mileage tire, about 8K miles
I decided to try the Bridgestone BT45s for the Ninjette, and I'm also satisfied with those, about the same performance as the K671s, with better cornering due to the dual compound tire, but at a higher cost, and less mileage about 7k.
I'll most likely go back to the K671s as I don't attack the twisties as hard as I use to in my younger days. On my EX500 I've never had any issues with confidence in the twisties with the K671s.
Both bikes have had the suspension modified/upgraded to my weight, taste, and style of riding.
violente et ignorantia
ZX-2R BLOG
Old August 18th, 2015, 10:43 AM   #7
22R88
Thanks for the reply. I just ordered a set of the 671's. I sure they will work fine for my needs.
22R88
Old August 18th, 2015, 11:07 AM   #8
Ghostt
Ghostt's Avatar
22R88
As far as balancing goes I personally use Dynabeads or Counteract, I run them in all my vehicles with excellent results.
ZX-2R BLOG
Old August 18th, 2015, 12:59 PM   #9
allanoue
allanoue's Avatar
MOTM - Sep '14
@Ghostt have you looked at the Michelin Pilot streets? On the surface they looked to be more expensive but they have a very long life so you get all your money back with few trips to the tire store.
Old August 18th, 2015, 01:09 PM   #10
Ghostt
Ghostt's Avatar
I was under the belief that they don't come in 16"
If I'm wrong, please link a brother up.
ZX-2R BLOG
Old August 18th, 2015, 01:12 PM   #11
allanoue
allanoue's Avatar
MOTM - Sep '14
I really need to pay closer attention to where I am
Old August 18th, 2015, 03:28 PM   #12
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
What are you doing to only get 8K miles on your K671s? On my EX250 I typically get 23-25K rear and 27-28K front.
As far as balance goes, I have a couple of tire weights I found in my gutter a few years back and just use those. I do check the balance of my rims and my tires separately and then install with the heavy spots opposite. I've found the heavy spots are not at the valve stem nor at or opposite the mark on the tire.
Old August 18th, 2015, 04:01 PM   #13
Ghostt
Ghostt's Avatar
@FrugalNinja250
That mileage is on the EX500, and I weigh about 230lbs with gear, maybe that's why my mileage is low, I use it mostly for commuting
Balance beads are easy to install, and are constantly keeping the tires in balance.
ZX-2R BLOG
chain and tire questions twistywrist 2013 - 2017 Ninja 300 Tech Talk 16 June 25th, 2014 11:42 PM
Tire questions capriccio Ninjettes At Speed 2 May 31st, 2012 01:53 PM
Tire questions Bols 2008 - 2012 Ninja 250R Tech Talk 1 September 6th, 2010 11:59 AM
150 tire size and Ebay hugger fitment randomwalk101 2008 - 2012 Ninja 250R Tech Talk 7 October 9th, 2009 06:16 AM
More Tire Questions minuslars 1986 - 2007 Ninja 250R Tech Talk 4 August 28th, 2009 11:17 PM
